nicko84 72 Posted March 1, 2018 Posted March 1, 2018 Hello everyone, My old HP remote control is out of order. I'm looking for a good remote for ET. I'm waiting for your advice ! Thanks
Guest asrequested Posted March 1, 2018 Posted March 1, 2018 I have a harmony hub and companion remote. It works really well. But it doesn't have a home button. One of the upper models probably does. If that matters?
waldoverkill 0 Posted March 1, 2018 Posted March 1, 2018 ++ for harmony. Works great. I use the Menu button for home.
Jdiesel 1435 Posted March 1, 2018 Posted March 1, 2018 FLIRC and any remote that you like. I personally use a FLIRC and this Zidoo remote on both my Shield TV and my HTPC https://www.amazon.com/Zidoo-Remote-Control-Shortcut-Learning/dp/B01CTOFWSY/ref=cm_cr_arp_d_product_top?ie=UTF8
Guest asrequested Posted March 1, 2018 Posted March 1, 2018 ++ for harmony. Works great. I use the Menu button for home. I can't find the home function in the setup menu. Are you using a shortcut?
waldoverkill 0 Posted March 1, 2018 Posted March 1, 2018 I think I set the menu key to press the keyboard home key (I am using bluetooth to connect the harmony hub to the media center)
Guest asrequested Posted March 1, 2018 Posted March 1, 2018 I'm using Bluetooth, but I can't find any option for home key. I may try making a sequence, and see if I can 'make' the button.
