mpm131 1 Posted February 24, 2018 Posted February 24, 2018 I am in need of some help. I am running Emby Server Version 3.2.70.18 beta on a Windows Home Server 2011. For some reason my library is getting deleted every couple of days and I wind up have to rebuild the library which takes a bit of time. This has happened about 4 times now over a week's time frame. I have tried deleting the library.db file and rebuilding and that did not seem to solve the problem. I have include the server logs and the media browser classis logs (running on the htpc). If you look roughly around 16:30 in the server logs you can see a bunch of deleting of entries going on. Is there a cleanup task going on that can be stopped? I appreciate any help that you can provide. Please let me know if you have any questions. Thanks, Mike server-63654988783.txt MBClassic-2322018a11b94498746477f85a00dad0e4ff68e.log
Luke 42206 Posted February 24, 2018 Posted February 24, 2018 Hi, can you please describe what you mean exactly by library getting deleted? thanks.
mpm131 1 Posted February 24, 2018 Author Posted February 24, 2018 When I am sitting down to view a movie or a tv show and I go to explore one of my media channels, I get no items available. When I check each of the other media channels, I get the same response. I have to re-scan the library so that it can rebuild. I can then view the items in each of the media channels I have. It's like the items in the Library.db database are getting deleted. I have verified this in Media Browser Classic, Emby Theatre, and through the web portal. Let me know if this makes sense to you. Thanks, Mike
mpm131 1 Posted February 24, 2018 Author Posted February 24, 2018 It is a drive array. I use Flexraid to to pool 4 disks together. I have been using Emby with this setup for a few years now and have not had an issue. The only major change that I had was that I had to re install Windows Home Server due to my primary disk getting corrupted. I had to replace the drive. I re-installed everything and it seems to have worked well other than the above issue. I did use the back up and restore plugin to restore my Emby environment. Mike
mpm131 1 Posted February 24, 2018 Author Posted February 24, 2018 Yes. These drives are on the same system. They are not external or networked drives.
d00zah 152 Posted February 24, 2018 Posted February 24, 2018 'New and Upcoming Movies on Dvd & Blu-ray' & 'New and Upcoming Movies on Netflix'. No content displayed. Have tried 'Refresh Channels' scheduled task, full scan, etc.... Logs show nothing interesting, but attached anyway
Luke 42206 Posted February 24, 2018 Posted February 24, 2018 The new server release also requires an update to the plugin so make sure you have that
d00zah 152 Posted February 24, 2018 Posted February 24, 2018 (edited) The new server release also requires an update to the plugin so make sure you have that It was 1 of 2 plugins updated after the 1st restart. This is after the 2nd restart w/ new, updated plugins. UPDATE: Content for the listed sections is now appearing. Thanks! UDATE2: And now they are empty again... Edited February 24, 2018 by d00zah
Luke 42206 Posted February 24, 2018 Posted February 24, 2018 We're going to have to catch this when the removal actually happens but it sounds to me like the drives are becoming unavailable and then a library scan is running during that time.
danielk23 3 Posted February 25, 2018 Posted February 25, 2018 I'm seeing the exact same behaviour here on a network share from a synology array. hundreds if not thousands of items deleted. I've turned off scheduled library scans for now to try and prevent this, so i can ensure the array is fully "awake" and then trigger a manual scan for library content. This only started happening since i installed 3.3.0.0
d00zah 152 Posted February 25, 2018 Posted February 25, 2018 (edited) This happened to me overnight. Opened the webUI to see my libraries on the home screen, but no 'Recent Media". Browsing each library confirmed they were all empty... no Movies, no TV Series, no Music... nuthin'. All the config data was intact, but all metadata (GBs, in fact) was gone. Log shows that @ ~11:30 last night, Emby decided to start deleting everything. Media is on a NAS device that is allowed to sleep when idle, but this has never posed an issue in the past, & was probably still active when the log indicates the 'purge' began. Currently in the middle of a ground-up scan, waiting to see how much manual effort (hours of updating, adding actor images, etc.) was lost. Edited February 25, 2018 by d00zah
Luke 42206 Posted February 25, 2018 Posted February 25, 2018 Try adjusting the schedule of the library scan to what is appropriate based on when your drives are available.
d00zah 152 Posted February 25, 2018 Posted February 25, 2018 Try adjusting the schedule of the library scan to what is appropriate based on when your drives are available. As I stated, I'm pretty sure the NAS was still spun up, as I was looking at the channel issues shortly before retiring for the evening... within 10-15 min. of the 'purge' beginning. You seem to be implying that people live on a regimented, predictable schedule. NAS(s) spin down whenever idle, which could be any time, at all. This hasn't been an issue since I started using MB3 shortly after the new project was announced. I should start running what amounts to a manually initiated scan... when I'm sure all conditions are favorable, from now on? That's hardly a reasonable solution.
