Elenthil 4 Posted February 25, 2018 Posted February 25, 2018 here are my log file. server-63654790317.txt
Luke 42206 Posted February 25, 2018 Posted February 25, 2018 here are my log file. This particular log doesn't have any evidence of any mass deletions taking place. Do you have an earlier one from when that might have happened?
Elenthil 4 Posted February 25, 2018 Posted February 25, 2018 sorry, it was the wrong log, sry. here is the right one. server-63655194684.txt
Luke 42206 Posted February 25, 2018 Posted February 25, 2018 sorry, it was the wrong log, sry. here is the right one. Thanks. I think I may have found the cause of this. I will have a beta release up later tonight with the change. Can you please try that? thanks.
Luke 42206 Posted February 25, 2018 Posted February 25, 2018 Thanks. I think I may have found the cause of this. I will have a beta release up later tonight with the change. Can you please try that? thanks.
Elenthil 4 Posted February 25, 2018 Posted February 25, 2018 (edited) Write when you will have it ready, i install it in the morning and let run a library scan. It is now 0:00 a.m. here in germany and i sleep a little bit When i get up at 6:00 i look if you post something new here. Edited February 25, 2018 by Elenthil
d00zah 152 Posted February 26, 2018 Posted February 26, 2018 Update: Both aforementioned views are now listing content, although 'New and Upcoming Movies on Dvd & Blu-ray' seems remarkably thin with only 10 releases listed, and none from 2018. Thanks!
Luke 42206 Posted February 26, 2018 Posted February 26, 2018 @@d00zah i've merged your topic into here. thanks.
d00zah 152 Posted February 26, 2018 Posted February 26, 2018 Thanks. I think I may have found the cause of this. I will have a beta release up later tonight with the change. Can you please try that? thanks. My scan just finished & all my libraries have been restored. If I pass on this beta for now, what are the odds of this metadata 'purge' happening again?
Luke 42206 Posted February 26, 2018 Posted February 26, 2018 Difficult to say because i don't know for sure yet that my theory is right.
d00zah 152 Posted February 26, 2018 Posted February 26, 2018 (edited) Difficult to say because i don't know for sure yet that my theory is right. ` Fair enough. Will stay tuned. v3.3.0.3-beta? Edited February 26, 2018 by d00zah
needanewjob 0 Posted February 26, 2018 Posted February 26, 2018 (edited) I have the exact same issue. My libraries are missing all their data. I've tried removing one and readding it, and nothing came back. Interesting my "optional" share paths have also all disappeared from my media folders. Edited February 26, 2018 by needanewjob
Luke 42206 Posted February 26, 2018 Posted February 26, 2018 I have the exact same issue. My libraries are missing all their data. I've tried removing one and readding it, and nothing came back. Please attach the emby server log. you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
needanewjob 0 Posted February 26, 2018 Posted February 26, 2018 (edited) Attached server-63655189751.txt Edited February 26, 2018 by needanewjob
needanewjob 0 Posted February 26, 2018 Posted February 26, 2018 (edited) Looking at them, this might be the more interesting one to you. For some reason it defaulted my libraries to the programdata folder instead of to /mnt/media (which is what's displayed in the UI). Edited February 26, 2018 by needanewjob
Luke 42206 Posted February 26, 2018 Posted February 26, 2018 Attached Do you have any earlier logs? We need to try and look at when this happened. Thanks.
needanewjob 0 Posted February 26, 2018 Posted February 26, 2018 This is the earliest I have. It's the first log after upgrading to 3.3.0. I thought I posted it earlier, but apparently not. The attach functionality is a _two step_ process. :-p server-63655186391.txt
Luke 42206 Posted February 26, 2018 Posted February 26, 2018 This is the earliest I have. It's the first log after upgrading to 3.3.0. I thought I posted it earlier, but apparently not. The attach functionality is a _two step_ process. :-p Ok, your issue is different from the rest of this topic. I think what happened to you is you originally installed using our older install package based on opensuse. And then you installed our newer install package over the top of that. How long ago did you first install?
Elenthil 4 Posted February 26, 2018 Posted February 26, 2018 hi, is 3.3.0.2 the version to test? Or do you working on 3.3.0.3?
Luke 42206 Posted February 26, 2018 Posted February 26, 2018 hi, is 3.3.0.2 the version to test? Or do you working on 3.3.0.3? Yes you can try that version, thanks.
needanewjob 0 Posted February 26, 2018 Posted February 26, 2018 (edited) Ok, your issue is different from the rest of this topic. I think what happened to you is you originally installed using our older install package based on opensuse. And then you installed our newer install package over the top of that. How long ago did you first install? Ummmm....back when it was still Mediabrowser. Am I looking at a total loss here or any chance for salvaging? edit: Looks like I had the day off after Thanksgiving in 2014... cat /var/log/apt/history.log | grep -B 1 mediabrowser Start-Date: 2014-11-28 14:10:29 Commandline: apt-get install mediabrowser Edited February 26, 2018 by needanewjob
hd4fun 6 Posted February 26, 2018 Posted February 26, 2018 ok since I started the thread and have a meltdown with our aircons at work I haven't had a chance to get back all my media is gone again and it's scanning the library again - extremely slowly here are two logs 8:31 when emby v3.30 updated 00:00 when library scan started i believ I'll try to grab the 3.3.02 version and let you know 2018-02-24-20-31.Log 2018-02-25-00-00.Log
Elenthil 4 Posted February 26, 2018 Posted February 26, 2018 Media scan is still running with 3.3.0.2. Will report back when it is finished. It tooks a lot longer with 3.3.0.2 as with 3.3.0.0.
Luke 42206 Posted February 26, 2018 Posted February 26, 2018 Media scan is still running with 3.3.0.2. Will report back when it is finished. It tooks a lot longer with 3.3.0.2 as with 3.3.0.0. If the library was removed then it will take a while because it is essentially re-importing everything.
