crazybbs 24 Posted March 2, 2018 Posted March 2, 2018 Hi, My audio setting inside Theater are back to default and I cant't check any passthrough anymore the setting are not saved and the audio settting page keep over when I go back Anyone else get the same error? Any solution @@Luke
Luke 42243 Posted March 2, 2018 Posted March 2, 2018 Sorry I don't quite understand what you're trying to say but I'm able to access the settings and save without any problem.
crazybbs 24 Posted March 2, 2018 Author Posted March 2, 2018 well it's hard to explain but like I said I've audio , video and madvr video setting who doesn't work, it's coming over ui and I can't change anything I wanted to test to switch language of ET in case it could be an issue , how I can switch display language now?
crazybbs 24 Posted March 2, 2018 Author Posted March 2, 2018 nvm reinstalled from website and setting are ok now Thank you
Guest asrequested Posted March 2, 2018 Posted March 2, 2018 @@crazybbs If you haven't yet seen, MadVR is about to be removed from Theater.
crazybbs 24 Posted March 2, 2018 Author Posted March 2, 2018 I dont't use it , I was just saying all this 3 settings had problem. short story @@Luke, I found my main problem , I wasn't able to play anything and was trying to know why. I finally found that I had enabled cinema mode to try it but getting stuck loading the trailer failed on mpv logs thank you now everything back to the normal
Guest asrequested Posted March 2, 2018 Posted March 2, 2018 Ah yeah. I had an issue with it not getting past a trailer of Justice League. Eventually it would stop trying and go back to the details page.
