wp.rauchholz 5 Posted March 8, 2018 Posted March 8, 2018 I run emmby server latest version and have a SAMSUNG TV UE40ES8000, emby app 2.2.4 I cannot watch channel anymore. Once selected the screen shows loading, but does not go any further than hjtat. Thanks for looking otnto this Wolfgang ffmpeg-directstream-68abbb9c-7a3e-415a-8756-369bcc9ac78c.txt ffmpeg-transcode-2124dde6-1de8-47c7-960d-21d9b5d79118.txt record-transcode-f6535e25-74b4-49ce-8909-e24774c26fa8.txt server-63656064000.txt
Luke 42241 Posted March 8, 2018 Posted March 8, 2018 Try turning off the recording conversion feature.
wp.rauchholz 5 Posted March 8, 2018 Author Posted March 8, 2018 I did turn this off. Still not working
Luke 42241 Posted March 8, 2018 Posted March 8, 2018 What you could also try is lowering the in app quality setting to force a full transcode.
wp.rauchholz 5 Posted March 16, 2018 Author Posted March 16, 2018 Which exact parameter are you referring to? Attached screenshot of log file. I can watch this same channel on my laptop, unfortunately not in emby app of SAMSUNG. Wolfgang
FrostByte 5453 Posted March 16, 2018 Posted March 16, 2018 There should be a setting to lower the quality / bitrate under "TV Settings"
wp.rauchholz 5 Posted March 16, 2018 Author Posted March 16, 2018 (edited) No change, it set lowest possible value of 0,5 MB/d. I have 2 TV sets, one runs on 2.2.3 and the other on 2.2.4. The problem is the same on both. It worked fine, I did not change the config and it stopped working Wolfgang Edited March 16, 2018 by wp.rauchholz
Luke 42241 Posted March 16, 2018 Posted March 16, 2018 Can you please attach the log anyway so that we can review? thanks.
wp.rauchholz 5 Posted March 16, 2018 Author Posted March 16, 2018 Here are two files. There is another issue that happens form time to time and happened just now. When using Samsung app and the iPad, emby crashes sometimes. Maybe there is a hint inthe file why this happens server-63656804584.txt server-63656817154.txt
Luke 42241 Posted March 16, 2018 Posted March 16, 2018 Ok, keep in mind for your model TV this is a community maintained app. Perhaps @@SamES can try to reproduce the live tv playback failure. thanks.
SamES 1084 Posted March 17, 2018 Posted March 17, 2018 Development of Live TV was never officially competed or released for this app. It was only available in the beta release for devt testing. Once development ended it was not initially included in the release, but eventually it was added back to 2.2.3 for those that had used on the basis of it being unfinished work. I expect if I was to start looking at the code we would find more than a few things that need work. https://emby.media/community/index.php?/topic/31461-emby-for-samsung-release-notes-tizen-orsay/ 1
