gerritv 4 Posted March 13, 2018 Posted March 13, 2018 I recently added a 32" Samsung M5300 Tv (Tizen) to our house but it has an issue with specific videos. Other devices work fine(LG 55UH6550, Androids and Windows 10 Edge). 2018-03-13 17:18:22.276 Info HttpServer: HTTP POST http://localhost:8096/emby/Sessions/854701e35e17d709fcdc3e228346fcab/Playing?ItemIds=fd85eafe4f4757e64977c2dc6bd76505&PlayCommand=PlayNow. UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; Trident/7.0; rv:11.0) like Gecko 2018-03-13 17:18:22.322 Info HttpServer: HTTP HEAD http://192.168.0.117:8096/videos/fd85eafe4f4757e64977c2dc6bd76505/stream.ts,mpegts?DeviceProfileId=224788e003939ff0644f957b7869156f&DeviceId=uuid:9667b9d1-ab22-4977-8415-faddd4478199&MediaSourceId=fd85eafe4f4757e64977c2dc6bd76505&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=37500000&AudioBitrate=448000&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&RequireAvc=false&Tag=5fd109e432813d78daa6a0c827c978f7&h264-level=41&audiochannels=6&TranscodeReasons=AudioCodecNotSupported&dlnaheaders=true. Host=192.168.0.117:8096, getcontentFeatures.dlna.org=1, getCaptionInfo.sec=1 2018-03-13 17:18:22.322 Error HttpServer: Could not find handler for /videos/fd85eafe4f4757e64977c2dc6bd76505/stream.ts,mpegts 2018-03-13 17:18:22.322 Info HttpServer: HTTP Response 404 to 192.168.0.140. Time: 0ms. http://192.168.0.117:8096/videos/fd85eafe4f4757e64977c2dc6bd76505/stream.ts,mpegts?DeviceProfileId=224788e003939ff0644f957b7869156f&DeviceId=uuid:9667b9d1-ab22-4977-8415-faddd4478199&MediaSourceId=fd85eafe4f4757e64977c2dc6bd76505&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=37500000&AudioBitrate=448000&MaxFramerate=30&MaxWidth=1920&MaxHeight=1080&RequireAvc=false&Tag=5fd109e432813d78daa6a0c827c978f7&h264-level=41&audiochannels=6&TranscodeReasons=AudioCodecNotSupported&dlnaheaders=true 2018-03-13 17:18:22.327 Error HttpClient: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>716</errorCode><errorDescription>Resource not found</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope> 2018-03-13 17:18:22.348 Error HttpServer: Error processing request The TV reportedly does not support AC3, nor mpegts. It says it supports AAC, mkv, ts, h264, h265. I tinkered with User DLNA profile but I am stabbing in the dark with no success. I don't mind if this has to transcode but could use some guidance on the required profile. The file is a .mkv MediaInfo says: Format: Matroska, Video Format: AVC, Coded ID:V_MPEG4, Audio Format: EAC-3, Coded ID:A_EAC3 Gerrit
Luke 42239 Posted March 14, 2018 Posted March 14, 2018 Hi, first, have you located the TV's documentation for supported media formats?
gerritv 4 Posted March 17, 2018 Author Posted March 17, 2018 (edited) Sorry, forgot to set Notifications for this thread :-( Yes, attached is the info from their manual. It says they support containers MKV amongst others, it doesn't mention AVC but does say they support mgep4 (which is the codec according to MediaInfo.) The device doesn't support AC3 so I recoded the file to use AAC, still failed. The same file plays fine on our LG UH6550, Android tablets and Windows 10 devices using Edge browser and Emby Theatre/Apps. Log file for those shows /videos/fd85eafe4f4757e64977c2dc6bd76505/stream.ts (no ,mpegts after the stream.ts) Samsung 32M5300 TV Media Formats.pdf Edited March 17, 2018 by gerritv
Luke 42239 Posted March 18, 2018 Posted March 18, 2018 Actually it looks to me like your device should support it. what is the media info of the file that won't play?
