joggs 24 Posted February 25, 2018 Posted February 25, 2018 (edited) I am having a couple of playback problems on my philips android tv, using emby for android tv. It has worked well for a long time, but recently the server has started transcoding due to a not supported bitrate, that I think have worked well earlier. Even more recently, I cannot play the video at all. I attached a log, where I can see that a null reference error is thrown when I try to start the playback of vikings season 5 episode 1: System.NullReferenceException: Object reference not set to an instance of an object. at MediaBrowser.Model.Dlna.StreamBuilder.GetVideoDirectPlayProfile (... I am getting the same error for all other videos as well. My other clients play everything as expected, such as emby for android (phone), embycon on libreelec on RPi, emby for kodi and the web client. server-63655188528 - Copy (2).txt Edited February 25, 2018 by joggs
joggs 24 Posted February 25, 2018 Author Posted February 25, 2018 Solved. I reinstalled the app a second time in pure desperation, and everything is working well again. Based on the server exception, I'm not sure why a reinstall helped, especially the second time :-)
joggs 24 Posted February 26, 2018 Author Posted February 26, 2018 (edited) A new server beta update was released today. After installation, the videos are transcoded duet to audio incompatibility. Doesn't matter if i reinstall the app. Edited February 26, 2018 by joggs
Luke 42245 Posted February 26, 2018 Posted February 26, 2018 A new server beta update was released today. After installation, the videos are transcoded duet to audio incompatibility. Doesn't matter if i reinstall the app. So this is correct?
joggs 24 Posted February 27, 2018 Author Posted February 27, 2018 Sorry, for missing details. No, I like to avoid transcoding and somehow I can directplay that video until i update the server. Aftter the server update, the same video is transcoded. It usually is solved by unistalling the androidtv client and install it again.
Luke 42245 Posted February 27, 2018 Posted February 27, 2018 Ok. @@ebr may want to collect some info to try and diagnose that.
ebr 16337 Posted February 27, 2018 Posted February 27, 2018 Sorry, for missing details. No, I like to avoid transcoding and somehow I can directplay that video until i update the server. Aftter the server update, the same video is transcoded. It usually is solved by unistalling the androidtv client and install it again. That really doesn't make a lot of sense so those actions may be coincidental. If you can reproduce it and then provide the server, ffmpeg and app log we can take a look. Thanks.
