kanipek 230 Posted February 26, 2018 Posted February 26, 2018 Just curious about images using XMLTV vs. SD-json images Using XMLTV some of the recording schedule thumbs and series posters are "zoomed" in, while using SD-json they appear correct or normal. It isn't consistent across all scheduled recordings either, some are displayed correctly and some are "zoomed". Same issue with the series artwork on the series tab some are correct posters and others look to be "zoomed" thumbs. I don't see these issues using the SD-json data. What is the cause of this? Attached a couple of examples Is there a reason that existing user library images can't be used for these images? Provided they already exist in the users library. I like to use to XMLTV data vs. json because I get more detailed info in the EPG - premieres are shown correctly is one example (I do have that option selected using json for me it doesn't work) Thanks!
Luke 42206 Posted February 26, 2018 Posted February 26, 2018 On those screens yes, using the images from your library is something we should look to do in the future but right now it just uses whatever you have from your guide data source.
