georgewill76 14 Posted March 5, 2018 Posted March 5, 2018 Hi I have a few movies that have a DTS-HD HRA audio track. However, they dont seem to work in Emby Theater. I have bitstreaming set for all the formats. I am able to play DTS-X, DTS-HD, DTS-HD MA, True HD without any problems. I am using a Denon AVR-X2400H receiver. I have tested my files to make sure the DTS-HD HRA track plays as I have PowerDVD 17 installed on my HTPC and it is able to play the audio track without any problems. Has anyone else seen this problem before? Is there a fix or something I could do to get this audio track to play?
Guest asrequested Posted March 6, 2018 Posted March 6, 2018 It's ostensibly just a higher bitrate. I'm not sure I have anything to test with. Can you give me a sample, so I can take a look? But on it's face, it should just bitstream. If the receiver supports the bitrate, then it will play. A quick heads about PDVD (I have it, too). it can do some funky stuff with audio. But I really need to have a sample before I can figure anything out. It is peaking my curiosity. I just got a test file.....testing
Guest asrequested Posted March 6, 2018 Posted March 6, 2018 PDVD does bitstream it, correctly....looking in to mpv....
Guest asrequested Posted March 6, 2018 Posted March 6, 2018 This isn't looking promising. It can decode it to PCM https://github.com/mpv-player/mpv/issues/1986 But I haven't found a way to bitstream it, yet. When I play it, I do get sound, but it's incorrect. I'll keep testing...
Guest asrequested Posted March 6, 2018 Posted March 6, 2018 It may need to be a profile https://github.com/mpv-player/mpv/search?utf8=%E2%9C%93&q=hra&type=
georgewill76 14 Posted March 6, 2018 Author Posted March 6, 2018 Hi Doofus Thanks for looking into this me. From what you say does it mean something needs to be updated in the emby theatre software?
Guest asrequested Posted March 6, 2018 Posted March 6, 2018 Hi Doofus Thanks for looking into this me. From what you say does it mean something needs to be updated in the emby theatre software? No, it's down to how ffmpeg handles it, as the player that's in theater is mpv and runs on ffmpeg. I've been looking into it. I haven't found anything specific to bitstreaming HRA, but I haven't experimented with making a profile, yet. I know it can be decoded, but in my testing it only decodes the core. DCA apparently supports all the dts extensions, so it may just need some tweaking. I ran out of time, last night.
Guest asrequested Posted March 6, 2018 Posted March 6, 2018 One variation I didn't try, was dts-hd_hra. I'll see how that goes, tonight, among other things.
