Luke 42246 Posted May 15, 2018 Posted May 15, 2018 If anyone is available to jump on the beta server that would be helpful. Just be aware that if you do jump up to beta, you cannot switch back to stable, not until the stable channel catches up to changes that are in beta. Thanks.
torinn 3 Posted May 16, 2018 Posted May 16, 2018 (edited) I've upgraded to the latest beta (I think 3.4.1.5?) this morning. Still up three hours later. I'll report back if I can replicate the HTTPS outage. Edit: Probably doesn't merit its own post but we're now ~30h in and still up! Edited May 17, 2018 by torinn 1
jscoys 147 Posted May 18, 2018 Posted May 18, 2018 I've upgraded to the latest beta (I think 3.4.1.5?) this morning. Still up three hours later. I'll report back if I can replicate the HTTPS outage. Edit: Probably doesn't merit its own post but we're now ~30h in and still up! So? Sent from my iPhone using Tapatalk
torinn 3 Posted May 18, 2018 Posted May 18, 2018 So? Sent from my iPhone using Tapatalk I'm unclear on what your question is. Can you elaborate?
jscoys 147 Posted May 18, 2018 Posted May 18, 2018 I'm unclear on what your question is. Can you elaborate? Is the issue solved on your side? Sent from my iPad using Tapatalk
torinn 3 Posted May 18, 2018 Posted May 18, 2018 I think it's more accurate to say "I no longer see the symptoms after patching to 3.4.1.5" than "the issue is solved", but yes, it's now been 48 hours and I can't replicate the misbehavior. I make this clarification because there were ~3 beta patches from the last major release that behaved the same way (see my earlier posts in this thread). I'll continue to patch as I can to the latest beta and provide feedback if this regressed before 3.5.* stable drops. 1
chali 11 Posted May 20, 2018 Posted May 20, 2018 on beta 3.4.1.6 x64 running on x64 ubuntu, im getting: check for plugin updates failed. the ssl connection could not be established, see inner exception. Log ssl.txt Skickat från min SM-G965F via Tapatalk
Luke 42246 Posted May 20, 2018 Posted May 20, 2018 on beta 3.4.1.6 x64 running on x64 ubuntu, im getting: check for plugin updates failed. the ssl connection could not be established, see inner exception. Log ssl.txt Skickat från min SM-G965F via Tapatalk That's different. Your issue, as well as this topic, are both in relation to incoming https. The beta server on linux has upgraded to .NET Core 2.1 and there are some temporary issues with outgoing https that we are looking into, due to changes in the 2.1 runtime. You can follow discussion about that here: https://emby.media/community/index.php?/topic/59007-3414-applicationplugin-updates-failing Thanks. 1
Jdiesel 1437 Posted May 21, 2018 Posted May 21, 2018 I would recommend removing Linux 3.4.1. beta builds until this has been resolved as it is not possible to revert back to .Net 2.0 builds. Not being able to download metadata is a pretty major component that doesn't work right now and users who upgrade to the betas will be disappointed.
neik 874 Posted May 21, 2018 Posted May 21, 2018 @@Jdiesel, I agree on that part but it is possible to downgrade to the latest stable again. Actually, I did it myself! I went from 3.4.1.0 to 3.4.1.6 beta and back to 3.4.1.0 without any issues. Metadata download is working again over here.
Luke 42246 Posted May 21, 2018 Posted May 21, 2018 @@Jdiesel, I agree on that part but it is possible to downgrade to the latest stable again. Actually, I did it myself! I went from 3.4.1.0 to 3.4.1.6 beta and back to 3.4.1.0 without any issues. Metadata download is working again over here. FYI: https://emby.media/community/index.php?/topic/58633-3403-virtualized-paths/&do=findComment&comment=574220 1
Jdiesel 1437 Posted May 21, 2018 Posted May 21, 2018 I would recommend removing Linux 3.4.1. beta builds until this has been resolved as it is not possible to revert back to .Net 2.0 builds. Not being able to download metadata is a pretty major component that doesn't work right now and users who upgrade to the betas will be disappointed. I meant to post this is this thread https://emby.media/community/index.php?/topic/59007-3414-applicationplugin-updates-failing
jscoys 147 Posted May 25, 2018 Posted May 25, 2018 Someone tested with 3.4.1.8? Issue’s solved? Sent from my iPhone using Tapatalk
torinn 3 Posted May 25, 2018 Posted May 25, 2018 I just upgraded from 3.4.1.6. I'll report back tomorrow.
jscoys 147 Posted May 25, 2018 Posted May 25, 2018 Ok thx someone with this issue when trying to upgrade to 3.4.1.8? Sent from my iPad using Tapatalk
torinn 3 Posted May 26, 2018 Posted May 26, 2018 dpkg did the update for me painlessly. We're now 24h in and still stable on 3.4.1.8. HTTPS is up.
jscoys 147 Posted May 26, 2018 Posted May 26, 2018 Thanks for the feedback. So on centos 7 the 3.4.1.6 is ok but the 3.4.1.8 makes my yum crying about the dependencies I described above. Sent from my iPhone using Tapatalk
jscoys 147 Posted May 26, 2018 Posted May 26, 2018 Should be resolved for the next beta. Thanks.Awesome! Sent from my iPhone using Tapatalk
