jscoys 147 Posted April 19, 2018 Posted April 19, 2018 Hum interesting thing. I had the same issue and we tried to debug without success with @@dcrdev 2-3 months ago. Hum first question: is it working with Plex? Did you wait up to 8 hours with Plex to see if it became unresponsive? Other thing, what is your router? Do you have the original firmware on it? Following my issue 2-3 months ago, desperate, I replaced my firmware on my dlink-880l with dd wrt and it works like a charm now. I don’t know if it handle better some connections not closed on Emby side or other issues there, but it solved my issue. Sent from my iPhone using Tapatalk
ElDitcho 0 Posted April 19, 2018 Posted April 19, 2018 here is the log 2018-04-19 09:20:07.043 Info Main: Application path: /opt/emby-server/system/EmbyServer.dll 2018-04-19 09:20:07.052 Info Main: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.119 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system 2018-04-19 09:20:07.230 Info App: Application version: 3.3.1.19 2018-04-19 09:20:07.231 Info App: Loading assemblies 2018-04-19 09:20:07.250 Info App: File /var/lib/emby/plugins/Emby.Server.CinemaMode.dll has version 1.0.0.0 2018-04-19 09:20:07.250 Info App: File /opt/emby-server/system/plugins/Emby.Server.CinemaMode.dll has version 1.0.0.0 2018-04-19 09:20:07.257 Info App: Loading MBBackup, Version=1.2.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/MBBackup.dll 2018-04-19 09:20:07.257 Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.Server.CinemaMode.dll 2018-04-19 09:20:07.257 Info App: Loading statistics, Version=2.0.4.2, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Statistics.dll 2018-04-19 09:20:07.257 Info App: Loading MediaBrowser.Plugins.Anime, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/MediaBrowser.Plugins.Anime.dll 2018-04-19 09:20:07.257 Info App: Loading Emby.Kodi.SyncQueue, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.Kodi.SyncQueue.dll 2018-04-19 09:20:07.257 Info App: Loading MediaBrowser.Api, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading MediaBrowser.WebDashboard, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading MediaBrowser.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading MediaBrowser.Common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading MediaBrowser.Controller, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading MediaBrowser.Providers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading Emby.Photos, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading Emby.Server.Implementations, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading MediaBrowser.LocalMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading MediaBrowser.XbmcMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.257 Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-04-19 09:20:07.387 Info SqliteUserRepository: Sqlite version: 3.23.1 2018-04-19 09:20:07.387 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2018-04-19 09:20:07.414 Info SqliteUserRepository: Default journal_mode for /var/lib/emby/data/users.db is wal 2018-04-19 09:20:07.417 Info SqliteUserRepository: PRAGMA synchronous=1 2018-04-19 09:20:07.428 Info AuthenticationRepository: Default journal_mode for /var/lib/emby/data/authentication.db is wal 2018-04-19 09:20:07.428 Info AuthenticationRepository: PRAGMA synchronous=1 2018-04-19 09:20:07.514 Info DeviceManager: Default journal_mode for /var/lib/emby/data/devices.db is wal 2018-04-19 09:20:07.514 Info DeviceManager: PRAGMA synchronous=1 2018-04-19 09:20:07.536 Info ActivityRepository: Default journal_mode for /var/lib/emby/data/activitylog.db is wal 2018-04-19 09:20:07.537 Info ActivityRepository: PRAGMA synchronous=1 2018-04-19 09:20:07.539 Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/lib/emby/data/displaypreferences.db is wal 2018-04-19 09:20:07.539 Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 2018-04-19 09:20:07.542 Info SqliteItemRepository: Default journal_mode for /var/lib/emby/data/library.db is wal 2018-04-19 09:20:07.542 Info SqliteItemRepository: PRAGMA synchronous=1 2018-04-19 09:20:07.553 Info SqliteNotificationsRepository: Default journal_mode for /var/lib/emby/data/notifications.db is wal 2018-04-19 09:20:07.553 Info SqliteNotificationsRepository: PRAGMA synchronous=1 2018-04-19 09:20:07.783 Info App: Emby.Kodi.SyncQueue IS NOW STARTING!!! 2018-04-19 09:20:07.784 Info App: Emby.Kodi.SyncQueue: Creating DB Repository... 