Guest asrequested Posted March 9, 2018 Posted March 9, 2018 Unfortunately, the best I'm coming up with is decoding the core audio. I haven't found any reference to bitstreaming HRA. As far as I can tell, DCA relies on dts-hd to bitstream all of the extensions, but doesn't appear to work with HRA. @@daedalus, have you seen anything relating to DTS-HD HRA? When I look at the list of decoders, for DTS it all comes under DCA, with no specific listings for the other DTS extensions. Audio decoders: comfortnoise - RFC 3389 comfort noise generator dvaudio - Ulead DV Audio 8svx_exp - 8SVX exponential 8svx_fib - 8SVX fibonacci s302m - SMPTE 302M sdx2_dpcm - DPCM Squareroot-Delta-Exact aac - AAC (Advanced Audio Coding) aac_fixed (aac) - AAC (Advanced Audio Coding) aac_latm - AAC LATM (Advanced Audio Coding LATM syntax) ac3 - ATSC A/52A (AC-3) ac3_fixed (ac3) - ATSC A/52A (AC-3) alac - ALAC (Apple Lossless Audio Codec) als (mp4als) - MPEG-4 Audio Lossless Coding (ALS) amrnb (amr_nb) - AMR-NB (Adaptive Multi-Rate NarrowBand) amrwb (amr_wb) - AMR-WB (Adaptive Multi-Rate WideBand) ape - Monkey's Audio aptx - aptX (Audio Processing Technology for Bluetooth) atrac1 - ATRAC1 (Adaptive TRansform Acoustic Coding) atrac3 - ATRAC3 (Adaptive TRansform Acoustic Coding 3) atrac3al - ATRAC3 AL (Adaptive TRansform Acoustic Coding 3 Advanced Lossless) atrac3plus (atrac3p) - ATRAC3+ (Adaptive TRansform Acoustic Coding 3+) atrac3plusal (atrac3pal) - ATRAC3+ AL (Adaptive TRansform Acoustic Coding 3+ Advanced Lossless) binkaudio_dct - Bink Audio (DCT) binkaudio_rdft - Bink Audio (RDFT) bmv_audio - Discworld II BMV audio cook - Cook / Cooker / Gecko (RealAudio G2) dca (dts) - DCA (DTS Coherent Acoustics) dolby_e - Dolby E dsd_lsbf - DSD (Direct Stream Digital), least significant bit first dsd_msbf - DSD (Direct Stream Digital), most significant bit first dsd_lsbf_planar - DSD (Direct Stream Digital), least significant bit first, planar dsd_msbf_planar - DSD (Direct Stream Digital), most significant bit first, planar dsicinaudio - Delphine Software International CIN audio dss_sp - Digital Speech Standard - Standard Play mode (DSS SP) dst - DST (Digital Stream Transfer) eac3 - ATSC A/52B (AC-3, E-AC-3) evrc - EVRC (Enhanced Variable Rate Codec) wavesynth - Wave synthesis pseudo-codec flac - FLAC (Free Lossless Audio Codec) g723_1 - G.723.1 g729 - G.729 gsm - GSM gsm_ms - GSM Microsoft variant iac - IAC (Indeo Audio Coder) imc - IMC (Intel Music Coder) interplayacm - Interplay ACM mace3 - MACE (Macintosh Audio Compression/Expansion) 3:1 mace6 - MACE (Macintosh Audio Compression/Expansion) 6:1 metasound - Voxware MetaSound mlp - MLP (Meridian Lossless Packing) mp1 - MP1 (MPEG audio layer 1) mp1float (mp1) - MP1 (MPEG audio layer 1) mp2 - MP2 (MPEG audio layer 2) mp2float (mp2) - MP2 (MPEG audio layer 2) mp3 - MP3 (MPEG audio layer 3) mp3float (mp3) - MP3 (MPEG audio layer 3) mp3adu - ADU (Application Data Unit) MP3 (MPEG audio layer 3) mp3adufloat (mp3adu) - ADU (Application Data Unit) MP3 (MPEG audio layer 3) mp3on4 - MP3onMP4 mp3on4float (mp3on4) - MP3onMP4 mpc7 (musepack7) - Musepack SV7 mpc8 (musepack8) - Musepack SV8 nellymoser - Nellymoser Asao on2avc (avc) - On2 Audio for Video Codec opus - Opus paf_audio - Amazing Studio Packed Animation File Audio qcelp - QCELP / PureVoice qdm2 - QDesign