Jedi Master Rob 1 Posted February 25, 2018 Posted February 25, 2018 My server did this as well upon update to 3.3, all libraries show no items post update and a library scan will find some items for a few minutes and then they dissappair again. The media is still on the drives and the only fix i found so far was to revert to 3.2.70, however all of the collections i had built for movies have been completely messed up.
hd4fun 6 Posted February 25, 2018 Posted February 25, 2018 what was it doing ? 2 days ago I was prompted for an update to v 3.3.0 So I selected restart server - it did restart but no update - it was still 3.2.7 I did this a couple times and still no luck so I went and stopped the emby server task Re-launched emby server - it then applied the patch and requested a restart restarted emby it applied v 3.3.0 then all the addons wanted a restart restarted emby again everything appeared ok - watched a movie library scan started soon after or within 12 hours Yesterday went to emby and all the media was missing (24 hours after update) restarted a manual library scan - was taking forever just to go 1/10th of 1 % it was complaining about all images (as in missing metadata - just took a 1 minute look) I had to leave and this morning (12 hours later again) it appears to be ok I believe it was going out and verifying all the images and or meta-data? Although I don't believe it downloaded much as the folder image dates didn't change for a couple I looked at - unless there was a db or metadata rebuild ? System: w2012, 16 Gb, 80TB over 12 disks All disks are active and on the same server as emby thanks
hd4fun 6 Posted February 25, 2018 Posted February 25, 2018 i did look but not to sure what to look for its over couple days this is what is repeated for different media again it seems to be reaching out to the meta data providers for all media internet was fine server has not been rebooted during this time nor since it is working now maybe omdb not responding due to too many requests ?? here is a snip - if this helps you at all seems to be working ok at the moment ----------------- 2018-02-24 20:39:01.599 Error HttpClient: Connection to https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=1951&t=Alice+in+Wonderland&type=movie timed out 2018-02-24 20:39:01.610 Error App: Error in The Open Movie Database *** Error Report *** Version: 3.3.0.0 Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application directory: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System MediaBrowser.Model.Net.HttpException: Connection to https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=1951&t=Alice+in+Wonderland&type=movie timed out ---> System.Threading.Tasks.TaskCanceledException: A task was canceled. at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() at System.Net.Http.HttpClient.<FinishSendAsyncBuffered>d__58.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetSearchResultsInternal>d__12.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetMovieImdbId>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetMovieResult>d__19`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<ExecuteRemoteProviders>d__43.MoveNext() MediaBrowser.Model.Net.HttpException at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetSearchResultsInternal>d__12.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetMovieImdbId>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetMovieResult>d__19`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<ExecuteRemoteProviders>d__43.MoveNext() InnerException: System.Threading.Tasks.TaskCanceledException System.Threading.Tasks.TaskCanceledException: A task was canceled. at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() at System.Net.Http.HttpClient.<FinishSendAsyncBuffered>d__58.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() at System.Net.Http.HttpClient.<FinishSendAsyncBuffered>d__58.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() 2018-02-24 20:39:02.066 Info App: MovieDbProvider: Finding id for item: Avengers Confidential Black Widow And Punisher2018-02-24 20:39:02.066 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Avengers+Confidential+Black+Widow+And+Punisher&language=en2018-02-24 20:39:02.366 Info HttpClient: GET https://api.themoviedb.org/3/movie/257346?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:02.506 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2014&t=Avengers+Confidential+Black+Widow+And+Punisher&type=movie2018-02-24 20:39:03.027 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/257346?api_key=5c6b04c68e904cfed1e6cbc9a9e683d42018-02-24 20:39:03.801 Info App: MovieDbProvider: Finding id for item: Batman The Dark Knight Returns Part 12018-02-24 20:39:03.801 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Batman+The+Dark+Knight+Returns+Part+1&language=en2018-02-24 20:39:04.108 Info HttpClient: GET https://api.themoviedb.org/3/movie/123025?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:04.489 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2012&t=Batman+The+Dark+Knight+Returns+Part+1&type=movie2018-02-24 20:39:04.744 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt2313197&plot=short&tomatoes=true&r=json2018-02-24 20:39:05.989 Info App: MovieDbProvider: Finding id for item: Batman The Killing Joke2018-02-24 20:39:05.989 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Batman+The+Killing+Joke&language=en2018-02-24 20:39:06.300 Info HttpClient: GET https://api.themoviedb.org/3/movie/382322?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:06.541 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2016&t=Batman+The+Killing+Joke&type=movie2018-02-24 20:39:06.961 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt4853102&plot=short&tomatoes=true&r=json2018-02-24 20:39:07.359 Info HttpClient: GET https://api.themoviedb.org/3/movie/382322?