Error when using Emby live tv recordings as widget
Go to solution Solved by Angelblue05,
Since I switched from the DVBlink plugin to native use of my HDhomerun tuner in Emby I can’t use the pvr widget because it is no longer in use. So i have set the widget to Emby live tv recording (experimental).
I know it is experimental but is that the only reason for this error?
the log says something about a memory leak.
when the error message is gone It works just fine.
Thanks
.kodi.log
Edited by heula
  • Solution
Angelblue05
This experimental feature has been disabled with 3.x.x version. It is not coming back.
I revamped playback completely to remove certain workarounds and update for the new Kodi and Emby api and I don't have the time nor Live TV to maintain that feature (it was added by Marcelveldt).
When it is added, it will be a separate entity to Emby for Kodi.
Thanks for reminding me I should remove the dynamic shortcuts.
Edited by Angelblue05
Okay thanks.
Guest