Music Codec 2 qdmc - QDesign Music Codec 1 real_144 (ra_144) - RealAudio 1.0 (14.4K) real_288 (ra_288) - RealAudio 2.0 (28.8K) ralf - RealAudio Lossless shorten - Shorten sipr - RealAudio SIPR / ACELP.NET smackaud (smackaudio) - Smacker audio sonic - Sonic tak - TAK (Tom's lossless Audio Kompressor) truehd - TrueHD truespeech - DSP Group TrueSpeech tta - TTA (True Audio) twinvq - VQF TwinVQ vmdaudio - Sierra VMD audio vorbis - Vorbis wavpack - WavPack wmalossless - Windows Media Audio Lossless wmapro - Windows Media Audio 9 Professional wmav1 - Windows Media Audio 1 wmav2 - Windows Media Audio 2 wmavoice - Windows Media Audio Voice ws_snd1 (westwood_snd1) - Westwood Audio (SND1) xma1 - Xbox Media Audio 1 xma2 - Xbox Media Audio 2 pcm_alaw - PCM A-law / G.711 A-law pcm_bluray - PCM signed 16|20|24-bit big-endian for Blu-ray media pcm_dvd - PCM signed 16|20|24-bit big-endian for DVD media pcm_f16le - PCM 16.8 floating point little-endian pcm_f24le - PCM 24.0 floating point little-endian pcm_f32be - PCM 32-bit floating point big-endian pcm_f32le - PCM 32-bit floating point little-endian pcm_f64be - PCM 64-bit floating point big-endian pcm_f64le - PCM 64-bit floating point little-endian pcm_lxf - PCM signed 20-bit little-endian planar pcm_mulaw - PCM mu-law / G.711 mu-law pcm_s8 - PCM signed 8-bit pcm_s8_planar - PCM signed 8-bit planar pcm_s16be - PCM signed 16-bit big-endian pcm_s16be_planar - PCM signed 16-bit big-endian planar pcm_s16le - PCM signed 16-bit little-endian pcm_s16le_planar - PCM signed 16-bit little-endian planar pcm_s24be - PCM signed 24-bit big-endian pcm_s24daud - PCM D-Cinema audio signed 24-bit pcm_s24le - PCM signed 24-bit little-endian pcm_s24le_planar - PCM signed 24-bit little-endian planar pcm_s32be - PCM signed 32-bit big-endian pcm_s32le - PCM signed 32-bit little-endian pcm_s32le_planar - PCM signed 32-bit little-endian planar pcm_s64be - PCM signed 64-bit big-endian pcm_s64le - PCM signed 64-bit little-endian pcm_u8 - PCM unsigned 8-bit pcm_u16be - PCM unsigned 16-bit big-endian pcm_u16le - PCM unsigned 16-bit little-endian pcm_u24be - PCM unsigned 24-bit big-endian pcm_u24le - PCM unsigned 24-bit little-endian pcm_u32be - PCM unsigned 32-bit big-endian pcm_u32le - PCM unsigned 32-bit little-endian pcm_zork - PCM Zork gremlin_dpcm - DPCM Gremlin interplay_dpcm - DPCM Interplay roq_dpcm - DPCM id RoQ sol_dpcm - DPCM Sol xan_dpcm - DPCM Xan adpcm_4xm - ADPCM 4X Movie adpcm_adx - SEGA CRI ADX ADPCM adpcm_afc - ADPCM Nintendo Gamecube AFC adpcm_aica - ADPCM Yamaha AICA adpcm_ct - ADPCM Creative Technology adpcm_dtk - ADPCM Nintendo Gamecube DTK adpcm_ea - ADPCM Electronic Arts adpcm_ea_maxis_xa - ADPCM Electronic Arts Maxis CDROM XA adpcm_ea_r1 - ADPCM Electronic Arts R1 adpcm_ea_r2 - ADPCM Electronic Arts R2 adpcm_ea_r3 - ADPCM Electronic Arts R3 adpcm_ea_xas - ADPCM Electronic Arts XAS g722 (adpcm_g722) - G.722 ADPCM g726 (adpcm_g726) - G.726 ADPCM g726le (adpcm_g726le) - G.726 ADPCM little-endian