Ice 23 Posted March 1, 2018 Posted March 1, 2018 Update on my issue.... As I mentioned above renaming my files to a more Emby friendly version fixed my problem, but what I failed to mention is that I also renamed those 2 WSBK subdirectories as well, I renamed 2018 to 18 and 2017 to 17. I thought I would do some more testing and instead of renaming the contents of the other directories I renamed the rest of the WSBK subdirectories to follow the changes in the structure which I just mentioned. I just did another Metadata update on the WSBK directory and now all my files are back. So it looks like the new server version doesn't allow for seasons which total in the 1000's if you know what I mean, where as the old version didn't have a problem with that
hd4fun 6 Posted March 1, 2018 Posted March 1, 2018 Hi Luke - just a thought Both ice and d00zah mentioned things that I do often as well. Many - not all my hard drives go to sleep when they are not used to save power. They are all on the same system as emby server - so direct attached or usb the server stays up all the time However - Because I can not edit the library folders - I delete them & then add them again After I rename and or move directories around between disks to optimize available space I haven't deleted any folders or moved directories on the 3.3.03 beta Since I've had the beta installed it has scanned every night and everything has stayed in place - for 3 nights
JAJ 11 Posted March 2, 2018 Posted March 2, 2018 My emby for WMC (windows 7) Library's are not displaying correctly, (I get no items available, on some and only partials movies or shows info on others).. since the 3.3 update, and scan media library gets stuck at 69.8%.
d00zah 152 Posted March 2, 2018 Posted March 2, 2018 (edited) My emby for WMC (windows 7) Library's are not displaying correctly, (I get no items available, on some and only partials movies or shows info on others).. since the 3.3 update, and scan media library gets stuck at 69.8%. Typical for an initial scan. Be patient, let it complete & everything should be restored. & you should probably post a server log for Luke to review. Edited March 2, 2018 by d00zah
Daithi 3 Posted March 3, 2018 Posted March 3, 2018 Can you grab the beta server and see if this continues to happen? thanks. Been on beta since 28th, so far so good. Thanks.
gwbaker 4 Posted March 4, 2018 Posted March 4, 2018 Thank you Luke for the help in the other treads!!! I have installed 3.3.0.5 beta. Not that I am much help, but figured I would report what I found. My libraries appear normal and my podcast is working, sorta. As another reported, my podcasts are back but they are not sorted by the different channels. All of the current episodes are in one big list. Happy to wait for the cure, especially after loosing my mind thinking I had done something!
Luke 42208 Posted March 4, 2018 Posted March 4, 2018 We'll be getting a new server release out today to correct this, thanks.
gwbaker 4 Posted March 5, 2018 Posted March 5, 2018 Seems to be all good now! YAY, thanks for the hard work. It took several hours for all the podcasts to show and sort, but once they did, we are back to normal. My issues are fixed, hope the same for all others.
Peter Nent 71 Posted March 5, 2018 Posted March 5, 2018 Just upgraded to EMBY v3.3.1.0 this morning, but seems that ALL Live-TV simply 'disappeared': I'm using the VU+ Live-TV solution which worked well until yesterday, but now: the plug-in is still installed, but at the Live-TV menu, everything disappeared.... HELP.
jasonwilliams 37 Posted March 5, 2018 Posted March 5, 2018 Hello, Same here - the only part of Live TV that is showing is Recordings. None of the Guide, Channels are there in 3.3.1.0.
Luke 42208 Posted March 5, 2018 Posted March 5, 2018 Your plugin might need an update. If the issue remains after that please see how to report a problem: https://emby.media/community/index.php?/topic/790-how-to-report-a-problem/?view=getnewpost Thanks.
Peter Nent 71 Posted March 5, 2018 Posted March 5, 2018 Just upgraded to EMBY v3.3.1.0 this morning, but seems that ALL Live-TV simply 'disappeared': I'm using the VU+ Live-TV solution which worked well until yesterday, but now: the plug-in is still installed, but at the Live-TV menu, everything disappeared.... HELP. After a lot of patience/waiting, resetting server, resetting the VU+UNO-4K box, etc., finally the Live-TV came back again and works normally....I'm lucky !? Greatz, Peter
jasonwilliams 37 Posted March 5, 2018 Posted March 5, 2018 Update: After some digging, I discovered that I accidentally deleted my M3U file when I upgraded to 3.3.1.0. Doh! I'm sure Live TV will work when I recreate it. Sorry for the false report.
Luke 42208 Posted March 5, 2018 Posted March 5, 2018 I'm going to lock this this thread now that the issue is resolved. If you have an issue we're happy to help. Please see how to report a problem. Thanks !
