memetopal 2 Posted February 26, 2018 Posted February 26, 2018 Hi everybody. Already posted in another thread, but I thought I would start a new topic as my issue is persisting on the new server version 3.3.0.0. I have an Xpenology system where Emby seems to be preventing the hard drives entering hibernation. When Emby is not running, disks behave as expected and go to sleep after the specified period of inactivity. Already tried deactivating DLNA with no luck. Any ideas on what might be happening? Should i upload some kind of log? If so, could you indicate me how to proceed, as i am kinda noob? Thanks in advance.
Luke 42241 Posted February 26, 2018 Posted February 26, 2018 Hi, can you please attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
memetopal 2 Posted February 26, 2018 Author Posted February 26, 2018 Here it goes. Hope i did it correctly. Emby Log.txt
Luke 42241 Posted February 26, 2018 Posted February 26, 2018 Try disabling the automatic port mapping feature under Advanced. Please note this may require you to configure your router for external access.
memetopal 2 Posted March 2, 2018 Author Posted March 2, 2018 Hi. I think that might have solved it, as now disks do enter hibernation, however i've seen in the 'Log Center' that they keep waking up every 1 or 2 hours. Does anyone know how could i check what are the causes of this, if its due to Emby or any other app or system event? Thanks in advance.
Luke 42241 Posted March 2, 2018 Posted March 2, 2018 What was the solution?As far as determining the cause of the wake, @@solabc16 may know the answer to that. Thanks !
memetopal 2 Posted March 2, 2018 Author Posted March 2, 2018 What was the solution? As far as determining the cause of the wake, @@solabc16 may know the answer to that. Thanks ! It seems that disabling automatic port mapping, as you suggested. Thank you, by the way!
solabc16 379 Posted March 6, 2018 Posted March 6, 2018 Hello @@memetopal Glad that solved it, let me know if you need any further assistance with the system not hibernating. We made a handful of improvements during the course of last year, to address issues with Emby Server preventing hibernation 'out of the box'. Typically now, if the system isn't hibernating and stopping Emby Server resolves it, the most likely cause will be because it's writing something to the log - so this is the first place to check : Dashboard -> Expert-> Logs You may have noticed the additional text we added here:- Best - James
Luke 42241 Posted March 6, 2018 Posted March 6, 2018 The next server release will also further reduce some Info logging slightly as i did a small review of that. 1
memetopal 2 Posted March 7, 2018 Author Posted March 7, 2018 (edited) @@solabc16 @@Luke Thank you both for your response and the constant improvements in Emby. Checking the logs i think i have found the problem: by default, there is a scheduled task to 'convert media' every 3 hours (more or less the time when my disks wake up). As i don't need this task, i´ll deactivate it and see what happens. I will give it some time and report the results i get. Edited March 7, 2018 by memetopal
memetopal 2 Posted March 8, 2018 Author Posted March 8, 2018 @@solabc16 @@Luke Thank you both for your response and the constant improvements in Emby. Checking the logs i think i have found the problem: by default, there is a scheduled task to 'convert media' every 3 hours (more or less the time when my disks wake up). As i don't need this task, i´ll deactivate it and see what happens. I will give it some time and report the results i get. Yep. That was it. Now my nas sleeps like a baby. Thank you.
solabc16 379 Posted March 19, 2018 Posted March 19, 2018 Thanks for the update @@memetopal, glad to hear hibernation is now working for you as expected. Best - James
