Kodi favorites issue
xbmcgotham
Cant seem to add favourites anymore to kodi’s favourites. How do I set this up so I can use favourites again in Kodi with emby data? Any specific configuration that needs to be followed initially?
Angelblue05
No. It should just work. That's default Kodi behavior, the add-on does not interfere. There's no crossing between emby favorite and kodi favorite. If you want to use favorite on emby, then context menu > emby options > add to favorites.
xbmcgotham
Hi, I think I found the problem. For some reason not always a xml file is correctly saved (Mac or windows) and Kodi has problems reading the file. By completely deleting the file again and letting kodi rewrite it, showed to solve the issue.
Is their anyway to combine emby favourites with Kodi favourites. makes more sense to sync them.
Angelblue05
Which xml? No. Kodi has no api for favorites.
xbmcgotham
pity. was handy. :-)
Guest
