rikiwi 32 Posted March 6, 2018 Posted March 6, 2018 (edited) I notice since updating the server to Version 3.3.1.1 beta, that the Live TV Guide is missing in Emby Theater for Windows. All the programs are still showing in the Channels section. The guide is still showing in the Windows 10 Emby Theater app. I seem to remember this happening ages ago but i just can't recall how I fixed it. Let me know if you need any logs etc. Thanks Edited March 6, 2018 by rikiwi
Sammy 791 Posted March 6, 2018 Posted March 6, 2018 (edited) I notice since updating the server to Version 3.3.1.1 beta, that the Live TV Guide is missing in Emby Theater for Windows. All the programs are still showing in the Channels section. The guide is still showing in the Windows 10 Emby Theater app. I seem to remember this happening ages ago but i just can't recall how I fixed it. Let me know if you need any logs etc. Thanks This is server side most likeky and logs are critical to resolving issues. Do you use ServerWMC? I'm having issues with the guide in 3.3.1.0 Stable. https://emby.media/community/index.php?/topic/56732-Tuners-not-found-in-Server-3.3.10 Sent from my SM-G930P using Tapatalk Edited March 6, 2018 by Sammy
rikiwi 32 Posted March 6, 2018 Author Posted March 6, 2018 No, I use NextPVR back-end and the plugin.
Sammy 791 Posted March 6, 2018 Posted March 6, 2018 No, I use NextPVR back-end and the plugin.My issues seem to correlate with the release of 3.3.1.0 but who knows for sure. Sent from my SM-G930P using Tapatalk
Luke 42243 Posted March 6, 2018 Posted March 6, 2018 Sounds like you removed live TV from your home screen
rikiwi 32 Posted March 6, 2018 Author Posted March 6, 2018 Thanks Luke. Gosh I never realised that Live TV had changed. I used to just access the guide from my Live TV icon on the home screen but now I need to activate this in the server first. Then the Live TV section is displayed as a separate section below My Media icons. Mmmm. Just a different way to access TV stuff.
Luke 42243 Posted March 6, 2018 Posted March 6, 2018 Eventually the guide will be embedded into the live tv screen just like the other apps.
