densma 12 Posted February 26, 2018 Posted February 26, 2018 All of a sudden refresh running more than 6 hours. I haven't started the server but what's the issue and how can i fix it? Thanks
Nick D_CA 0 Posted April 1, 2018 Posted April 1, 2018 Did you figure out the issue? I have the same problem, over 12 hours running and the guide refresh it's only at 60% on a pretty speedy machine.
Luke 42269 Posted April 1, 2018 Posted April 1, 2018 Did you figure out the issue? I have the same problem, over 12 hours running and the guide refresh it's only at 60% on a pretty speedy machine. Hi there @, please see post #2, thanks !
Nick D_CA 0 Posted April 1, 2018 Posted April 1, 2018 Hi there @, please see post #2, thanks ! Are you just looking for server logs? I was hoping since the original post was a month old they might have figured it out without me have to scrub a giant log file.
Luke 42269 Posted April 7, 2018 Posted April 7, 2018 How many channels do you have? it looks like a really big number, probably because according to the log they aren't actually channels but they each correspond to a movie or specific video.
Nick D_CA 0 Posted April 7, 2018 Posted April 7, 2018 How many channels do you have? it looks like a really big number, probably because according to the log they aren't actually channels but they each correspond to a movie or specific video. I am not sure the exact number but yes, there is a very large number. (I have my vote in for added category filtering on the Live TV section and now you can see why.) Is there a limit to the amount that Emby supports? My IPTV provider has many VOD and time shifting options which add up for all the extra channels. Is there a better place in Emby I should be adding these? (I don't know where else to add a m3u stream)
Nick D_CA 0 Posted April 7, 2018 Posted April 7, 2018 I just checked and there are 19472 channels and the EPG is 40,502 KB.
Luke 42269 Posted April 8, 2018 Posted April 8, 2018 There's not a limit, but right now it's not quite made to handle ~ 20k channels. It's something we can look at improving. If you can send me your m3u I'll look at it myself. Thanks.
Nick D_CA 0 Posted April 9, 2018 Posted April 9, 2018 Attached are the M3U and EPG files. TVService.zip
jamessouth 1 Posted July 9, 2021 Posted July 9, 2021 I know it's nearly 3 years later but was there any improvements delivered here? I'm sitting currently with ~4500 channels and the guide takes a very long time to update and also kills the responsiveness of the server despite low CPU.
Carlo 4561 Posted July 9, 2021 Posted July 9, 2021 Yes there was improvements made for loading guide data but 4500 channels is a ridiculous amount of channels no one could ever possibly use. Slim your channels down to something reasonable that you would actually use. I'm sure you have mostly channels in foreign languages or VOD like content that can get the boot.
Luke 42269 Posted July 9, 2021 Posted July 9, 2021 You don't necessarily have to modify the source of the channels. If you can reduce the number of channels that you import by disabling the ones you don't need in Emby Server channel management, then the refresh guide process will be faster. 1
muppet4k 10 Posted May 21, 2022 Posted May 21, 2022 On 7/9/2021 at 6:56 PM, Luke said: You don't necessarily have to modify the source of the channels. If you can reduce the number of channels that you import by disabling the ones you don't need in Emby Server channel management, then the refresh guide process will be faster. Where can i do this? How can i select more channels or groups at the same time? Thank you
Luke 42269 Posted May 22, 2022 Posted May 22, 2022 6 hours ago, muppet4k said: Where can i do this? How can i select more channels or groups at the same time? Thank you Hi, by unchecking the channels in the live TV channel management screen.
skrilla 0 Posted January 24, 2025 Posted January 24, 2025 has this been improved at all in the years since? i have the same m3u/xmltv file used in Kodi and the guide sync takes about 30 seconds first time and 2-3 for subsequent updates unless i miss a few days then its like 30 seconds or so, emby however takes 4-9 hours atleast, i believe i trimmed the VOD's and whatnot using my editor but there is alot of channels, is there any way i can make this run faster? not sure what all else it needs to do after initial scan, mostly just new epg info but wouldn't that be fairly easy to update?
Luke 42269 Posted January 30, 2025 Posted January 30, 2025 On 1/24/2025 at 5:58 PM, skrilla said: has this been improved at all in the years since? i have the same m3u/xmltv file used in Kodi and the guide sync takes about 30 seconds first time and 2-3 for subsequent updates unless i miss a few days then its like 30 seconds or so, emby however takes 4-9 hours atleast, i believe i trimmed the VOD's and whatnot using my editor but there is alot of channels, is there any way i can make this run faster? not sure what all else it needs to do after initial scan, mostly just new epg info but wouldn't that be fairly easy to update? Hi, yes it has. Have you tried with the latest version?