2018-04-19 09:20:07.852 Info App: Emby.Kodi.SyncQueue: SyncAPI Created and Listening at "/Emby.Kodi.SyncQueue/{UserID}/{LastUpdateDT}/GetItems?format=json" - {LastUpdateDT} must be a UTC DateTime formatted as yyyy-MM-ddTHH:mm:ssZ 2018-04-19 09:20:07.852 Info App: Emby.Kodi.SyncQueue: SyncAPI Created and Listening at "/Emby.Kodi.SyncQueue/{UserID}/GetItems?LastUpdateDT={LastUpdateDT}&format=json" - {LastUpdateDT} must be a UTC DateTime formatted as yyyy-MM-ddTHH:mm:ssZ 2018-04-19 09:20:07.852 Info App: Emby.Kodi.SyncQueue: The following parameters also exist to filter the results: 2018-04-19 09:20:07.852 Info App: Emby.Kodi.SyncQueue: filter=movies,tvshows,music,musicvideos,boxsets 2018-04-19 09:20:07.852 Info App: Emby.Kodi.SyncQueue: Results will be included by default and only filtered if added to the filter query... 2018-04-19 09:20:07.852 Info App: Emby.Kodi.SyncQueue: the filter query must be lowercase in both the name and the items... 2018-04-19 09:20:07.926 Info HttpServer: Calling ServiceStack AppHost.Init 2018-04-19 09:20:08.664 Info ServerManager: Loading Http Server 2018-04-19 09:20:08.669 Info HttpServer: Adding HttpListener prefix http://+:8096/ 2018-04-19 09:20:08.669 Info HttpServer: Adding HttpListener prefix https://+:8920/ 2018-04-19 09:20:08.895 Info Skia: SkiaSharp version: 1.58.0.0 2018-04-19 09:20:08.901 Info App: Emby.Kodi.SyncQueue.Task: Retention Task Scheduled! 2018-04-19 09:20:08.930 Info TaskManager: Daily trigger for Configuration Backup set to fire at 20/04/2018 00:10:00, which is 889.85116294 minutes from now. 2018-04-19 09:20:08.931 Info TaskManager: Daily trigger for Calculate statistics for all users set to fire at 20/04/2018 00:00:00, which is 879.851142081667 minutes from now. 2018-04-19 09:20:08.932 Info TaskManager: Daily trigger for Remove Old Sync Data set to fire at 20/04/2018 00:01:00, which is 880.851132006667 minutes from now. 2018-04-19 09:20:08.935 Info TaskManager: Daily trigger for Chapter image extraction set to fire at 20/04/2018 02:00:00, which is 999.851079656667 minutes from now. 2018-04-19 09:20:08.953 Info TaskManager: Daily trigger for Rotate log file set to fire at 20/04/2018 00:00:00, which is 879.850775838333 minutes from now. 2018-04-19 09:20:08.958 Info MediaEncoder: FFMpeg: /opt/emby-server/bin/ffmpeg 2018-04-19 09:20:08.959 Info MediaEncoder: FFProbe: /opt/emby-server/bin/ffprobe 2018-04-19 09:20:08.959 Info MediaEncoder: Validating media encoder at /opt/emby-server/bin/ffmpeg 2018-04-19 09:20:08.961 Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -decoders 2018-04-19 09:20:08.998 Info MediaEncoder: Decoder available: mpeg2video 2018-04-19 09:20:09.003 Info MediaEncoder: Decoder available: h264_cuvid 2018-04-19 09:20:09.003 Info MediaEncoder: Decoder available: hevc_cuvid 2018-04-19 09:20:09.004 Info MediaEncoder: Decoder available: mpeg2_cuvid 2018-04-19 09:20:09.004 Info MediaEncoder: Decoder available: mpeg4_cuvid 2018-04-19 09:20:09.004 Info MediaEncoder: Decoder available: vc1_cuvid 2018-04-19 09:20:09.005 Info MediaEncoder: Decoder available: vp8_cuvid 2018-04-19 09:20:09.006 Info MediaEncoder: Decoder available: vp9_cuvid 2018-04-19 09:20:09.014 Info MediaEncoder: Decoder available: ac3 2018-04-19 09:20:09.014 Info MediaEncoder: Decoder available: aac 2018-04-19 09:20:09.015 Info MediaEncoder: Decoder available: mp3 2018-04-19 09:20:09.015 Info MediaEncoder: Decoder available: h264 2018-04-19 09:20:09.016 Info MediaEncoder: Decoder available: hevc 2018-04-19 09:20:09.025 Info MediaEncoder: Running /opt/emby-server/bin/ffmpeg -encoders 2018-04-19 09:20:09.057 Info MediaEncoder: Encoder available: libx264 2018-04-19 09:20:09.058 Info MediaEncoder: Encoder available: mpeg4 2018-04-19 09:20:09.058 Info MediaEncoder: Encoder available: msmpeg4 2018-04-19 09:20:09.059 Info MediaEncoder: Encoder available: aac 2018-04-19 09:20:09.059 Info MediaEncoder: Encoder available: libmp3lame 2018-04-19 09:20:09.060 Info MediaEncoder: Encoder available: libopus 2018-04-19 09:20:09.060 Info MediaEncoder: Encoder available: libvorbis 2018-04-19 09:20:09.061 Info MediaEncoder: Encoder available: srt 2018-04-19 09:20:09.061 Info MediaEncoder: Encoder available: h264_nvenc 2018-04-19 09:20:09.061 Info MediaEncoder: Encoder available: hevc_nvenc 2018-04-19 09:20:09.064 Info MediaEncoder: Encoder available: h264_vaapi 2018-04-19 09:20:09.064 Info MediaEncoder: Encoder available: hevc_vaapi 2018-04-19 