Degsy41 0 Posted March 5, 2018 Posted March 5, 2018 Hi, Does anyone know if the PCTV 460e DVB-S2 tuner is compatible with the Emby server or could be made to work? I have two connected to my Synology DS1511+ but Emby is not detecting them. thanks
Luke 42241 Posted March 5, 2018 Posted March 5, 2018 Hi, we don't support this tuner natively. The good news is you can most likely still use it with Emby via other software. What you could do is install tvheadend, get that working, and then install the Tvheadend plugin for emby. Please let us know if this helps. Thanks.
Degsy41 0 Posted March 5, 2018 Author Posted March 5, 2018 Thanks for the advice Luke. Ill give that a go. Are there plans to support this tuner in the future?
