medarion 1 Posted March 3, 2018 Posted March 3, 2018 Since the upgrade to version 3.3.0.0 some of my videos won't play, when transcoding is required. The issue is related to this thread: https://emby.media/community/index.php?/topic/48628-too-many-packets-buffered-for-output-stream-00/ and this known regression in ffmpeg: https://trac.ffmpeg.org/ticket/6375 which is apparently not fixed in recent versions. Here are the logs: server-log.txt transcoding-log.txt As suggested in the ffmpeg bug report, it helps to increase -max_muxing_queue_size. Is it possible to adjust the ffmpeg params which emby uses in some config file?
Luke 42246 Posted March 3, 2018 Posted March 3, 2018 Hi, we don't have a setting for this, no. Can you provide a sample video for testing? Thanks.
medarion 1 Posted March 4, 2018 Author Posted March 4, 2018 Here is a shorter version of the file in question: https://oemus.net/public/test.m4v
Luke 42246 Posted March 4, 2018 Posted March 4, 2018 Strange. In my test I had no problem with this file - both in a remux example as well as a full transcode.
medarion 1 Posted March 4, 2018 Author Posted March 4, 2018 That's unfortunate. Did you test it on Windows? Maybe it only happens on Linux. It's also unrelated to hardware transcoding, I just tried it without. I guess I have to wait until it is fixed upstream or manually reencode the source file.
medarion 1 Posted March 4, 2018 Author Posted March 4, 2018 In case someone else stumbles upon the same problem: here it was sufficient to reencode the audio streams (in contradiction to ffmpeg saying somethong ebout stream #0!), while reencoding the video and copying the audio did not help. So after doing: ffmpeg -fflags +genpts -i test.m4v -map 0 -c:v copy -c:a aac -max_muxing_queue_size 4000 out.m4v Emby was able to play/transcode the file.
pueex 0 Posted May 16, 2018 Posted May 16, 2018 happens to me as well. i run from docker, do i need to take an older version of ffmpeg and replace the ffmpeg on the docker ?
Luke 42246 Posted May 16, 2018 Posted May 16, 2018 happens to me as well. i run from docker, do i need to take an older version of ffmpeg and replace the ffmpeg on the docker ? Hi there, best thing to do is discuss an example and attach the information requested in how to report a problem. thanks !
blastbass 0 Posted July 2, 2018 Posted July 2, 2018 Hello, Where i can add this parameters to use with emby ? I've this problem with many files and the same error.
Luke 42246 Posted July 2, 2018 Posted July 2, 2018 Why don't you start by seeing how to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
blastbass 0 Posted July 3, 2018 Posted July 3, 2018 (edited) Yes luke, of course. You have 2 example of files (in the logs) who doesn't works, and one with no problem. The problem is the same on all devices : Phone, web or TV. Log_film_OK2.txt Log_film_OK.txt Log_KO.txt Log_transcode_KO.txt Log_transcode2_KO.txt Log_another_film_KO.txt Edited July 3, 2018 by blastbass
Luke 42246 Posted July 6, 2018 Posted July 6, 2018 @@Waldonnis what do you make of these errors? ffmpeg version 3.4.2 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) libpostproc 54. 7.100 / 54. 7.100 [matroska,webm @ 0xf074c0] Format matroska,webm detected only with low score of 1, misdetection possible! configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --cc=x86_64-pc-linux-gnu-gcc --cxx=x86_64-pc-linux-gnu-gcc --arch=x86_64 --prefix=/srv/buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-ffserver --disable-xlib --enable-fontconfig --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --extra-libs='-ldl -lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -luuid -lgmp -lhogweed -lnettle -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static --enable-gnutls --enable-libsmbclient --enable-cuda --enable-cuvid --enable-nvenc --enable-vaapi [matroska,webm @ 0xf074c0] Read error at pos. 1 (0x1) libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavcodec 57.107.100 / 57.107.100 [matroska,webm @ 0xf074c0] EBML header parsing failed @@blastbass
Waldonnis 148 Posted July 8, 2018 Posted July 8, 2018 Looks like a malformed mkv...or maybe not really an mkv file at all. I've seen people on the Internet recommend just changing file extensions on video files before (from mp4 to mkv), so it wouldn't surprise me if this wasn't actually a Matroska file at all. Another possibility is that the file wasn't finished writing (doubtful, since position 1 is where it hit an error on one file)...or that there's a disc problem where the file is stored. Fortunately, checking to see if a file really is a Matroska container is really easy. If you're on Linux, you can just use 'head file.mkv' and the first line of the output should have the string "matroska" in there. If you're on Windows, using 'type file.mkv | more' should show the string as well in its first page of output. If it's actually an mp4, you'll probably see 'mp4' in the first few lines of output instead. If the file extension is wrong for the type of file it is, renaming it properly should do the trick. If it is actually a mkv after all, then it's either corrupted or there's a disc problem where it's stored. In either case, you can try to copy it somewhere else and see if the problem persists...but it may not be recoverable if the file is too badly damaged. Oh, one other thing you can try is remuxing it with something like MKVToolNix. It's usually pretty good about detecting the real container type (if it's wrongly named) and the remux may fix any errors in the container of the original file. 1
blastbass 0 Posted July 9, 2018 Posted July 9, 2018 Thanks you very much @Waldonnis and @@Luke for you investigation. I will check this.