09:20:09.065 Info MediaEncoder: Encoder available: h264_v4l2m2m 2018-04-19 09:20:09.065 Info MediaEncoder: Encoder available: libwebp 2018-04-19 09:20:09.065 Info MediaEncoder: Encoder available: ac3 2018-04-19 09:20:09.066 Info MediaEncoder: Encoder validation complete 2018-04-19 09:20:09.067 Info App: ServerId: b693d914c2614efeb63b3dabdc2b2793 2018-04-19 09:20:09.116 Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint 2018-04-19 09:20:09.117 Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.0008154 seconds 2018-04-19 09:20:09.117 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2018-04-19 09:20:09.276 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.158647 seconds 2018-04-19 09:20:09.276 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2018-04-19 09:20:09.277 Info App: Loading data from /var/lib/emby/data/connect.txt 2018-04-19 09:20:09.282 Info App: Loading data from /var/lib/emby/data/wan.dat 2018-04-19 09:20:09.288 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0125413 seconds 2018-04-19 09:20:09.288 Info App: Core startup complete 2018-04-19 09:20:09.288 Info App: Post-init migrations complete 2018-04-19 09:20:09.288 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-04-19 09:20:09.288 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 4.04E-05 seconds 2018-04-19 09:20:09.288 Info App: Starting entry point MBBackup.ServerEntryPoint 2018-04-19 09:20:09.288 Info App: Entry point completed: MBBackup.ServerEntryPoint. Duration: 3.04E-05 seconds 2018-04-19 09:20:09.288 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-04-19 09:20:09.288 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 2.66E-05 seconds 2018-04-19 09:20:09.288 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2018-04-19 09:20:09.289 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.000334 seconds 2018-04-19 09:20:09.289 Info App: Starting entry point Emby.Kodi.SyncQueue.EntryPoints.LibrarySyncNotification 2018-04-19 09:20:09.291 Info App: Emby.Kodi.SyncQueue: LibrarySyncNotification Startup... 2018-04-19 09:20:09.291 Info App: Entry point completed: Emby.Kodi.SyncQueue.EntryPoints.LibrarySyncNotification. Duration: 0.001814 seconds 2018-04-19 09:20:09.291 Info App: Starting entry point Emby.Kodi.SyncQueue.EntryPoints.UserSyncNotification 2018-04-19 09:20:09.291 Info App: Emby.Kodi.SyncQueue: UserSyncNotification Startup... 2018-04-19 09:20:09.292 Info App: Entry point completed: Emby.Kodi.SyncQueue.EntryPoints.UserSyncNotification. Duration: 0.0009157 seconds 2018-04-19 09:20:09.292 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2018-04-19 09:20:09.292 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 5.57E-05 seconds 2018-04-19 09:20:09.292 Info App: Starting entry point Emby.Server.Implementations.Notifications.Notifications 2018-04-19 09:20:09.295 Info App: Entry point completed: Emby.Server.Implementations.Notifications.Notifications. Duration: 0.003462 seconds 2018-04-19 09:20:09.295 Info App: Starting entry point Emby.Server.Implementations.Notifications.WebSocketNotifier 2018-04-19 09:20:09.296 Info App: Entry point completed: Emby.Server.Implementations.Notifications.WebSocketNotifier. Duration: 0.0004791 seconds 2018-04-19 09:20:09.296 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2018-04-19 09:20:09.296 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0001975 seconds 2018-04-19 09:20:09.296 Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint 2018-04-19 09:20:09.298 Info App: Loading live tv data from /var/lib/emby/data/livetv/timers 2018-04-19 09:20:09.402 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 192.168.1.51 2018-04-19 09:20:09.461 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on fe80::20c:29ff:fee8:886a%2 2018-04-19 09:20:09.540 Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.2439831 seconds 2018-04-19 09:20:09.540 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2018-04-19 09:20:09.566 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.0265326 seconds 2018-04-19 09:20:09.567 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2018-04-19 09:20:09.567 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0002866 seconds 2018-04-19 09:20:09.567 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding 2018-04-19 09:20:09.579 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.0125617 seconds 2018-04-19 09:20:09.579 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2018-04-19 09:20:09.580 