ZiggyDubz 7 Posted March 12, 2018 Posted March 12, 2018 (edited) I finally, with the help of a friend (I have ZERO Linux experience) have set up Emby server on my R-Pi. I have it so it can read the drive I have plugged in (finally) and I have the folders associated with the appropriate movies, tv shows, music, etc. Everything works (Meta data shows, I can edit titles so it gets the proper meta data; the whole shabang) exactly as it did when I ran emby server on Windows 10, except when I go to play a video or song, it gives me this: "Playback Error - No compatible streams are currently available. Please try again later or contact your system administrator for details."I thought it could be a codec problem? I downloaded VLC to it and it will open the movie files, but barely play them. I figured the playback device did all the work and it was just drawing the actual movie file from the R-Pi, but perhaps the R-Pi is the thing doing all the work (and isn't powerful enough to do so?) WHAT DO I DO?Please and thanks. I appreciate it. Edited March 12, 2018 by Skvli
mastrmind11 722 Posted March 13, 2018 Posted March 13, 2018 I finally, with the help of a friend (I have ZERO Linux experience) have set up Emby server on my R-Pi. I have it so it can read the drive I have plugged in (finally) and I have the folders associated with the appropriate movies, tv shows, music, etc. Everything works (Meta data shows, I can edit titles so it gets the proper meta data; the whole shabang) exactly as it did when I ran emby server on Windows 10, except when I go to play a video or song, it gives me this: "Playback Error - No compatible streams are currently available. Please try again later or contact your system administrator for details." I thought it could be a codec problem? I downloaded VLC to it and it will open the movie files, but barely play them. I figured the playback device did all the work and it was just drawing the actual movie file from the R-Pi, but perhaps the R-Pi is the thing doing all the work (and isn't powerful enough to do so?) WHAT DO I DO? Please and thanks. I appreciate it. Sounds like your media is being trancoded and the pi is not the machine you want for that. You need all your stuff in direct play format, and a bitrate that fits within your network profile's bandwidth. Post the server and transcode logs here and we can take a look.
ZiggyDubz 7 Posted March 13, 2018 Author Posted March 13, 2018 Where do I find said logs, and how do I post them? 1
tdiguy 99 Posted March 13, 2018 Posted March 13, 2018 I find the easiest way to get logs is to log into the emby server from a different machine and go to the emby admin dashboard. This is where you add libraries and such. Further down on the left side should be a selection for log files.
Luke 42245 Posted March 13, 2018 Posted March 13, 2018 How to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
ZiggyDubz 7 Posted March 13, 2018 Author Posted March 13, 2018 Here is one of the Transcode Logs:2018-03-12 19:03:12.862Application version: 3.3.0.0http://192.168.181.192:8096/emby/videos/8bd8ee6b1b1eeffdaf94eaba55cc9b30/live.m3u8?DeviceId=aec8938656ad74810ea8bbc92ebe191e21bd3e9e&MediaSourceId=8bd8ee6b1b1eeffdaf94eaba55cc9b30&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=139808000&AudioBitrate=192000&PlaySessionId=57c4a466d35c4b8fb79be8410a380331&api_key=295234b985a948e49cbc71c08b21f3ca&TranscodingMaxAudioChannels=2&RequireAvc=true&Tag=c111b16884be524c2678418f8501d078&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=51&h264-deinterlace=true&allowVideoStreamCopy=false&allowAudioStreamCopy=false{"Protocol":"File","Id":"8bd8ee6b1b1eeffdaf94eaba55cc9b30","Path":"/media/pi/WallaceMedia/Emby/Movies/10 Cloverfield Lane.mkv","Type":"Default","Container":"mkv","Name":"10 Cloverfield Lane.mkv","IsRemote":false,"ETag":"c111b16884be524c2678418f8501d078","ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[],"Formats":[],"RequiredHttpHeaders":{}}User policy for Zak: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True/opt/emby-server/bin/ffmpeg -f matroska -i file:"/media/pi/WallaceMedia/Emby/Movies/10 Cloverfield Lane.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 139808000 -bufsize 279616000 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -flags -global_header -vsync -1 -codec:a:0 libmp3lame -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/f48a0d3a4fc50024bb8a981239dbf103/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/lib/emby/transcoding-temp/f48a0d3a4fc50024bb8a981239dbf103.m3u8" -y "/var/lib/emby/transcoding-temp/f48a0d3a4fc50024bb8a981239dbf103%d.ts"ffmpeg version 3.4.2 Copyright © 2000-2018 the FFmpeg developersbuilt with gcc 6.4.1 (Linaro GCC 6.4-2017.08) 20170707configuration: --enable-cross-compile --cross-prefix=arm-linux-gnueabihf- --cc=arm-linux-gnueabihf-gcc --cxx=arm-linux-gnueabihf-gcc --arch=armv7h --prefix=/srv/buildbot/armhf/ffmpeg-armhf/staging --pkg-config=pkg-config --disable-cuda --disable-cuvid --disable-iconv --disable-nvenc --disable-doc --disable-ffplay --disable-ffserver --disable-xlib --enable-fontconfig --enable-gpl --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --extra-libs='-ldl -lexpat -lfreetype -lfribidi -lfontconfig -lpng -lgmp -lhogweed -lnettle -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4' --target-os=linux --enable-shared --disable-static --enable-gnutls --enable-libsmbclientlibavutil 55. 78.100 / 55. 78.100libavcodec 57.107.100 / 57.107.100libavformat 57. 83.100 / 57. 83.100libavdevice 57. 10.100 / 57. 10.100libavfilter 6.107.100 / 6.107.100libswscale 4. 8.100 / 4. 8.100libswresample 2. 9.100 / 2. 9.100ffmpeg version 3.4.2 Copyright © 2000-2018 the FFmpeg developersffmpeg version 3.4.2 Copyright © 2000-2018 the FFmpeg developerslibpostproc 54. 7.100 / 54. 7.100
ZiggyDubz 7 Posted March 13, 2018 Author Posted March 13, 2018 The Server log is too long to post. It keeps erroring out haha.
harrv 90 Posted April 3, 2018 Posted April 3, 2018 How to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks. The Server log is too long to post. It keeps erroring out haha. The link Luke gave you already has at least three suggestions (near the bottom of the page) for how to share a large log file.
