MrOctober77 0 Posted March 6, 2018 Posted March 6, 2018 I have Emby installed and am using a Pivos AIOS player to access the server. When trying to play videos, I have them set to folder vew. If I have twenty videos in a folder and one subfolder, the videos will not play correctly. the first video will say "unsupported format", the second video play but it plays the first video. Two subfolders will make the fisrt two videos unplayable and so forth. Only way to make it work is to have zero subfolders or have every video in separate subfolders. Images will behave the same way. The other issue I have is images, when I click on any photo with the AIOS it only shows up as thumbnail size, If I use the browser the photos are full size.
MrOctober77 0 Posted March 6, 2018 Author Posted March 6, 2018 (edited) Is that Pivos player browsing over Dlna? Yes it is. Edited March 7, 2018 by MrOctober77
Luke 42239 Posted March 11, 2018 Posted March 11, 2018 hi @@MrOctober77, what year was this device made? based on a quick google search it appears it's probably pretty old, right?
Luke 42239 Posted March 11, 2018 Posted March 11, 2018 Ok. Without having one of these for testing I'm not quite sure about this subfolder thing. To be honest it sounds like a defect in the dlna browser of the device that we would have to figure out a workaround for.
