lai 0 Posted March 1, 2018 Posted March 1, 2018 FLAC not playing on LG SMART TV OLED65E7PFLAC files that play when on the TV USB stick do not play when using EMBY LG Smart TV client.Tries, gives up, tries next track on album, gives up again, until end of album.Server Log attachedEmby Server 3.3.0 (nor on 3.2.70)Thanks server-63655440376.txt
Luke 42237 Posted March 22, 2018 Posted March 22, 2018 Emby for LG 1.06 has just been released. Please try it out. Thanks !
lai 0 Posted March 22, 2018 Author Posted March 22, 2018 Luke, Thanks. I tested. On TV it seems better - no error loop thru all albuns (Error screen stops on OK/Done button ---Playback Error: No compatiple Streams found). On Server - no direct play stream found for flac. Enclosed server log. server-63657323436.txt
Luke 42237 Posted March 22, 2018 Posted March 22, 2018 Hi @@lai, on server, what do you mean? Are you referring to using the web app? Thanks.
lai 0 Posted March 22, 2018 Author Posted March 22, 2018 Hi Luke, Just peeked at the server log I enclosed and saw the Direct Play messages ... on Dashboard - Recent Activity just messages like those below (timestamps below differ from those on log): dvr boss has stopped playing Miguel Proença - Gnatalli: Alma Brasileira 3/22/2018, 3:05:26 pm App: Emby Theater, Device: LG Smart TV dvr boss has started playing Miguel Proença - Gnatalli: Alma Brasileira 3/22/2018, 3:05:26 pm App: Emby Theater, Device: LG Smart TV
Luke 42237 Posted March 22, 2018 Posted March 22, 2018 I don't quite understand. Is there a problem, or no?
lai 0 Posted March 22, 2018 Author Posted March 22, 2018 Yes... flac files still do no play on the LG webos app. After the LG app update now the symptom on TV is different -- after selecting a flac file to play, TV tries to load, does not play and display a modal error message on tv screen PLAYBACK ERROR: NO Compatible streams found and a DONE button which if pressed repeats the this cycle tries to play, display the error message stops-- (before the app update, the app on TV would loop thru all flac files without playing, and sometimes the app would crash after a certain number of files).
Kramadana 0 Posted April 1, 2018 Posted April 1, 2018 I can con confirm latest wont play flac files back.
Luke 42237 Posted April 1, 2018 Posted April 1, 2018 It's resolved for the next release of the app, thanks.
andyblac644 69 Posted April 5, 2018 Posted April 5, 2018 As soon as LG approves it. around June / July then
lai 0 Posted May 20, 2018 Author Posted May 20, 2018 (edited) New version of Emby LG App is out (V 1.0.7 09/04/2018). Tested and it is playing flac files now.. No problems noticed. Thanks to the great dev/support team at Emby Edited May 20, 2018 by lai
medric 5 Posted April 12, 2019 Posted April 12, 2019 okay i still can not play a mkv with flac audio with not subtitle ( i thought it was subtitle base) i have the latest version of emby app 1.0.15 emby server 4.0.3.0 synology 6.2 lg webos tv UH8500 software version 5.30.30 i have a lot of videos with mkv and flac that have all stream and kills the server. if there is anything i can do to add to profile would be greatly appreciated or is an webos fault
Luke 42237 Posted April 12, 2019 Posted April 12, 2019 okay i still can not play a mkv with flac audio with not subtitle ( i thought it was subtitle base) i have the latest version of emby app 1.0.15 emby server 4.0.3.0 synology 6.2 lg webos tv UH8500 software version 5.30.30 i have a lot of videos with mkv and flac that have all stream and kills the server. if there is anything i can do to add to profile would be greatly appreciated or is an webos fault Is it trying to direct play it?
medric 5 Posted April 12, 2019 Posted April 12, 2019 the logs are so big let me try and pull it and upload it.
medric 5 Posted April 22, 2019 Posted April 22, 2019 Here is my log when i play Flac files it always transcode ffmpeg-transcode.txt
Guest Posted April 22, 2019 Posted April 22, 2019 I have a large collection of FLAC songs and to not transcode, just change the extension of the files to MP4.The file does not lose size and does not lose quality and reproduces in Emby, LG TV, without transcoding and with excellent audio quality.
Luke 42237 Posted April 24, 2019 Posted April 24, 2019 Here is my log when i play Flac files it always transcode @@medric, we did what we had to do, because previously they were failing with the LG audio player when direct playing. @@SamES can provide more information. Thanks.
