Wheemer 50 Posted March 10, 2018 Posted March 10, 2018 Local client connecting through chrome and no video is displayed, only audio. Tried many different sources. This is using direct play. I'm running the latest beta of Emby Server. Any help would be great, this might have stopped working after the latest update or two.
Luke 42208 Posted March 10, 2018 Posted March 10, 2018 Hi there @@Wheemer, please discuss an example and attach the information requested in how to report a media playback issue. thanks.
Wheemer 50 Posted March 10, 2018 Author Posted March 10, 2018 It is because the video are being transcoded when I do not want that to happen. When I edit the user to disable transcoding it will not play audio but the video plays fine. I do not believe it was transcoding anything before when it was working. Why is it transcoding direct streams? I have users using emby right now so I will submit a log later when the server is not in use. But the problem seems that it should not be transcoding anything when playback is local through windows 10 chrome clients.
Luke 42208 Posted March 10, 2018 Posted March 10, 2018 Again I would need to look at the above requested information in order to provide any kind of assessment. Thanks.
Wheemer 50 Posted March 10, 2018 Author Posted March 10, 2018 Transcoding turned off and no audio through chrome win 10 server-63656238627.txt
Wheemer 50 Posted March 10, 2018 Author Posted March 10, 2018 I just get aq playback error in firefox and nothing works at all. server-63656238627.txt
Luke 42208 Posted March 11, 2018 Posted March 11, 2018 @@Wheemer, you disabled user permissions to transcoding. You're getting exactly what you asked for. 2018-03-10 00:37:42.721 Info App: User policy for Mom Dad. EnablePlaybackRemuxing: False EnableVideoPlaybackTranscoding: False EnableAudioPlaybackTranscoding: False Here you're trying to play an mkv, Firefox does not support mkv.
Wheemer 50 Posted March 11, 2018 Author Posted March 11, 2018 OK so firefox is out, so why is it that it needs to be transcoded to playback in Chrome, my original problem? My Emby server is running on not the best hardware and since I am only streaming locally with direct play, I had assumed it should be able to play without any transcoding. Which is how I thought it had been working fine for a long time, until recently.
Luke 42208 Posted March 11, 2018 Posted March 11, 2018 What is the media info of the video as seen in the web app?
Wheemer 50 Posted March 11, 2018 Author Posted March 11, 2018 1080p H264 and ENG Dolby Digital+ 5.1 Default The one minute playback works in Theater.
Luke 42208 Posted March 11, 2018 Posted March 11, 2018 Chrome does not support Dolby Digital. As you can see we have done all of the work to make this easy for you. All you need to do is trust the default settings. Thanks. 1
