unisoft 355 Posted January 9, 2020 Posted January 9, 2020 There is for some time been an issue with dates in XML files and getting the month and day the wrong way round, despite on Synology Emby Server it being correct format for UK. Both dates look correctly formatted. Seems to affect the early part of the month and then something like after the 12th of each month, it reads it in correctly again. When it does this I have to use the metadata editor in Emby to swap the month and day around so it's correct. Reported before some time ago.
Luke 42287 Posted January 9, 2020 Posted January 9, 2020 That's another reason to use nfo over xml. I do not want to change the xml date parsing over worries of it negatively affecting others, and I do not have enough bandwidth to start building options into the xml plugin. But with nfo there is no such problem.
gnollo 17 Posted October 23, 2022 Posted October 23, 2022 (edited) Hello everyone, I think that after upgrading to server 4.7.8.0 the library scan picked up multi files within a movie folder and thinks that are different films, is there a way to fix that without having to reencode hundreds of old movies in my library? Edited October 24, 2022 by gnollo
Happy2Play 9814 Posted October 23, 2022 Posted October 23, 2022 (edited) 11 minutes ago, gnollo said: Hello everyone, I think that after upgrading to server 4.4.8.0 the library scan picked up multi files within a movie folder and thinks that are different films, is there a way to fix that without having to reencode hundreds of old movies in my library? Sorry can you elaborate? At the same time not much support can be provided for older server versions. Maybe a typo? Edited October 23, 2022 by Happy2Play
gnollo 17 Posted October 24, 2022 Posted October 24, 2022 9 hours ago, Happy2Play said: Sorry can you elaborate? At the same time not much support can be provided for older server versions. Maybe a typo? Yes, sorry, I’m on version 4.7.8.0
GrimReaper 4926 Posted October 24, 2022 Posted October 24, 2022 10 hours ago, gnollo said: Hello everyone, I think that after upgrading to server 4.7.8.0 the library scan picked up multi files within a movie folder and thinks that are different films, is there a way to fix that without having to reencode hundreds of old movies in my library? As stated: 10 hours ago, Happy2Play said: Sorry can you elaborate? Specific example will be needed with some more details, like your folder structure, naming scheme etc. 1
gnollo 17 Posted October 25, 2022 Posted October 25, 2022 yes for example \unraid\divx\knocked.up\p-kua.avi \unraid\divx\knocked.up\p-kub.avi No subflolders No subtitles only xml, nfo and jpg files in the same folder Emby actually scanned and added the p-kub.avi as Kubo and the two strings... The file has been there since 2007, so something must have changes in Emby for it to suddenly pop up, alonge side all my other multiple files per movie folders...
gnollo 17 Posted October 27, 2022 Posted October 27, 2022 Does anybody know why that does not work anymore? It did work before.
Luke 42287 Posted October 27, 2022 Posted October 27, 2022 HI, can you please show the complete contents of the folder, with exact file names? Thanks.
Happy2Play 9814 Posted October 27, 2022 Posted October 27, 2022 (edited) @gnollo Not sure as I don't have your metadata, adding your example to a db only library creates two movies from this structure as filename is queried. \divx\knocked.up\p-kua.avi \divx\knocked.up\p-kub.avi Line 129: 2022-10-27 16:11:31.336 Info App: MovieDbProvider: Finding id for item: p-kua Line 186: 2022-10-27 16:11:33.879 Info App: MovieDbProvider: Finding id for item: p-kub Folder view for these two files I can only guess your existing metadata is not being read. Edited October 27, 2022 by Happy2Play
gnollo 17 Posted October 27, 2022 Posted October 27, 2022 51 minutes ago, Luke said: HI, can you please show the complete contents of the folder, with exact file names? Thanks. Directory of Z:\divx\Knocked.Up 03/02/2020 22:27 <DIR> . 23/10/2022 02:06 <DIR> .. 24/12/2009 09:22 663,586 fanart.jpg 15/11/2009 18:15 90 p-kub.dvdid.xml 15/11/2009 18:15 90 p-kua.dvdid.xml 03/02/2020 22:27 14,655 movie.xml 15/11/2009 18:44 205,752 mymovies-front.jpg 15/11/2009 18:15 52,386 folder.jpg 22/08/2007 14:02 733,564,928 p-kua.avi 03/02/2020 22:27 9,163 p-kua.nfo 22/08/2007 14:03 728,887,296 p-kub.avi 15/11/2009 18:15 52,386 poster.jpg 15/11/2009 18:44 277,912 mymovies-back.jpg 24/12/2009 09:22 663,586 backdrop.jpg
Luke 42287 Posted October 27, 2022 Posted October 27, 2022 OK yes with 4.7 we no longer combine on just a and b because that can lead to false positives where things get combined that shouldn't. You'll need to use an explicit method to name them as multi-part: https://support.emby.media/support/solutions/articles/44001159102-movie-naming So for example: Knocked Up (2009)-part1.avi Knocked Up (2009)-part2.avi Knocked Up (2009)-pt1.avi Knocked Up (2009)-pt2.avi Knocked Up (2009)-pta.avi Knocked Up (2009)-ptb.avi etc.
