mastrmind11
But he's playing h264 movies, not VC1
Codec tagavc1
AVCYes
I'llgo try and find a VC1 sample online somewhere.
Vc1 files normally would have a vc1 extension though not mp4
Sent from my SM-G900P using Tapatalk
Guest asrequested
Codec tagavc1
AVCYes
If he looks at the details in the web app or Android mobile app, it'll say h264
mastrmind11
ok.  lets settle this.  @@tdiguy, cut a 1 min sample and put it up.
mastrmind11
sample.  video.  solves.  this.  debate.
Guest asrequested
Lol...a sample would be good for us to test, too.
Edited by Doofus
This is the 1 min sample. It plays fine for me for some reason.
I had to zip it to upload. this is the media info
Media Info
Video
CodecH264
Codec tagavc1
AVCYes
ProfileMain
Level41
Resolution960x540
Aspect ratio16:9
AnamorphicNo
InterlacedNo
Framerate30
Bitrate560 kbps
Bit depth8 bit
Pixel formatyuv420p
Ref frames1
NAL4
Title480P H264
Audio
Languageeng
CodecAAC
Codec tagmp4a
ProfileLC
Layout4.0
Channels4 ch
Bitrate128 kbps
Sample rate44100 Hz
DefaultYes
TitleEng AAC 4.0 Default
Containermp4
Path/test/101 Dalmations-1.mp4
101 Dalmations-1.zip
mastrmind11
it's tiny, make it 5-10 mins for a real test since your other one failed around the 1 min mark.  post it or test locally, and we'll check your sample (others will beat me since I'm on my way out for the night).
Guest asrequested
I'll be able to check it when I get off work, in a few hours.
The original did not play at all. It made attempts to play for a minute but never did.
With DLNA now turned on and trying to play using vlc the original fails right off the bat while the 1 min version plays fine.
Edited by tdiguy
Guest asrequested
I wonder if it's a container issue. Try giving it a quick remux.
mastrmind11
seriously, just post a sample for us to try.  it's family friendly, and if not, I won't judge.
I did. post #34
It either loads or it doesnt for some reason the 1 min sample loads fine but the full movie does not load at all.
Edited by tdiguy
mastrmind11
I did. post #34
Thats my point.  If it loads on yours, it will loadon mine and everyone elses. Make it longer so we can rule out environment... need to get to playing it.
Edited by mastrmind11
Guest asrequested
Even better, depending on it's full size, can you throw it on a cloud drive and share the link? If it's only a few gigs, that is. Then we can truly test.
Lol I will have to see if i have enough room on one of my cloud accounts.
I really should look into scaling this thing down, 2 hours and its 5.5gigs.
Edited by tdiguy
Guest asrequested
The reason I suggested that, was because then we can use the exact file that you are. Even lopping off a piece I will cause a container remodel. So Mastermind's suggestion is good. If you lop off a big chunk, test it, if it plays, sharing it will be redundant. At that point, we'll need the whole thing.
Its currently uploading to dropbox. ETA 2 hours ( 5 meg upload speed :()
I am going to also scale it down 5 gigs is huge for my movies most are 1 gig or so. Except my wifes old movies which are like 3 or 4 hours long also lol.
Guest asrequested
Lol... I suspect that once you transcode it, you won't have any issues playing it. I think the largest movie I've got is around 70GB :)
OFFS I scaled it down a little bit ( now at 3.5 gig ) and it plays, takes a little bit to load but it plays now.
Something must have been off on it. What i dont get is that i have a program on my laptop i used for nearly all the movies in my collection and i used the same profile for all of them. I think this one and like 2 other movies gave me problems.
My wifes movies are significantly larger in play time and file size.
clarkss12
After you scaled it down,what the codecs show?
Guest asrequested
I have a feeling it was how they were muxed. Sometimes slight errors can occur. So then some players will be able to split them easily, and others might have issues.
Guest asrequested
And for the curious minded, here's the difference between H264 and VC1. Here's the same movie in each of those codecs
VC1
H264
Edited by Doofus