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0002005 seconds 2018-04-19 09:20:09.580 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2018-04-19 09:20:09.581 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0009701 seconds 2018-04-19 09:20:09.581 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier 2018-04-19 09:20:09.582 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.0010707 seconds 2018-04-19 09:20:09.582 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2018-04-19 09:20:09.583 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0016058 seconds 2018-04-19 09:20:09.583 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2018-04-19 09:20:09.584 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0006257 seconds 2018-04-19 09:20:09.584 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2018-04-19 09:20:09.584 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0002331 seconds 2018-04-19 09:20:09.584 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint 2018-04-19 09:20:09.588 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0040935 seconds 2018-04-19 09:20:09.589 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint 2018-04-19 09:20:09.589 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.0005921 seconds 2018-04-19 09:20:09.589 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2018-04-19 09:20:09.589 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0001155 seconds 2018-04-19 09:20:09.589 Info App: Starting entry point Emby.Server.Implementations.Devices.DeviceManagerEntryPoint 2018-04-19 09:20:09.590 Info App: Entry point completed: Emby.Server.Implementations.Devices.DeviceManagerEntryPoint. Duration: 0.0009074 seconds 2018-04-19 09:20:09.590 Info App: Starting entry point Emby.Server.Implementations.Collections.CollectionManagerEntryPoint 2018-04-19 09:20:09.592 Info App: Entry point completed: Emby.Server.Implementations.Collections.CollectionManagerEntryPoint. Duration: 0.0022274 seconds 2018-04-19 09:20:09.592 Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint 2018-04-19 09:20:09.594 Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.001149 seconds 2018-04-19 09:20:09.594 Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint 2018-04-19 09:20:09.594 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.0006185 seconds 2018-04-19 09:20:09.594 Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint 2018-04-19 09:20:09.594 Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.000121 seconds 2018-04-19 09:20:09.594 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-04-19 09:20:09.595 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 4.38E-05 seconds 2018-04-19 09:20:09.595 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2018-04-19 09:20:09.604 Info App: Sqlite version: 3.23.1 2018-04-19 09:20:09.604 Info App: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2018-04-19 09:20:09.604 Info App: Default journal_mode for /var/lib/emby/data/sync14.db is wal 2018-04-19 09:20:09.605 Info App: PRAGMA synchronous=1 2018-04-19 09:20:09.607 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.012815 seconds 2018-04-19 09:20:09.607 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2018-04-19 09:20:09.608 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0003555 seconds 2018-04-19 09:20:09.608 Info App: All entry points have started 2018-04-19 09:20:09.923 Info LibraryMonitor: Watching directory /jarvis/video/AnimeMovies 2018-04-19 09:20:09.929 Info HttpClient: GET https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2018-04-19 09:20:10.129 Info LibraryMonitor: Watching directory /jarvis/video/TV Shows 2018-04-19 09:20:10.427 Info LibraryMonitor: Watching directory /jarvis/video/AnimeTv 2018-04-19 09:20:11.942 Info TaskManager: StartupTrigger fired for task: Check for plugin updates 2018-04-19 09:20:11.944 Info TaskManager: Queueing task PluginUpdateTask 2018-04-19 09:20:11.948 Info TaskManager: Executing Check for plugin updates 2018-04-19 09:20:11.952 Info TaskManager: StartupTrigger fired for task: Check for application updates 2018-04-19 09:20:11.952 Info TaskManager: Queueing task SystemUpdateTask 2018-04-19 09:20:11.952 Info TaskManager: Executing Check for application updates 2018-04-19 09:20:11.967 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2018-04-19 09:20:11.969 Info HttpClient: GET https://api.github.com/repos/MediaBrowser/Emby.Releases/releases 2018-04-19 09:20:12.325 Info