adpcm_ima_amv - ADPCM IMA AMV adpcm_ima_apc - ADPCM IMA CRYO APC adpcm_ima_dat4 - ADPCM IMA Eurocom DAT4 adpcm_ima_dk3 - ADPCM IMA Duck DK3 adpcm_ima_dk4 - ADPCM IMA Duck DK4 adpcm_ima_ea_eacs - ADPCM IMA Electronic Arts EACS adpcm_ima_ea_sead - ADPCM IMA Electronic Arts SEAD adpcm_ima_iss - ADPCM IMA Funcom ISS adpcm_ima_oki - ADPCM IMA Dialogic OKI adpcm_ima_qt - ADPCM IMA QuickTime adpcm_ima_rad - ADPCM IMA Radical adpcm_ima_smjpeg - ADPCM IMA Loki SDL MJPEG adpcm_ima_wav - ADPCM IMA WAV adpcm_ima_ws - ADPCM IMA Westwood adpcm_ms - ADPCM Microsoft adpcm_mtaf - ADPCM MTAF adpcm_psx - ADPCM Playstation adpcm_sbpro_2 - ADPCM Sound Blaster Pro 2-bit adpcm_sbpro_3 - ADPCM Sound Blaster Pro 2.6-bit adpcm_sbpro_4 - ADPCM Sound Blaster Pro 4-bit adpcm_swf - ADPCM Shockwave Flash adpcm_thp - ADPCM Nintendo THP adpcm_thp_le - ADPCM Nintendo THP (little-endian) adpcm_vima - LucasArts VIMA audio adpcm_xa - ADPCM CDROM XA adpcm_yamaha - ADPCM Yamaha libopus (opus) - libopus Opus libspeex (speex) - libspeex Speex libvorbis (vorbis) - libvorbis
Guest asrequested Posted March 14, 2018 Posted March 14, 2018 (edited) So, I'm gonna go ahead and say that at this time, mpv doesn't support DTS-HD HRA bitstreaming. Edited March 14, 2018 by Doofus
Jdiesel 1435 Posted March 14, 2018 Posted March 14, 2018 https://github.com/Nevcairiel/LAVFilters/issues/167 Looks like there is issues with LAV too
Guest asrequested Posted March 14, 2018 Posted March 14, 2018 I saw that when I was researching, this. PowerDVD will bitstream it. Luke, maybe add a selection for an external player to play it? Until ffmpeg, matures.
Guest asrequested Posted March 14, 2018 Posted March 14, 2018 (edited) Of course, the other option is to let mpv do the decoding and pass the uncompressed audio directly to the receiver. Technically, it's the exact same audio. To try it, disable DTS-HD in the settings and make sure that the audio channels are set correctly in both Theater and Windows. That way mpv will decode it instead of the receiver. So any DTS-HD will be treated the same way. There shouldn't be any difference in fidelity. I have a feeling that ffmpeg is heading in this general direction. This will also most likely remove any metadata, which could be a problem. I haven't actually tested this, but I will, tonight. Luke, as a side note. Make sure that Emby has an ffmpeg build that has the DCA decoder. Otherwise if the server has to transcode that audio, it will come out wrong or not at all. Edited March 14, 2018 by Doofus
Guest asrequested Posted March 14, 2018 Posted March 14, 2018 Is it transcoding OK now? Bitstreaming, you mean? No, it won't bitstream, but it can be decoded to PCM. I just need to test that it isn't just decoding the core audio. Which is what I'll test, tonight. Ffmpeg appears to rely on DCA decoding for all dts audio. So I was giving a shout out, for that. I think I remember seeing DCA in some transcode logs, but I thought I'd just draw some attention to it.