SamES 1084 Posted April 28, 2019 Posted April 28, 2019 Here is my log when i play Flac files it always transcode It's transcoding as it's failing during playback so we fallback to transcoding rather than giving a 'No playable streams' error. The problem is that the maximum supported profile level for H.264 @ 1920x1080@60P is 4.2. Your video is Level 5.0 (50). I don't think 10-bit 1080 content is supported. {"Codec":"h264","Language":"eng","ColorSpace":"bt709","TimeBase":"1/1000","CodecTimeBase":"1001/48000","VideoRange":"SDR","DisplayTitle":"1080p H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":7357647,"BitDepth":10,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"High 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p10le","Level":50,"IsAnamorphic":false} http://webostv.developer.lge.com/discover/specifications/supported-media-formats/webos-40/ It is not the audio that is the problem, it is the video. To confirm this I disabled FLAC support which should cause it to only convert the audio (DirectStream) instead of a full transcode. It does attempt this, but still throws an error on the video stream which causes it to transcode. Sorry, there is nothing we can do to prevent this as it is outside the LG spec for this type of video. But I can confirm that in your case, the video is the problem, not the audio. @@Luke, ideally we need to be able to limit the profile/level based on resolution and codec as the LG spec is 4.2 for 1080/h.264 and 4.1 for 1080/hevc but 5.1 for 2160 content. On Samsung this also transcodes with transcode reason 'Video profile not supported'. Not sure why this is being detected differently. This is my test sample which is similar to yours http://192.168.1.222:8096/emby/videos/288204/hls1/main/0.ts?DeviceId=2da01462cc276ae31f8b967de7e274e60eb5767a&MediaSourceId=1a05065b1324e21de775a5bea6af5d8a&PlaySessionId=d75dfb2c63d445e5ab96e3e536121832&api_key=b26c77e8df77485eaa7b2eaa15fa2b8f&VideoCodec=h264,h265,hevc&AudioCodec=ac3,eac3,aac,mp3&VideoBitrate=139808000&AudioBitrate=192000&AudioStreamIndex=1&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=False&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=51&TranscodeReasons=ContainerBitrateExceedsLimit&allowVideoStreamCopy=false {"Protocol":"File","Id":"1a05065b1324e21de775a5bea6af5d8a","Path":"\\\\10.55.1.2\\Media\\Demos\\Test Files\\flac_mkv\\[MK-Pn8] Sword Art Online II - 07v2 [bD 1080p][Hi10][Dual][E3858ED0].mkv","Type":"Default","Container":"mkv","Size":0,"Name":"[MK-Pn8] Sword Art Online II - 07v2 [bD 1080p][Hi10][Dual][E3858ED0]","IsRemote":false,"RunTimeTicks":14232970240,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"h264","ColorTransfer":"bt709","ColorPrimaries":"bt709","ColorSpace":"bt709","TimeBase":"1/1000","CodecTimeBase":"1001/48000","Title":"[sS] h264 Hi10 1080p","VideoRange":"SDR","DisplayTitle":"1080p H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":6621111,"BitDepth":10,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"High 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p10le","Level":51,"IsAnamorphic":false},{"Codec":"flac","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"[MK] FLAC 2.0ch","DisplayTitle":"English FLAC stereo (Default)","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"stereo","BitDepth":24,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"flac","Language":"jpn","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"[sS] FLAC 2.0ch","DisplayTitle":"Japanese FLAC stereo","DisplayLanguage":"Japanese","IsInterlaced":false,"ChannelLayout":"stereo","BitDepth":16,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"ass","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"[MK] Signs","DisplayTitle":"English (Default ASS)","DisplayLanguage":"English","IsInterlaced":false,"IsDefault":true,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Level":0},{"Codec":"ass","Language":"jpn","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"[MK] Full Subtitles","DisplayTitle":"Japanese (ASS)","DisplayLanguage":"Japanese","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":4,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Level":0},{"Codec":"mjpeg","ColorSpace":"bt470bg","TimeBase":"1/90000","CodecTimeBase":"0/1","IsInterlaced":false,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":900,"Width":900,"RealFrameRate":90000,"Profile":"192","Type":"EmbeddedImage","AspectRatio":"1:1","Index":6,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuvj444p","Level":-99,"IsAnamorphic":false}],"Formats":[],"Bitrate":6621111,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false}
SamES 1084 Posted April 28, 2019 Posted April 28, 2019 (edited) @@Luke, web0s also detects as browser.chrome so '|high 10' is being added when it shouldn't be. This doesn't stop transcoding, but it explains why it attempts to DirectPlay. Edited April 28, 2019 by SamES