LibraryMonitor: Watching directory /jarvis/video/Movies 2018-04-19 09:20:13.155 Info TaskManager: Check for application updates Completed after 0 minute(s) and 1 seconds 2018-04-19 09:20:13.171 Info TaskManager: ExecuteQueuedTasks 2018-04-19 09:20:13.210 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 1 seconds 2018-04-19 09:20:13.210 Info TaskManager: ExecuteQueuedTasks 2018-04-19 09:20:37.702 Info HttpServer: HTTP GET https://dummyurl:8920/. UserAgent: curl/7.47.0 2018-04-19 09:20:37.704 Info HttpServer: HTTP Response 302 to 127.0.0.1. Time: 3ms. https://dummyurl:8920/ 2018-04-19 09:25:19.718 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 3.3.1.19 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.119 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Security.Authentication.AuthenticationException: A call to SSPI failed, see inner exception. ---> Interop+OpenSsl+SslException: SSL Handshake failed with OpenSSL error - SSL_ERROR_SSL. ---> Interop+Crypto+OpenSslCryptographicException: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown --- End of inner exception stack trace --- at Interop.OpenSsl.DoSslHandshake(SafeSslHandle context, Byte[] recvBuf, Int32 recvOffset, Int32 recvCount, Byte[]& sendBuf, Int32& sendCount) at System.Net.Security.SslStreamPal.HandshakeInternal(SafeFreeCredentials credential, SafeDeleteContext& context, SecurityBuffer inputBuffer, SecurityBuffer outputBuffer, Boolean isServer, Boolean remoteCertRequired) --- End of inner exception stack trace --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsServer(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpConnection.<Init>d__30.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__27.MoveNext() System.Security.Authentication.AuthenticationException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsServer(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpConnection.<Init>d__30.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__27.MoveNext() InnerException: Interop+OpenSsl+SslException Interop+OpenSsl+SslException: SSL Handshake failed with OpenSSL error - SSL_ERROR_SSL. ---> Interop+Crypto+OpenSslCryptographicException: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown --- End of inner exception stack trace --- at Interop.OpenSsl.DoSslHandshake(SafeSslHandle context, Byte[] recvBuf, Int32 recvOffset, Int32 recvCount, Byte[]& sendBuf, Int32& sendCount) at System.Net.Security.SslStreamPal.HandshakeInternal(SafeFreeCredentials credential, SafeDeleteContext& context, SecurityBuffer inputBuffer, SecurityBuffer outputBuffer, Boolean isServer, Boolean remoteCertRequired) at Interop.OpenSsl.DoSslHandshake(SafeSslHandle context, Byte[] recvBuf, Int32 recvOffset, Int32 recvCount, Byte[]& sendBuf, Int32& sendCount) at System.Net.Security.SslStreamPal.HandshakeInternal(SafeFreeCredentials credential, SafeDeleteContext& context, SecurityBuffer inputBuffer, SecurityBuffer outputBuffer, Boolean isServer, Boolean remoteCertRequired) InnerException: Interop+Crypto+OpenSslCryptographicException Interop+Crypto+OpenSslCryptographicException: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown Hum interesting thing. I had the same issue and we tried to debug without success with @@dcrdev 2-3 months ago.Hum first question: is it working with Plex? Did you wait up to 8 hours with Plex to see if it became unresponsive?Other thing, what is your router? Do you have the original firmware on it?Following my issue 2-3 months ago, desperate, I replaced my firmware on my dlink-880l with dd wrt and it works like a charm now. I don’t know if it handle better some connections not closed on Emby side or other issues there, but it solved my issue.Sent from my iPhone using Tapatalk For my part, there is no plex and using the router of my provider.
jscoys 147 Posted April 19, 2018 Posted April 19, 2018 Ok forget my message, I’m having the same issue with 3.3.1.19... let’s @@Luke checking. Sent from my iPhone using Tapatalk
jscoys 147 Posted April 19, 2018 Posted April 19, 2018 Can we have a status on it? Every time I wanna watch something I have to restart my Emby-Server service... Sent from my iPhone using Tapatalk
Luke 42246 Posted April 19, 2018 Posted April 19, 2018 Can we have a status on it? Every time I wanna watch something I have to restart my Emby-Server service... Sent from my iPhone using Tapatalk Have you provided the information requested in how to report a problem? Thanks.