Guest asrequested Posted March 15, 2018 Posted March 15, 2018 (edited) OK, so that works, but there are a few things to consider. One is that you have to disable all DTS bitstreaming. If you only disable DTS-HD, it will still bitstream the core audio (5.1). This means that all DTS will be decoded to PCM raw audio (lossless, and still discrete channels). The second is that you will lose any metadata. Which really only applies to DTS-X (object based processing). The audio fidelity should not be affected, and with the exception of the metadata, the audio should be identical. You should also disabled audio exclusivity. From the mpv log [ad] Selected audio codec: dca (DCA (DTS Coherent Acoustics)) [ 0.082][v][cplayer] Starting playback... [ 0.083][v][af] Audio filter chain: [ 0.083][v][af] [in] 96000Hz 7.1 8ch floatp [ 0.083][v][af] [out] 96000Hz 7.1 8ch floatp [ 0.083][v][af] [ao] 96000Hz 7.1 8ch floatp [ 0.083][v][ao] Trying audio driver 'wasapi' [ 0.083][v][ao] Using preferred device 'SC-95 (Intel(R) Display Audio)' [ 0.083][v][ao/wasapi] requested format: 96000 Hz, 7.1 channels, floatp [ 0.083][d][ao/wasapi] Init wasapi [ 0.083][d][ao/wasapi] Find device 'SC-95 (Intel(R) Display Audio)' [ 0.088][v][ao/wasapi] Selecting device by name: 'SC-95 (Intel(R) Display Audio)' [ 0.088][v][ao/wasapi] Selecting device '{2e25d85a-2baf-4064-aafd-c0e05aef416f}' (SC-95 (Intel(R) Display Audio)) [ 0.089][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{2e25d85a-2baf-4064-aafd-c0e05aef416f} [ 0.100][d][ao/wasapi] Init wasapi thread [ 0.100][d][ao/wasapi] Activating pAudioClient interface [ 0.103][d][ao/wasapi] Probing formats [ 0.103][v][ao/wasapi] Trying 7.1 float (32/32 bits) @ 96000hz (shared) -> ok [ 0.103][v][ao/wasapi] Accepted as 7.1 float @ 96000hz -> 7.1 float (32/32 bits) @ 96000hz (shared) [ 0.103][d][ao/wasapi] Fixing format [ 0.103][d][ao/wasapi] IAudioClient::GetDevicePeriod [ 0.103][v][ao/wasapi] Device period: 10 ms [ 0.103][d][ao/wasapi] IAudioClient::Initialize [ 0.124][d][ao/wasapi] IAudioClient::Initialize pRenderClient [ 0.124][d][ao/wasapi] IAudioClient::Initialize IAudioClient_SetEventHandle [ 0.124][d][ao/wasapi] IAudioClient::Initialize IAudioClient_GetBufferSize [ 0.124][v][ao/wasapi] Buffer frame count: 4800 (50 ms) [ 0.124][v][ao/wasapi] IAudioClock::GetFrequency gave a frequency of 3072000. [ 0.125][d][ao/wasapi] IAudioClient::Initialize pAudioVolume [ 0.125][d][ao/wasapi] Entering dispatch loop [ 0.125][d][ao/wasapi] Init wasapi done [ 0.126][v][ao/wasapi] device buffer: 4800 samples. [ 0.126][v][ao/wasapi] using soft-buffer of 19200 samples. [ 0.126][i][cplayer] AO: [wasapi] 96000Hz 7.1 8ch float [ 0.126][v][cplayer] AO: Description: Windows WASAPI audio output (event mode) [ 0.126][v][af] Adding filter lavrresample [ 0.126][v][af] Audio filter chain: [ 0.126][v][af] [in] 96000Hz 7.1 8ch floatp [ 0.126][v][af] [lavrresample] 96000Hz 7.1 8ch float [a] [ 0.126][v][af] [out] 96000Hz 7.1 8ch float [ 0.126][v][af] [ao] 96000Hz 7.1 8ch float Edited March 19, 2018 by Doofus
Guest asrequested Posted March 15, 2018 Posted March 15, 2018 I think I read that lavrresample is going to be removed in the next mpv build. So this will need to be retested if that happens.
Jdiesel 1435 Posted March 19, 2018 Posted March 19, 2018 Just saw this on the Kodi forum from the OSMC developer We are working on a PCM infoframe fix to fix Atmos and DTS HRA on some AVRs (low end Denons). https://forum.kodi.tv/showthread.php?tid=258707&pid=2715967#pid2715967 Might just be an issue with the OP's Denon receiver and needs an upstream patch to mpv
Guest asrequested Posted March 19, 2018 Posted March 19, 2018 I have the same issue, and I have a Pioneer Elite SC-95. I should report it to mpv and post my logs. I was waiting for the next mpv release, first. There are many changes coming.
Guest asrequested Posted October 31, 2018 Posted October 31, 2018 Apparently this has been fixed. https://github.com/mpv-player/mpv/commit/25ee18d6e54cd95e8c193023674ce26803e76464