gnollo 17 Posted November 14, 2022 Posted November 14, 2022 Yep this worked, thank you. The unfortunate thing is that now I have to rename over 400 movies, so over 800 manual file renaming....
gnollo 17 Posted November 27, 2022 Posted November 27, 2022 Job done, the movie list is now back to how it should look, thanks for the tip Luke. 1
gnollo 17 Posted November 27, 2022 Posted November 27, 2022 (edited) Hmm, now that I can see the movies, I realised that new additions do not show up at all. I just scanned manually several times, no change. The movies are in the usual folder, but they are not being picked up. Any thoughts? Also manually updated the server docker version to 4.7.10.0, and scanned again, no change. [edit, although both issues manifested after the software upgrade, they are separate, so I will create a new thread for this one.] Edited November 27, 2022 by gnollo
Luke 42287 Posted November 28, 2022 Posted November 28, 2022 12 hours ago, gnollo said: Hmm, now that I can see the movies, I realised that new additions do not show up at all. I just scanned manually several times, no change. The movies are in the usual folder, but they are not being picked up. Any thoughts? Also manually updated the server docker version to 4.7.10.0, and scanned again, no change. [edit, although both issues manifested after the software upgrade, they are separate, so I will create a new thread for this one.] HI there, can you please provide a specific example? thanks.
tanStaafl 15 Posted June 28, 2023 Posted June 28, 2023 (edited) As I understand it, nfo is the default, but EMBY xml is also an option from the library configuration. Is the xml structure the same as the nfo structure or is it different. I understand that the nfo file is in xml and follows KODI format, is the xml xml file the same? Hope this isn't confusing, as I am almost confused myself The reason I am asking is that all my metadata is in .xml files and has been since this was Media Browser and want to make sure the formatting is correct. Edited June 28, 2023 by tanStaafl
Luke 42287 Posted June 28, 2023 Posted June 28, 2023 1 hour ago, tanStaafl said: As I understand it, nfo is the default, but EMBY xml is also an option from the library configuration. Is the xml structure the same as the nfo structure or is it different. I understand that the nfo file is in xml and follows KODI format, is the xml xml file the same? Hope this isn't confusing, as I am almost confused myself The reason I am asking is that all my metadata is in .xml files and has been since this was Media Browser and want to make sure the formatting is correct. It’s different than nfo. At this point in all honesty you’re better off deleting them as Emby server’s xml support has not been kept up to date with new features in the way nfo has.
tanStaafl 15 Posted June 28, 2023 Posted June 28, 2023 Thank you for the quick response. So I should just delete, not replace with .nfo formatted files? EMBY will do this for me?
tanStaafl 15 Posted June 28, 2023 Posted June 28, 2023 Ok, I see now how it works and where the .nfo files are stored. So one last question, is there a way to direct the tv show .nfo files to a separate metadata folder? Thanks in advance.
Luke 42287 Posted June 29, 2023 Posted June 29, 2023 22 hours ago, tanStaafl said: Thank you for the quick response. So I should just delete, not replace with .nfo formatted files? EMBY will do this for me? If you delete, then Emby Server will gradually save new nfo's over time whenever metadata is updated.
Luke 42287 Posted June 29, 2023 Posted June 29, 2023 20 hours ago, tanStaafl said: Ok, I see now how it works and where the .nfo files are stored. So one last question, is there a way to direct the tv show .nfo files to a separate metadata folder? Thanks in advance. There is no option to move the nfo files to another location, sorry.
tanStaafl 15 Posted July 2, 2023 Posted July 2, 2023 Thanks again for all your help. I wrote a forward facing interface 12+ years ago to supplement what was Media Browser at the time (uses RSS, RAR, uTorrent WEBui etc). It appears many of the features I built into it are no longer necessary as EMBY handles it all .. time for an overhaul! I found that if I delete the .xml's then go to each library and refresh the metadata it builds all the .nfo files immediately.. so one and done!! Thanks again!! 1
tedfroop 34 Posted July 2, 2023 Posted July 2, 2023 Sorry for probably covering ground that may have been covered here already but I have difficulty with logic and cognition at times, and following threads is difficult at best....... Please correct me if I'm wrong, but in the interests of preserving backing up and restoring in case of trouble I need help understanding this. - If I take a file, lets say a Looney Tunes cartoon, and add metadata, say adding the cartoon characters as actors. And add photos and bio for those characters, IF I don't have NFO metadata savers active, then all the meta I change is saved to the XML database (both actor and file). IF I do a full refresh and don't have the file data locked - it disappears? I would have to go back and add those "actors" again? - If I choose to go to NFO savers, the meta is saved to the NFO any time the meta is edited. Say for instance adding tags, actors, editing episode descriptions etc? - How is the added actor data saved? How do I ensure its backed up? Is that part of what the server backup plugin does?
