zoneee 6 Posted May 14, 2018 Posted May 14, 2018 This has been happening for a while now for me. I think since I started using emby. Im using a LetsEncrypt pfx and port forwarding from my router to the emby-server. The server establishes an SSL connection but does not progress beyond that till emby-server is restarted. Im on Version 3.4.1.0 Ubuntu 18.04 right now. Again, this only affects connections from outside the LAN.
Luke 42212 Posted May 14, 2018 Posted May 14, 2018 If anyone is available to jump on the beta server that would be helpful. Just be aware that if you do jump up to beta, you cannot switch back to stable, not until the stable channel catches up to changes that are in beta. Thanks.
zoneee 6 Posted May 14, 2018 Posted May 14, 2018 Jumped! Unpacking emby-server (3.4.1.2) over (3.4.1.0) ... Will let you know in a few days. :-) 1
jscoys 147 Posted May 14, 2018 Posted May 14, 2018 Question for you zoneee: was it happening with browsers only or with native apps? Sent from my iPhone using Tapatalk
zoneee 6 Posted May 14, 2018 Posted May 14, 2018 Kodi EmbyCon, Kodi Emby, Browser, Android/iOS App ... everything times out till a restart of the server. And to make matters worse, there's no real way to tell (when on the LAN) till you actually try using it from the internet. Thats when you realize its not working anymore and go manually restart.:/
jscoys 147 Posted May 16, 2018 Posted May 16, 2018 Ok on my side it’s only from outside and with https from browsers. If I use native app (ET, iOS app, android app...) it works right away. Sent from my iPhone using Tapatalk
zoneee 6 Posted May 21, 2018 Posted May 21, 2018 Well, so far so good. 4 days on emby-server-deb_3.4.1.5_amd64.deb and things are still working from the outside. 1
killride 47 Posted May 23, 2018 Posted May 23, 2018 (edited) Hi @@Luke, I'm making a little script to check the https port and restart the server when he's not responsing. Is it possible to do a proper restart like with the restart button on the dashboard by any way? I found that in the dashboard.html : <button is="emby-button" type="button" class="raised btnRestartContainer hide" onclick="DashboardPage.restart();" style="margin-left:0;"> <span>${ButtonRestart}</span> </button> So I think It's possible to run the JS DashboardPage.restart() in a batch script? Edited May 23, 2018 by killride
extensive 20 Posted May 23, 2018 Posted May 23, 2018 i finally jumped on a beta, 3.4.1.7 today and so far so good. i do not see any mention of this in the release notes of the beta, why is that?
Luke 42212 Posted May 23, 2018 Posted May 23, 2018 i finally jumped on a beta, 3.4.1.7 today and so far so good. i do not see any mention of this in the release notes of the beta, why is that? Because this is a hard to reproduce problem so I can't confidently say whether it's resolved or not at this point. 1
extensive 20 Posted May 23, 2018 Posted May 23, 2018 Because this is a hard to reproduce problem so I can't confidently say whether it's resolved or not at this point. thanks for the response. will keep this thread updated with beta results.
AgileHumor 123 Posted May 24, 2018 Posted May 24, 2018 (edited) Hi @@Luke, I'm making a little script to check the https port and restart the server when he's not responsing. Is it possible to do a proper restart like with the restart button on the dashboard by any way? I found that in the dashboard.html : <button is="emby-button" type="button" class="raised btnRestartContainer hide" onclick="DashboardPage.restart();" style="margin-left:0;"> <span>${ButtonRestart}</span> </button> So I think It's possible to run the JS DashboardPage.restart() in a batch script? If you're on Windows, these two files will restart Emby (not as cleanly as I'd like via supported command line). https://emby.media/community/index.php?/topic/31242-is-there-a-way-to-turn-off-the-emby-through-dos-command-line/?p=302108 (Post #6) RestartEmby.zip Edited May 24, 2018 by AgileHumor
extensive 20 Posted May 30, 2018 Posted May 30, 2018 no new update? i was on the beta for 3 days and it was rock solid. but i switched to nginx and couldn't be happier.
