Jdiesel 1435 Posted March 23, 2018 Posted March 23, 2018 Also worth mentioning that I am running linux and Emby server is binding to ports 8096 and 443. I suppose it is possible the Emby is releasing port 443 or some other software is interfering with it but I am not aware of any software on my server that would be using port 443.
jhoff80 94 Posted March 23, 2018 Author Posted March 23, 2018 There's definitely something really weird about all this... because for the past week it happened once a day. And now all of a sudden today, it's not even lasting 20 minutes. I also switched from the release version to 3.3.1.7 with no change observed. Still the same issue. In the interest of adding more information, some of which was already probably in my logs: OS: Windows Server 2016 (version 1607, GUI install) Emby SSL: 8097 Emby non-SSL: 8096 My certificate is through Let's Encrypt, and still has a month before expiry currently. Same certificate is used for Server 2016 Essentials Remote Web Access with no issues as well. Also, with regards to removing "https://" from the external domain field, I never put it there in the first place. Mine has always just been remote.<domain>.com in that field.
Jdiesel 1435 Posted March 23, 2018 Posted March 23, 2018 https://github.com/aspnet/KestrelHttpServer/issues/2104
Jdiesel 1435 Posted March 24, 2018 Posted March 24, 2018 Down again on 3.3.1.7. Was up for about 30 hours before becoming unresponsive over https.
Luke 42212 Posted March 24, 2018 Posted March 24, 2018 Ok thanks, I think I have a handle on it. Please try the next beta server, thanks. 1
Jdiesel 1435 Posted March 24, 2018 Posted March 24, 2018 Ok thanks, I think I have a handle on it. Please try the next beta server, thanks. Alright will try the next release when it is out. Is there anything that might trigger it that I can use to replicate the issue? Lots of activity or connections perhaps?
Luke 42212 Posted March 24, 2018 Posted March 24, 2018 Well I don't know what the single bad event is at this point but it does look like when they start to pile up that it just becomes an issue of too many open sockets. So now they'll at least be closed when there's a problem.
Luke 42212 Posted March 25, 2018 Posted March 25, 2018 New beta is up. If any of you can try that out, that would be very helpful. Thanks.
Jdiesel 1435 Posted March 25, 2018 Posted March 25, 2018 New beta is up. If any of you can try that out, that would be very helpful. Thanks. No luck, only lasted about 2 hours before it went down. PMed you the logfile.
jhoff80 94 Posted March 25, 2018 Author Posted March 25, 2018 I'm not sure when exactly 3.3.1.8 went down here either, but I upgraded and 12 hours later was asked to reset it again so someone could connect.
Luke 42212 Posted March 26, 2018 Posted March 26, 2018 Please try the 3.3.1.9 beta once available for your platform, thanks.
zirus 0 Posted March 26, 2018 Posted March 26, 2018 I'm on 3.3.1.9 for 13 hours so far and i still seem to be up! So i'm optimistic at this point
Luke 42212 Posted March 27, 2018 Posted March 27, 2018 The builds are available from the website download page: https://emby.media/download Thanks.
Jdiesel 1435 Posted March 27, 2018 Posted March 27, 2018 Whoops didn't realize the compiled builds had been removed from Github already. I see 3.3.1.10 has been released so I will wait for that now
Luke 42212 Posted March 27, 2018 Posted March 27, 2018 The website will always link you directly to the downloads. That is the best place to go. Thanks.
jhoff80 94 Posted March 29, 2018 Author Posted March 29, 2018 I've been on 3.3.1.10 for about 44 hours now with no issues so yeah, I'm cautiously optimistic that this is fixed. I'll upgrade to whatever newest build when I hit a week (or if it ends up happening again), but I just want to see if it keeps working if I leave it running. 1
Luke 42212 Posted March 31, 2018 Posted March 31, 2018 @@Jdiesel have you have a chance to try the beta? Thanks.
Jdiesel 1435 Posted March 31, 2018 Posted March 31, 2018 Yes, been on 3.3.1.10 for about 36 hours now with no issues. I started to migrate some users back over to my Ember server today so it should see a bit of a test under load this weekend.
Jdiesel 1435 Posted April 2, 2018 Posted April 2, 2018 Server became unresponsive last night when browsing via the Android TV client, tried connecting via the web client and could not connect either. Needed to reboot the server. Looks like there are quite a few errors being thrown in the log file which weren't there when the server became unresponsive previously so maybe it is a different issue. PMed you the logfile.