jscoys 147 Posted April 19, 2018 Posted April 19, 2018 here we are: https://expirebox.com/download/24a7d21e5879bddbfed29d46efde3a1c.html for your info the 3.3.1.17 seems working, i downgraded to this version 2 hours ago and its working.
jscoys 147 Posted April 20, 2018 Posted April 20, 2018 let’s try again ;-) https://expirebox.com/download/bd0d6564b35d61c13b1b6f3827597877.html
jscoys 147 Posted April 20, 2018 Posted April 20, 2018 Little word to say I don’t have the issue with the .20 so I guess it’s fixed. Sent from my iPhone using Tapatalk
ElDitcho 0 Posted April 22, 2018 Posted April 22, 2018 Just passed on the .21 and it's worse ^^ i have some "Error processing request" but does not seems related. https://pastebin.com/7fHqELUj
Luke 42246 Posted April 22, 2018 Posted April 22, 2018 Just passed on the .21 and it's worse ^^ i have some "Error processing request" but does not seems related. https://pastebin.com/7fHqELUj Hi, please keep beta discussion in the Testing Area section of the community. However, just to address this - there are no problems in this log.
ElDitcho 0 Posted April 22, 2018 Posted April 22, 2018 Hi, please keep beta discussion in the Testing Area section of the community. However, just to address this - there are no problems in this log. ok thx
jscoys 147 Posted April 24, 2018 Posted April 24, 2018 Do you have the link for the entry in Beta section? Personally I still have the issue Sent from my iPhone using Tapatalk
jscoys 147 Posted May 3, 2018 Posted May 3, 2018 Sooooo on Yesterday it wasn’t working well, today it is. Accessed from https through browsers is working well with .28 today, so we can close the point. Something I notice is that through https I have sometimes issues but not through native apps on devices like iOS app or android app... I guess you use different technology to connect from them? Sent from my iPhone using Tapatalk
jscoys 147 Posted May 8, 2018 Posted May 8, 2018 I don’t know why but I’m so desperate of the web access to my Emby server... it’s not loading correctly from safari on iOS, I have to refresh the page several times... but on the native iOS app it’s working nicely... Luke how do you handle differently the access from web browsers compared to native apps? Sent from my iPhone using Tapatalk
Luke 42246 Posted May 9, 2018 Posted May 9, 2018 Well the web app has to download both the web app files as well as your emby data. I've seen this with older versions of ios, for instance i have a tablet still on ios9 which i use for old device testing. Sometimes on initial load of the web app i have to refresh the page a couple times. I do not see this with ios 10 and above.
neik 874 Posted May 9, 2018 Posted May 9, 2018 I think I am having the same problem as described in post #1 with 3.4.0.0. After a random amount of time I can't access Emby anymore using https. It does not matter how I try to access it (WebUI, Emby for Kodi, Emby for Android) always the same result. Interesting enough Emby doesn't even write anything into the logfile it looks like it is freezed and doesn't respond to queries. Gonna update to latest stable but anyways I would appreciate any hint.
Luke 42246 Posted May 9, 2018 Posted May 9, 2018 I think I am having the same problem as described in post #1 with 3.4.0.0. After a random amount of time I can't access Emby anymore using https. It does not matter how I try to access it (WebUI, Emby for Kodi, Emby for Android) always the same result. Interesting enough Emby doesn't even write anything into the logfile it looks like it is freezed and doesn't respond to queries. Gonna update to latest stable but anyways I would appreciate any hint. We already have a topic where we are trying to help you. Right now you are posting the same thing in multiple places and that's actually going to make it harder for us to help you.
