snake98 10 Posted March 5, 2018 Posted March 5, 2018 I notice with the logs, that Emby is not respecting the H264 encoding preset setting. It only uses h264_qsv -preset 7 when using hardware acceleration. According to intel 7 is Fastest settings, biggest quality drop. cpu is Intel® Core™ i7-8700K. Log ffmpeg.exe -analyzeduration 3000000 -fflags +igndts -c:v h264_qsv -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/7d781adb17ca4640879c92a5b50bef79/stream.ts" -map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 h264_qsv -preset 7 -look_ahead 0 -b:v 2616000 -maxrate 2616000 -bufsize 5232000 -profile:v high -level 4.1 -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -flags -global_header -vsync cfr -codec:a:0 aac -strict experimental -ac 2 -ab 384000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/7aadbd1a838da4d6a936911d25fd8688/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "z:\transcoding-temp\7aadbd1a838da4d6a936911d25fd8688.m3u8" -y "z:\transcoding-temp\7aadbd1a838da4d6a936911d25fd8688%d.ts" Setup 1
Luke 42208 Posted March 5, 2018 Posted March 5, 2018 It's currently only used with software encoding.
snake98 10 Posted March 5, 2018 Author Posted March 5, 2018 It's currently only used with software encoding. Is there a way to change the setting used from 7 to 2 behind the scenes?
Luke 42208 Posted March 5, 2018 Posted March 5, 2018 It's something to consider for the future. Thanks. 1
snake98 10 Posted March 6, 2018 Author Posted March 6, 2018 It's something to consider for the future. Thanks. I created a pull request to add this options. I'm not a professional programmer, but I believe it follows your style. Let me know if you need anything changed, or can put it in the next Beta. If someone else wants to test it let me know. You just need to replace3 dll's that works on the current branch. https://github.com/MediaBrowser/Emby/pull/3193
snake98 10 Posted March 15, 2018 Author Posted March 15, 2018 Is getting that code put into the beta a possibility? I"ve been testing it and it works fine. If anyone else wants to test it let me know, I can upload the 3 dll that got changed. 1
cybergrimes 93 Posted March 15, 2018 Posted March 15, 2018 +1 this all day. I'm a big fan of QSV, so more options for quality control would be great.
snake98 10 Posted March 15, 2018 Author Posted March 15, 2018 (edited) @@Luke If this is a problem let me know i'll remove it, or should be it's own topic? This is a test will set the quality of the QSV to the settings of H264 encoding preset, Emby currently sets it to 7 (veryfast) and can't be changed. To install Replace the 3 Dll's in the \Emby-Server\system directory with the ones in the Link. You have to reapply these after every update. Allowed Settings areveryfastfasterfastermediumslowslowerveryslowAny other choice will default to emby's veryfast setting. These were built off server 3.1.1.0, and tested on windows. https://drive.google.com/drive/folders/1n-I1PXXL87rCi4hDpdqTjym2M6Xt90mJ Change code is here https://github.com/MediaBrowser/Emby/pull/3193 Please let me know if you have any problems, or if it works on linux. Edited March 15, 2018 by snake98
Carlo 4561 Posted March 16, 2018 Posted March 16, 2018 This is the same for amf and nvenc where it's not respecting the defaults set for the encoder. Actually what would be best is to have the normal CPU settings PLUS a section specific to the HW encoder chosen. 1
cybergrimes 93 Posted March 16, 2018 Posted March 16, 2018 It looks like on the fly DVR transcoding doesn't use these settings either? I set it to 20 but see in the log crf=23.0
Luke 42208 Posted March 16, 2018 Posted March 16, 2018 It looks like on the fly DVR transcoding doesn't use these settings either? I set it to 20 but see in the log crf=23.0 This option will go away at some point due to it's instability so I don't think there is much need to do new development with it.
Carlo 4561 Posted March 16, 2018 Posted March 16, 2018 The option for Live TV or you mean the option to set the defaults we each want to use? I sure hope you don't mean the latter as I'm sure many of us don't use the defaults.
snake98 10 Posted March 16, 2018 Author Posted March 16, 2018 (edited) This is the same for amf and nvenc where it's not respecting the defaults set for the encoder. Actually what would be best is to have the normal CPU settings PLUS a section specific to the HW encoder chosen. I can wright the code, but can't test it. and mapping doesn't seem to be as straight forward as intels. -preset <int> E..V.... Set the encoding preset (from 0 to 11) (default medium) default E..V.... slow E..V.... hq 2 passes medium E..V.... hq 1 pass fast E..V.... hp 1 pass hp E..V.... high performance hq E..V.... high quality bd E..V.... blue ray disk ll E..V.... low latency llhq E..V.... low latency hq llhp E..V.... low latency hp lossless E..V.... lossless losslesshp E..V.... lossless high performance I believe lossless overrides bit rate control on nvenc, so do we just want to map the bd,slow, medium,fast options. I can't seem to find good documentation. Is bd higher quality than high quality? Add an option to do high performance 2 pass? I believe we can ignore low latency, as it more for game streaming and teleconferencing and lowers picture quality. Edited March 16, 2018 by snake98
cybergrimes 93 Posted March 16, 2018 Posted March 16, 2018 (edited) The option for Live TV or you mean the option to set the defaults we each want to use? I sure hope you don't mean the latter as I'm sure many of us don't use the defaults. He quoted me so should be talking about the DVR auto-transcode feature. I think he has mentioned some kind of post-record feature to replace it eventually (unless I misunderstood) Edited March 16, 2018 by cybergrimes
Carlo 4561 Posted March 17, 2018 Posted March 17, 2018 Got ya. Yes that makes a lot of sense and is a solid way to go. You would also get much better compression of H.264 post processing it as well.