gerritv 4 Posted March 18, 2018 Author Posted March 18, 2018 The full MediaInfo for the file is: General Unique ID : 209696919647509833031323191146399101982 (0x9DC2285DAEDE35368640C6D08467741E) Complete name : C:\Users\xcvxcx\Videos\Outlander\xcvxc s03e07.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 1.11 GiB Duration : 50 min 57 s Overall bit rate mode : Variable Overall bit rate : 3 113 kb/s Encoded date : UTC 2017-10-29 07:21:59 Writing application : mkvmerge v11.0.0 ('Alive') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, RefFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 50 min 57 s Bit rate mode : Variable Bit rate : 2 471 kb/s Maximum bit rate : 4 500 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.112 Stream size : 901 MiB (79%) Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : E-AC-3 Format/Info : Enhanced Audio Coding 3 Codec ID : A_EAC3 Duration : 50 min 57 s Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 187.500 FPS (256 SPF) Compression mode : Lossy Delay relative to video : 2 ms Stream size : 233 MiB (21%) Language : English Service kind : Complete Main Default : Yes Forced : No
Luke 42239 Posted March 18, 2018 Posted March 18, 2018 Can you try something with Ac3 instead of eac3? If everything else is identical then it seems the file should direct play no problem.
gerritv 4 Posted March 18, 2018 Author Posted March 18, 2018 (edited) Nothing with AC3 or E_AC3 will play. Which sadly is most of my video library :-( Do I need to add/change a Response filter to force re-coding AC3 to AAC? This is the output from DeviceSpy, in response to GetProtocolInfo request: http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO http-get:*:image/png:DLNA.ORG_PN=PNG_TN http-get:*:image/png:DLNA.ORG_PN=PNG_SM_ICO http-get:*:image/png:DLNA.ORG_PN=PNG_LRG_ICO http-get:*:image/png:DLNA.ORG_PN=PNG_LRG http-get:*:audio/vnd.dolby.dd-raw:DLNA.ORG_PN=AC3;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=AMR_3GPP;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/3gpp:DLNA.ORG_PN=AMR_WBplus;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/x-sony-oma:DLNA.ORG_PN=ATRAC3plus;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=AAC_LTP_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_MULT5_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=AAC_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L3_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L3_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=BSAC_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/mp4:DLNA.ORG_PN=BSAC_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=8D100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_PAL;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_NTSC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_PAL_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_NTSC_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_ATRAC3plus;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_SP_G726;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_VGA_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_VGA_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_HEAAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_ATRAC3plus;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_HEAAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L5_SO_G726;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_HEAAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L4_SO_G726;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_MP4_P0_L10_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_3GPP_P0_L10_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_CO_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_MPEG2_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_MPEG2_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_CO_MPEG2_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_3GPP_P3_L10_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_HEAAC_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_HEAAC_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_BSAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_BSAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_ATRAC3plus;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3_SD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_HEAAC_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_HEAAC_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L2_CIF30_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_BSAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_940;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_HEAAC_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_HEAAC_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_LTP_520;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L12_CIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L1B_QCIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_CIF30_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_CIF15_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHM_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_MP3;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_EU_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_EU;DLNA.ORG_FLAGS=ED100000000000000000000000000000 http-get:*:image/jpeg:* http-get:*:image/png:* http-get:*:image/bmp:* http-get:*:image/mpo:* http-get:*:audio/mpeg:* http-get:*:audio/x-ms-wma:* http-get:*:audio/mp4:* http-get:*:audio/x-m4a:* http-get:*:audio/3ga:* http-get:*:audio/ogg:* http-get:*:audio/x-wav:* http-get:*:audio/x-flac:* http-get:*:smi/caption:* http-get:*:video/x-msvideo:* http-get:*:video/x-ms-asf:* http-get:*:video/x-divx:* http-get:*:video/x-ms-wmv:* http-get:*:video/x-mkv:* http-get:*:video/quicktime:* http-get:*:video/mp4:* http-get:*:video/hevc:* http-get:*:video/x-avi:* http-get:*:video/avi:* http-get:*:video/x-flv:* http-get:*:video/mpeg:* http-get:*:video/mpeg2:* http-get:*:video/3gpp:* http-get:*:video/webm:* Edited March 19, 2018 by gerritv
gerritv 4 Posted March 19, 2018 Author Posted March 19, 2018 (edited) Solved part of this problem by adding eac3 to the audio codecs in mkv DirectPlay container. The AC3 ones play as well, I had to add mpeg2video to the mkv DirectPlay container. WAF is back to 100% :-) Thank you for a fabulous product, well worth the subscription fee. Edited March 19, 2018 by gerritv