torinn 3 Posted May 13, 2018 Posted May 13, 2018 (edited) I'm still seeing this behavior on 3.4.1.0 stable. Many tcp connections in the CLOSE_WAIT state with an internal host chatting over HTTPS (specifically a Samsung TV running the Emby app). Bouncing the service sorts the issue out for a spell, and then we're right back to it. Here's the "How to report a problem" bits as best I can provide them: - First version where this issue was observed: Emby Server 3.3.1.0 - Tried on various beta builds from 3.3.1.*, as well at 3.4.0.0 - Current version: Emby Server 3.4.1.0 - OS: Debian 9.4 - Clients and network location, in order of frequency: Internal web browser, internal Samsung app, external android app, external Chrome browser - Applications accessing the server over the API: Ombi (request portal) - HTTPS Certificate provider: Letsencrypt - HTTPS port: 8920 (default) - Last restart: 01:22 AM UTC 2018-05-12 - Description of behavior: "At some time after starting the emby-server service internal and external HTTPS traffic hangs. After this time HTTP access remains operational (though practically this downs the application as I only use HTTP for diagnostic testing for security reasons). I observe many CLOSE_WAIT connections in the output of netstat when this behavior presents itself. Restarting the emby-server service temporarily resolves this behavior." Server Logs in full are somewhat burdensome to share (220k lines when HTTPS goes down on 2018-05-12 and another 198k lines from today, 68M of data across the two files). Trimming around the last few instances of <DNS-record>:<HTTPS port> occurs: #First (and only) cluster of errors in the logs before HTTPS fails 2018-05-12 00:00:05.393 Error FileSystem: Error determining LastAccessTimeUtc for /mnt/nas/media/TV/House/Season 1/House 01x18 - Babies & Bathwater.avi *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.9.0.3 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.ArgumentOutOfRangeException: Valid values are between -62135596800 and 253402300799, inclusive. Parameter name: seconds at System.DateTimeOffset.FromUnixTimeSeconds(Int64 seconds) at System.IO.FileSystemInfo.System.IO.IFileSystemObject.get_LastWriteTime() at System.IO.FileSystemInfo.get_LastWriteTimeUtc() at Emby.Server.Implementations.IO.ManagedFileSystem.GetLastWriteTimeUtc(FileSystemInfo info) System.ArgumentOutOfRangeException at System.DateTimeOffset.FromUnixTimeSeconds(Int64 seconds) at System.IO.FileSystemInfo.System.IO.IFileSystemObject.get_LastWriteTime() at System.IO.FileSystemInfo.get_LastWriteTimeUtc() at Emby.Server.Implementations.IO.ManagedFileSystem.GetLastWriteTimeUtc(FileSystemInfo info) #Last hit for "https://emby.torinn.xyz:8920" in logs 2018-05-12 06:57:50.125 Info HttpServer: HTTP Response 204 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/Sessions/Playing/Progress 2018-05-12 06:58:00.125 Info HttpServer: HTTP POST https://emby.torinn.xyz:8920/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-12 06:58:00.126 Info HttpServer: HTTP Response 204 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/Sessions/Playing/Progress 2018-05-12 06:58:10.126 Info HttpServer: HTTP POST https://emby.torinn.xyz:8920/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-12 06:58:10.127 Info HttpServer: HTTP Response 204 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/Sessions/Playing/Progress 2018-05-12 06:58:20.125 Info HttpServer: HTTP POST https://emby.torinn.xyz:8920/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-12 06:58:20.126 Info HttpServer: HTTP Response 204 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/Sessions/Playing/Progress 2018-05-12 06:58:30.125 Info HttpServer: HTTP POST https://emby.torinn.xyz:8920/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-12 06:58:30.126 Info HttpServer: HTTP Response 204 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/Sessions/Playing/Progress 2018-05-12 06:58:40.126 Info HttpServer: HTTP POST https://emby.torinn.xyz:8920/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-12 06:58:40.126 Info HttpServer: HTTP Response 204 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/Sessions/Playing/Progress 2018-05-12 06:58:50.125 Info HttpServer: HTTP POST https://emby.torinn.xyz:8920/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-12 06:58:50.126 Info HttpServer: HTTP Response 204 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/Sessions/Playing/Progress 2018-05-12 06:59:00.126 Info HttpServer: HTTP POST https://emby.torinn.xyz:8920/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-12 06:59:00.127 Info HttpServer: HTTP Response 