kanipek 230 Posted March 5, 2018 Posted March 5, 2018 Getting the descriptive audio track playing when direct playing/direct streaming SD definition channels. Can't say it is every channel. Haven't checked them all. This using an nvidia shield and a sony bravia. Transcoding seems to solve it. Also the "Zoom" function is not working on the Sony Bravia - instead of zooming it moves the displayed video to the left. Bravia Log sent @ 131pm EST User: Marlene Server: Delta Vega Shield Log sent @124pm EST - See playing of NCIS on USA 26.1 User: Kenn Server: Delta Vega Logs attached ffmpeg-transcode-461fa548-6227-46f1-a364-2ac06d232599.txt server-63655852799.txt server-63655850028.txt 1
kanipek 230 Posted March 7, 2018 Author Posted March 7, 2018 Hello? Anybody!! How about a the ability to change the audio stream in the ATV app?
ebr 16310 Posted March 7, 2018 Posted March 7, 2018 Hi. Sorry, this app does not have multi-audio capability in live streams yet.
deallier 8 Posted March 7, 2018 Posted March 7, 2018 Hi i wonder i someone can help i have emby server setup on Win 7 i have a DVBS Card setup with DVBLogic iptv Server all setup on Astra 28.2 e so i receive bbc, itv etc but i receive the signal with two audio tracks the problem i have is that emby default plays the 1st audio track which is (Nar eng) in other words Audio Descriptive what i would like to do is set it to play track 2 that is English Stereo by default thanks Dom 2
kanipek 230 Posted March 7, 2018 Author Posted March 7, 2018 I am seeing this also using the ATV app on Nvidia Shield and Sony Bravia.
kanipek 230 Posted March 8, 2018 Author Posted March 8, 2018 Are your channels direct streaming (Direct/I)? Yes. When I force it to transcode via enable live seeking or playback correction the audio is the correct one.
Spaceboy 2573 Posted March 10, 2018 Posted March 10, 2018 Yeah it’s been this way for 6 months or so. No real info on what’s being done or how long and it was working fine before it was disabled
deallier 8 Posted March 10, 2018 Posted March 10, 2018 hi it makes no difference for me if i direct stream or transcode it is the same i always get 1st audio track which is (Nar eng)
ebr 16310 Posted March 11, 2018 Posted March 11, 2018 If any of you are on the Android TV beta, please see how it behaves with yesterday's beta release (1.5.59). You should get an audio selection button/menu now but I'm interested in if the audio is actually correct. Thanks.
Guest asrequested Posted March 11, 2018 Posted March 11, 2018 I just tried it. It works perfectly on my mibox.
ebr 16310 Posted March 11, 2018 Posted March 11, 2018 I just tried it. It works perfectly on my mibox. Excellent. Thanks.
kanipek 230 Posted March 11, 2018 Author Posted March 11, 2018 If any of you are on the Android TV beta, please see how it behaves with yesterday's beta release (1.5.59). You should get an audio selection button/menu now but I'm interested in if the audio is actually correct. Thanks. Works!!! Any possibility of having the app "remember" the choice?
ebr 16310 Posted March 12, 2018 Posted March 12, 2018 Any possibility of having the app "remember" the choice? The problem is it doesn't know about the extra tracks until after playback starts. If I wait to do default track selection at that time then we are right back where we started with the channel start up taking too long.
