fonzie 23 Posted February 25, 2018 Posted February 25, 2018 I'm using the Emby beta plugin for Kodi set to Add-on mode. I have some movies with multiple qualities (4K and 1080p) so when I am browsing the library and select a movie, a window pops up asking which file I want to play. That is working perfectly. The issue I'm having is that when I try to do the same exact thing from the widgets on the homescreen, it asks me which quality I want to play. Loads for a second after I select it, and then the window pops up again asking which quality I want. The second instance will start the movie, but it starts playing it in the background and gives me errors with refresh rate switching and HDR (this doesn't happen when selecting that same movie from within the library). It happens with any skin I select. I reproduced the error with the default skin Estuary and have attached the log. Thanks kodi.log
Angelblue05 4132 Posted February 25, 2018 Posted February 25, 2018 Thank you for providing your log. I see where the issue is, I've added additional logging. Can you capture one more log for me? I don't have the same behavior, something must be slightly different. Thank you plugin.video.emby-3.0.12a.zip 1
fonzie 23 Posted February 25, 2018 Author Posted February 25, 2018 (edited) Sure I can. Is there a specific action you'd like me to take when providing the log or do you just want me to reproduce the error? edit: I noticed you attached an updated zip. Do I overwrite the old one with this one and try again? Edited February 25, 2018 by fonzie 1
Angelblue05 4132 Posted February 25, 2018 Posted February 25, 2018 (edited) Just reproduce the error thank you Edit: Use the build provided, restart Kodi. Edited February 25, 2018 by Angelblue05 1
fonzie 23 Posted February 25, 2018 Author Posted February 25, 2018 (edited) I reproduced it with another movie. It still prompted me for quality selection twice, but this time it didn't play in the background and HDR did come on properly. Edit: just noticed that you want me to try it with the build you linked. I will try again with 3.0.12a and report back kodi.log Edited February 25, 2018 by fonzie 1
Angelblue05 4132 Posted February 25, 2018 Posted February 25, 2018 Did you restart Kodi? I don't see the new log lines I added hmm.
fonzie 23 Posted February 25, 2018 Author Posted February 25, 2018 Here's the new log using the updated zip file you linked. It isn't playing in the background anymore, but it still prompts for quality selection twice. kodi.log 1
Angelblue05 4132 Posted February 25, 2018 Posted February 25, 2018 Thank you, give me a bit. Making a test build. 1
Angelblue05 4132 Posted February 25, 2018 Posted February 25, 2018 Give this a try, let me know. plugin.video.emby-3.0.12a.zip 1
fonzie 23 Posted February 26, 2018 Author Posted February 26, 2018 I feel like you're getting closer to resolving it. This time when I click the movie, it will start playing after I select the quality on the 1st attempt, but then the second quality prompt comes up over the movie and if I select cancel or press back, it will stop the movie and say that playback has failed. If I select the quality first, the movie will start playing and then the quality prompt comes up again, I can select the quality for a second time and the movie will continue playing without any further interruption. I used both of the methods above and attached a log file. kodi.log 1
Angelblue05 4132 Posted February 26, 2018 Posted February 26, 2018 (edited) @@fonzie Test this one for me. i suspect it will correct the double prompt. However, can you let me know if the artwork in the OSD seem to display correctly? The behavior between our kodi seem to differ slightly so I'll probably ask you to test another build after this, with a final fix. Thank you plugin.video.emby-3.0.12a.zip Edited February 26, 2018 by Angelblue05
fonzie 23 Posted February 26, 2018 Author Posted February 26, 2018 The last build worked. No more double prompt. The artwork displays properly on the OSD as well. Thanks a bunch for such a quick response! 1
