Playback stops after first track with Jongo A2
Hi,
I'm a new user trying to set-up Emby to replace an existing Squeezebox (Audio) & Kodi (Video) set-up. Any assistance would be appreciated!
I'm attempting to play an album, via the Emby web UI, rendering to a Pure Jongo A2. The first track always plays fine, after which it stops. There are multiple exceptions in the logs however I'm unclear if the problem is caused by the Jongo or Emby; a search through the forums hasn't turned up an existing issue.
Log following a restart with DLNA debug logging turned on is attached.
Potentially relevant info:
Server: Ubuntu 14.04.5 64-bit, 8GB RAM, Intel® Xeon® CPU E3-1225 v3 @ 3.20GHz
Emby version: 3.3.0.0
Source audio files: FLAC
Client: Pure Jongo A2. I have set-up a custom DLNA profile which limits its direct play codecs to mp3,wma,aac. Logs show this profile is being associated with the player and, given transcoding is taking place, I assume working correctly.
Network: Jongo is WiFI only however it's sitting next to the router/access point and it shows no signs of drop-outs.
My library is quite large (~26,000 audio tracks, ~4,000 videos) and I frequently see responses in the logs marked with (slow). I'm unsure if this is having an impact (although separately am very interested in anything I can do to speed it up! All libraries have been set to download missing metadata on scan rather than on-demand). I can upload a larger log file showing this if it would be helpful.
Very happy to run additional tests or capture further debug info. Many thanks in advance to anyone who is able to assist.
Best,
Andrew
server-63656101841.txt
ffmpeg-transcode-04c08258-124e-4b07-bfbc-19c8edd4e735.txt