Luke 42212 Posted May 30, 2018 Posted May 30, 2018 i was on the beta for 3 days and it was rock solid. but i switched to nginx and couldn't be happier. Thanks for the feedback. 1
vaise 340 Posted June 2, 2018 Posted June 2, 2018 If you're on Windows, these two files will restart Emby (not as cleanly as I'd like via supported command line). https://emby.media/community/index.php?/topic/31242-is-there-a-way-to-turn-off-the-emby-through-dos-command-line/?p=302108 (Post #6) I tried this script but it prompts for admin, and for some reason did not restart, just stopped the server. I had this ssl issue for the first time yesterday. A bit embarassing more than anything as I was demo'ing to some friends at dinner. I would like to schedule an emby server stop/start overnight, every night at 5AM. I can schedule the emby server start app no problem. In task manager, there are two Electron apps and one EmbyServer app there - can I just scheduled a ps kill of those to stop ? Thanks.
Luke 42212 Posted June 3, 2018 Posted June 3, 2018 What was the ssl issue? It could be unrelated to this topic.
AgileHumor 123 Posted June 4, 2018 Posted June 4, 2018 (edited) I tried this script but it prompts for admin, and for some reason did not restart, just stopped the server. I had this ssl issue for the first time yesterday. A bit embarassing more than anything as I was demo'ing to some friends at dinner. I would like to schedule an emby server stop/start overnight, every night at 5AM. I can schedule the emby server start app no problem. In task manager, there are two Electron apps and one EmbyServer app there - can I just scheduled a ps kill of those to stop ? Thanks. It only stops the server. You would need to add a command line to start the server at the end. i.e C:\Users\Administrator\AppData\Roaming\Emby-Server\system\EmbyServer.exe In task scheduler of Windows where you run the cmd file, you would need to to check the box "run with highest privledges". #4 here: https://www.raymond.cc/blog/task-scheduler-bypass-uac-prompt/ One day, I hope we get a command line switch i.e. "EmbyServer.exe /Restart" Edited June 4, 2018 by AgileHumor
vaise 340 Posted June 4, 2018 Posted June 4, 2018 I registered my https site on downnotifier.com, checks every 10 minutes and emails you, free for just that. Costs peanuts for checking every 1 minute instead if you want more.
Spaceboy 2573 Posted June 5, 2018 Posted June 5, 2018 PRTG does the same and loads loads more for free
vaise 340 Posted June 8, 2018 Posted June 8, 2018 had it fail today, checked logs, see this, restarted emby, all fine again - as prtg runs locally, maybe I can get it to auto restart emby when it notices it now working...... that would be better : 2018-06-08 09:51:53.751 Info HttpServer: HTTP Response 204 to 124.181.84.167. Time: 29ms. https://vaise.asuscomm.com:8920/emby/Sessions/Playing/Progress 2018-06-08 09:51:55.836 Info HttpServer: HTTP GET https://vaise.asuscomm.com:8920/emby/videos/6ba5469fc3b4895f0ddb0e02b96efe79/hls1/main/367.ts?DeviceId=C78E5E2B-E724-44C5-AEEC-3148F2DD5860&MediaSourceId=6ba5469fc3b4895f0ddb0e02b96efe79&VideoCodec=h264&AudioCodec=mp3,aac&AudioStreamIndex=1&VideoBitrate=576001&AudioBitrate=223999&PlaySessionId=e0ccce0992e9405cbe66fa922d5b2b9f&TranscodingMaxAudioChannels=2&RequireAvc=true&Tag=6a1aa7fbceef8c214d81f875338ce5f5&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&h264-deinterlace=true&TranscodeReasons=ContainerBitrateExceedsLimit. Host=vaise.asuscomm.com:8920, Referer=http://localhost:12344/index.html, X-Playback-Session-Id=CE1711F5-CCCF-4048-B008-B15E5E9A7F2E, Accept-Encoding=identity, Accept=*/*, Accept-Language=en-au, Connection=keep-alive, User-Agent=Mozilla/5.0 (iPad; CPU OS 9_3_5 like Mac OS X) AppleWebKit/601.1.46 (KHTML, like Gecko) Mobile/13G36 2018-06-08 09:51:57.900 Info HttpServer: HTTP Response 200 to 124.181.84.167. Time: 2065ms (slow). https://vaise.asuscomm.com:8920/emby/videos/6ba5469fc3b4895f0ddb0e02b96efe79/hls1/main/367.ts?DeviceId=C78E5E2B-E724-44C5-AEEC-3148F2DD5860&MediaSourceId=6ba5469fc3b4895f0ddb0e02b96efe79&VideoCodec=h264&AudioCodec=mp3,aac&AudioStreamIndex=1&VideoBitrate=576001&AudioBitrate=223999&PlaySessionId=e0ccce0992e9405cbe66fa922d5b2b9f&TranscodingMaxAudioChannels=2&RequireAvc=true&Tag=6a1aa7fbceef8c214d81f875338ce5f5&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&h264-deinterlace=true&TranscodeReasons=ContainerBitrateExceedsLimit 2018-06-08 09:55:05.763 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 3.4.1.0 Command line: C:\Users\Vaise\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Vaise\AppData\Roaming\Emby-Server Application directory: C:\Users\Vaise\AppData\Roaming\Emby-Server\system System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsServer(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpConnection.<Init>d__30.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__27.MoveNext() System.IO.IOException at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsServer(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpConnection.<Init>d__30.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__27.MoveNext() 2018-06-08 09:55:05.780 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 3.4.1.0 Command line: C:\Users\Vaise\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Vaise\AppData\Roaming\Emby-Server Application directory: C:\Users\Vaise\AppData\Roaming\Emby-Server\system System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c__DisplayClass35_0.<AuthenticateAsServerAsync>b__0(AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl(Func`3 beginMethod, Func`2 endFunction, Action`1 endAction, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync(Func`3 beginMethod, Action`1 endMethod, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.<Init>d__30.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__27.MoveNext() System.IO.IOException at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c__DisplayClass35_0.<AuthenticateAsServerAsync>b__0(AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl(Func`3 beginMethod, Func`2 endFunction, Action`1 endAction, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync(Func`3 beginMethod, Action`1 endMethod, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.<Init>d__30.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__27.MoveNext() 2018-06-08 09:55:05.801 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 3.4.1.0 Command line: C:\Users\Vaise\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Vaise\AppData\Roaming\Emby-Server Application directory: C:\Users\Vaise\AppData\Roaming\Emby-Server\system System.IO.IOException: Authentication failed because the remote party has closed the transport stream. at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c__DisplayClass35_0.<AuthenticateAsServerAsync>b__0(AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl(Func`3 beginMethod, Func`2 endFunction, Action`1 endAction, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync(Func`3 beginMethod, Action`1 endMethod, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.<Init>d__30.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__27.MoveNext() System.IO.IOException at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslStream.BeginAuthenticateAsServer(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation, AsyncCallback asyncCallback, Object asyncState) at System.Net.Security.SslStream.<>c__DisplayClass35_0.<AuthenticateAsServerAsync>b__0(AsyncCallback callback, Object state) at System.Threading.Tasks.TaskFactory`1.FromAsyncImpl(Func`3 beginMethod, Func`2 endFunction, Action`1 endAction, Object state, TaskCreationOptions creationOptions) at System.Threading.Tasks.TaskFactory.FromAsync(Func`3 beginMethod, Action`1 endMethod, Object state) at System.Net.Security.SslStream.AuthenticateAsServerAsync(X509Certificate serverCertificate, Boolean clientCertificateRequired, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation) at SocketHttpListener.Net.HttpConnection.<Init>d__30.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__29.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at SocketHttpListener.Net.HttpEndPointListener.<ProcessAccept>d__27.MoveNext()
Luke 42212 Posted June 8, 2018 Posted June 8, 2018 Ok you're on the stable release. I think it will be improved with the next release. Thanks.
zoneee 6 Posted June 8, 2018 Posted June 8, 2018 What broke in 3.4.1.12? $ curl -kv https://internal_hostname:8920/web/index.html * Trying 192.168.46.6... * TCP_NODELAY set * Connected to internal_hostname (192.168.46.6) port 8920 (#0) * ALPN, offering h2 * ALPN, offering http/1.1 * Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@@Strength * successfully set certificate verify locations: * CAfile: /etc/ssl/cert.pem CApath: none * TLSv1.2 (OUT), TLS handshake, Client hello (1): * LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to internal_hostname:8920 * stopped the pause stream! * Closing connection 0 curl: (35) LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to internal_hostname:8920 Ive gone back to 3.4.1.11
