Android TV - 1 Mbps & 1.5 Mbps settings swapped
cybergrimes
Hey, testing remote rate quality when I noticed that the 1 Mbps setting plays at 1.5Mbps and the 1.5 Mbps setting plays at 1 Mbps. They appear out of order in the list too, which is actually the correct order if you go by the result... hope that makes sense ; )
I'm on beta now but noticed this a week ago when still using release version.
  • Like 1
