Turboschnecke 2 Posted March 3, 2018 Author Posted March 3, 2018 (edited) No. From about 800 only three shows are imported from emby for kodi... All habe a correct tvdb ID and they are avaiable via the emby web client Edited March 3, 2018 by Turboschnecke
Solution Angelblue05 4132 Posted March 3, 2018 Solution Posted March 3, 2018 (edited) @@Turboschnecke The only reason why they are not available in Kodi is because we have a verification in place to detect/remove empty shows. To temporarily fix your issue, add-on settings > sync options > Enable Sync empty TV shows. You can then do a repair for your tv shows only and get your content added by launching the emby for kodi add-on > repair database > tv show. Edited March 3, 2018 by Angelblue05 1
Turboschnecke 2 Posted March 7, 2018 Author Posted March 7, 2018 "Enable Sync with empty TV Shows" seems to work! I see every show with their episodes and i can watch them! Thanks a lot!!! 1
Luke 42241 Posted March 7, 2018 Posted March 7, 2018 I am looking into it, thanks. I wouldn't go so far as adding those options. 1
lordsiris 2 Posted April 3, 2018 Posted April 3, 2018 @@Luke we really can not fix this? On well, I will add an option to show empty TV show to EmbyCon also. Any other option for us embycon users (great addon btw, stumbled across it a couple weeks ago and for my use case I like it much better than e4k) as I seem to be experiencing the issue as well. Noticed it mostly with my Emby DVR library (hdhomerun record source) and not showing episodes even though they are shown in the emby web gui and can be played. Would send logs but it's currently not occuring but sounds like the issue has been sourced. Thanks again!
Angelblue05 4132 Posted April 3, 2018 Posted April 3, 2018 (edited) @@lordsiris Could you please start a new thread so null_pointer can see it, thank you. Edited April 3, 2018 by Angelblue05
lordsiris 2 Posted April 4, 2018 Posted April 4, 2018 I added a new option to EmbyCon to show empty folders, this includes shows, seasons, boxsets Beta 1.4.64 is now available Wow. Fast! Thanks, I will start a new thread as there may be an issue with the beta. 1