204 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/Sessions/Playing/Progress 2018-05-12 06:59:10.126 Info HttpServer: HTTP POST https://emby.torinn.xyz:8920/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-12 06:59:10.127 Info HttpServer: HTTP Response 204 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/Sessions/Playing/Progress 2018-05-12 06:59:20.128 Info HttpServer: HTTP POST https://emby.torinn.xyz:8920/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-12 06:59:20.129 Info HttpServer: HTTP Response 204 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/Sessions/Playing/Progress 2018-05-12 07:05:01.736 Info HttpServer: HTTP GET http://emby.torinn.xyz:8096/emby/users/89719bdb5d1245e0b30c1da111c03322/items?Recursive=True&IncludeItemTypes=Movie. UserAgent: Ombi 2018-05-12 07:05:01.760 Info HttpServer: HTTP Response 200 to 10.0.0.20. Time: 25ms. http://emby.torinn.xyz:8096/emby/users/89719bdb5d1245e0b30c1da111c03322/items?Recursive=True&IncludeItemTypes=Movie 2018-05-12 07:05:01.764 Info HttpServer: HTTP GET http://emby.torinn.xyz:8096/emby/users/89719bdb5d1245e0b30c1da111c03322/items/01422d2977b063a1d4d75ed7853d8ee5. UserAgent: Ombi #First errors after HTTPS traffic stops 2018-05-12 09:25:00.423 Error FileSystem: Error determining LastAccessTimeUtc for /mnt/nas/media/TV/House/Season 2/House - 02x02 - Autopsy.avi *** Error Report *** Version: 3.4.1.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.9.0.3 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.ArgumentOutOfRangeException: Valid values are between -62135596800 and 253402300799, inclusive. Parameter name: seconds at System.DateTimeOffset.FromUnixTimeSeconds(Int64 seconds) at System.IO.FileSystemInfo.System.IO.IFileSystemObject.get_LastWriteTime() at System.IO.FileSystemInfo.get_LastWriteTimeUtc() at Emby.Server.Implementations.IO.ManagedFileSystem.GetLastWriteTimeUtc(FileSystemInfo info) System.ArgumentOutOfRangeException at System.DateTimeOffset.FromUnixTimeSeconds(Int64 seconds) at System.IO.FileSystemInfo.System.IO.IFileSystemObject.get_LastWriteTime() at System.IO.FileSystemInfo.get_LastWriteTimeUtc() at Emby.Server.Implementations.IO.ManagedFileSystem.GetLastWriteTimeUtc(FileSystemInfo info) #No other errors throughout the logs that don't match "Error determining LastAccessTimeUtc" As the errors mention System.IO and Filesystem I figure it's also worth mentioning these files are shared via a CIFS mount configured in /etc/fstab. Log times are in EST, so the gap roughly maps to 12:00:00 UTC (10h 38m after service restart). Edited May 13, 2018 by torinn 1
Luke 42246 Posted May 13, 2018 Posted May 13, 2018 Hi there, can you please attach the complete emby server log? Thanks !
torinn 3 Posted May 13, 2018 Posted May 13, 2018 (edited) Attached is the full 2018-05-12 log that was excerpted in my previous post Log.txt Edited May 13, 2018 by torinn
Luke 42246 Posted May 13, 2018 Posted May 13, 2018 I don't see any incoming https traffic in this log. Have you even configured https connectivity in Emby?
torinn 3 Posted May 13, 2018 Posted May 13, 2018 An example HTTP POST transaction to emby.torinn.xyz:8920 over the HTTPS protocol: 2018-05-12 06:59:20.128 Info HttpServer: HTTP POST https://emby.torinn.xyz:8920/Sessions/Playing/Progress. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-12 06:59:20.129 Info HttpServer: HTTP Response 204 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/Sessions/Playing/Progress The response sent to the client (10.0.0.50) was a 204. I just generated these transactions (I've restarted the service as I wanted to watch something): 2018-05-13 19:08:50.951 Info HttpServer: HTTP GET https://emby.torinn.xyz:8920/web/strings/en-US.json?v=1526252921483. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-13 19:08:50.953 Info HttpServer: HTTP Response 200 to 10.0.0.50. Time: 2ms. https://emby.torinn.xyz:8920/web/strings/en-US.json?v=1526252921483 2018-05-13 19:08:50.954 Info HttpServer: HTTP GET https://emby.torinn.xyz:8920/web/bower_components/emby-webcomponents/strings/en-us.json?v=1526252921483. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-13 19:08:50.955 Info HttpServer: HTTP Response 200 to 10.0.0.50. Time: 1ms. https://emby.torinn.xyz:8920/web/bower_components/emby-webcomponents/strings/en-us.json?v=1526252921483 2018-05-13 19:08:51.285 Info HttpServer: HTTP GET https://emby.torinn.xyz:8920/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.139 Safari/537.36 2018-05-13 19:08:51.285 Info HttpServer: HTTP Response 200 to 10.0.0.50. Time: 0ms. https://emby.torinn.xyz:8920/emby/system/info/public Looks like HTTPS to me