Carlo 4561 Posted March 17, 2018 Posted March 17, 2018 I can wright the code, but can't test it. and mapping doesn't seem to be as straight forward as intels. -preset <int> E..V.... Set the encoding preset (from 0 to 11) (default medium) default E..V.... slow E..V.... hq 2 passes medium E..V.... hq 1 pass fast E..V.... hp 1 pass hp E..V.... high performance hq E..V.... high quality bd E..V.... blue ray disk ll E..V.... low latency llhq E..V.... low latency hq llhp E..V.... low latency hp lossless E..V.... lossless losslesshp E..V.... lossless high performance I believe lossless overrides bit rate control on nvenc, so do we just want to map the bd,slow, medium,fast options. I can't seem to find good documentation. Is bd higher quality than high quality? Add an option to do high performance 2 pass? I believe we can ignore low latency, as it more for game streaming and teleconferencing and lowers picture quality. Why would you map it? The idea would be to show what is supported by the hardware. Not to try and translate it back to CPU nomenclature. So for NVENC just show the options exactly as they are here. So basically these options will translate exactly to what we see in the ffmpeg options.
Luke 42208 Posted March 17, 2018 Posted March 17, 2018 Even if you have gpu encoding enabled, there are cases where cpu will be used. that's why the mapping makes sense.
cybergrimes 93 Posted March 19, 2018 Posted March 19, 2018 Hey, saw the change is in 3.3.1.6 and is working for me (can see medium setting passed in log instead of ultrafast) Did notice the deinterlacing options for standard/bob&weave are missing from bottom of page-- expected change?
Luke 42208 Posted March 19, 2018 Posted March 19, 2018 Yes that's by design due to the amount of troubleshooting that it causes. You can still edit the setting in the config file.
snake98 10 Posted March 19, 2018 Author Posted March 19, 2018 @@Luke If this is acceptable, i'll write the code and ask for some beta tester in another thread. I"ll map it as following slow, slower, veryslow = slow medium = medium All other = fast
Carlo 4561 Posted March 20, 2018 Posted March 20, 2018 Even if you have gpu encoding enabled, there are cases where cpu will be used. that's why the mapping makes sense. That would be fine. What I'm saying is to have defaults for BOTH the CPU and for the HW transcoding. I know I'd prefer to have different settings between the two so mapping them to appear the same isn't good. For example I'd want to use a better setting for the preset for the hardware but may want fast or even very fast for CPU. With NVENC for example using one of the better profiles can cut file size nearly in half (less bandwidth as well) and comes much closer to CPU sizes without a huge impact on time (especially compared to CPU overhead). But if it's mapped then we can't have a "slow" setting for hardware and a fast or very fast for CPU. With NVENC we only get 2 streams on consumer GPUs so it's best to set this up to keep files/bitrates with better compression and PQ and it has little impact on the system. You can tune this to get much better quality and still easily do better than real-time with two simultaneous encodes. Not fine tuning the HW encode is just a waist since it can only due 2 streams and won't even use 50% of the GPU. Hopefully that makes sense. So basically in a nut shell, many of us would want to use something like "slow" or "very slow" equivalents via Hardware but want to use "fast" or "very fast" with CPU. So we'll try to always use the HW first if possible but fall back to CPU when it has to, but each would be tuned the way we need it on our system. Make sense? 3
roberto188 33 Posted March 29, 2018 Posted March 29, 2018 That would be fine. What I'm saying is to have defaults for BOTH the CPU and for the HW transcoding. I know I'd prefer to have different settings between the two so mapping them to appear the same isn't good. For example I'd want to use a better setting for the preset for the hardware but may want fast or even very fast for CPU. With NVENC for example using one of the better profiles can cut file size nearly in half (less bandwidth as well) and comes much closer to CPU sizes without a huge impact on time (especially compared to CPU overhead). But if it's mapped then we can't have a "slow" setting for hardware and a fast or very fast for CPU. With NVENC we only get 2 streams on consumer GPUs so it's best to set this up to keep files/bitrates with better compression and PQ and it has little impact on the system. You can tune this to get much better quality and still easily do better than real-time with two simultaneous encodes. Not fine tuning the HW encode is just a waist since it can only due 2 streams and won't even use 50% of the GPU. Hopefully that makes sense. So basically in a nut shell, many of us would want to use something like "slow" or "very slow" equivalents via Hardware but want to use "fast" or "very fast" with CPU. So we'll try to always use the HW first if possible but fall back to CPU when it has to, but each would be tuned the way we need it on our system. Make sense? Having the flexibility to set both the CPU and Hardware profiles would be ideal.
roberto188 33 Posted March 29, 2018 Posted March 29, 2018 (edited) @@Luke If this is acceptable, i'll write the code and ask for some beta tester in another thread. I"ll map it as following slow, slower, veryslow = slow medium = medium All other = fast I'll test it. Edited March 29, 2018 by roberto188
roberto188 33 Posted March 29, 2018 Posted March 29, 2018 (edited) Luke, how is the bob & weave option inserted into the encoding config file?Nevermind. <DeinterlaceMethod>bobandweave</DeinterlaceMethod> Edited March 29, 2018 by roberto188