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers2018-02-24 20:39:07.663 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/382322?api_key=5c6b04c68e904cfed1e6cbc9a9e683d42018-02-24 20:39:08.239 Info App: Stopping chapter extraction for Big Hero 6 (2014) because a chapter was found with a position greater than the runtime.2018-02-24 20:39:08.242 Info App: MovieDbProvider: Finding id for item: Big Hero 62018-02-24 20:39:08.242 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Big+Hero+6&language=en2018-02-24 20:39:08.555 Info HttpClient: GET https://api.themoviedb.org/3/movie/177572?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:09.016 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2014&t=Big+Hero+6&type=movie2018-02-24 20:39:09.509 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt2245084&plot=short&tomatoes=true&r=json2018-02-24 20:39:09.954 Info App: MovieDbProvider: Finding id for item: Bolt2018-02-24 20:39:09.954 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Bolt&language=en2018-02-24 20:39:10.260 Info HttpClient: GET https://api.themoviedb.org/3/movie/13053?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:10.724 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2008&t=Bolt&type=movie2018-02-24 20:39:10.990 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt0397892&plot=short&tomatoes=true&r=json2018-02-24 20:39:11.624 Info App: MovieDbProvider: Finding id for item: Brave2018-02-24 20:39:11.624 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Brave&language=en2018-02-24 20:39:11.935 Info HttpClient: GET https://api.themoviedb.org/3/movie/62177?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:12.140 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2012&t=Brave&type=movie2018-02-24 20:39:12.553 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1217209&plot=short&tomatoes=true&r=json2018-02-24 20:39:15.046 Info App: MovieDbProvider: Finding id for item: Brother Bear2018-02-24 20:39:15.046 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Brother+Bear&language=en2018-02-24 20:39:15.357 Info HttpClient: GET https://api.themoviedb.org/3/movie/10009?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:15.846 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2003&t=Brother+Bear&type=movie2018-02-24 20:39:16.255 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt0328880&plot=short&tomatoes=true&r=json2018-02-24 20:39:16.367 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/10009?api_key=5c6b04c68e904cfed1e6cbc9a9e683d42018-02-24 20:39:17.201 Info App: MovieDbProvider: Finding id for item: Cars 22018-02-24 20:39:17.202 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Cars+2&language=en2018-02-24 20:39:17.514 Info HttpClient: GET https://api.themoviedb.org/3/movie/49013?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:18.031 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2011&t=Cars+2&type=movie2018-02-24 20:39:18.495 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1216475&plot=short&tomatoes=true&r=json2018-02-24 20:39:18.806 Info App: MovieDbProvider: Finding id for item: Chicken Run2018-02-24 20:39:18.806 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Chicken+Run&language=en2018-02-24 20:39:19.107 Info HttpClient: GET https://api.themoviedb.org/3/movie/7443?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:19.540 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2000&t=Chicken+Run&type=movie2018-02-24 20:39:19.943 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt0120630&plot=short&tomatoes=true&r=json2018-02-24 20:39:20.498 Info App: MovieDbProvider: Finding id for item: Cool World2018-02-24 20:39:20.498 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Cool+World&language=en2018-02-24 20:39:20.804 Info HttpClient: GET https://api.themoviedb.org/3/movie/14239?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:21.710 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=1992&t=Cool+World&type=movie2018-02-24 20:39:22.212 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt0104009&plot=short&tomatoes=true&r=json2018-02-24 20:39:22.426 Info HttpClient: GET https://api.themoviedb.org/3/movie/14239?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers2018-02-24 20:39:22.811 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/14239?api_key=5c6b04c68e904cfed1e6cbc9a9e683d42018-02-24 20:39:23.542 Info HttpClient: GET https://api.themoviedb.org/3/movie/tt0848537?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:24.070 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt0848537&plot=short&tomatoes=true&r=json2018-02-24 20:39:24.739 Info App: MovieDbProvider: Finding id for item: Fire & Ice2018-02-24 20:39:24.739 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Fire+%26+Ice&language=en2018-02-24 20:39:25.042 Info HttpClient: GET https://api.themoviedb.org/3/movie/15035?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:25.652 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=1982&t=Fire+%26+Ice&type=movie2018-02-24 20:39:26.072 Info HttpClient: GET https://api.themoviedb.org/3/movie/15035?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers2018-02-24 20:39:26.343 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/15035?api_key=5c6b04c68e904cfed1e6cbc9a9e683d42018-02-24 20:39:26.815 Info App: MovieDbProvider: Finding id for item: Frankenweenie2018-02-24 20:39:26.815 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Frankenweenie&language=en2018-02-24 20:39:27.117 Info HttpClient: GET https://api.themoviedb.org/3/movie/62214?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:27.756 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2012&t=Frankenweenie&type=movie2018-02-24 20:39:28.243 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1142977&plot=short&tomatoes=true&r=json2018-02-24 20:39:28.646 Info HttpClient: GET https://api.themoviedb.org/3/movie/62214?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers2018-02-24 20:39:29.184 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/62214?api_key=5c6b04c68e904cfed1e6cbc9a9e683d42018-02-24 20:39:29.554 Info App: MovieDbProvider: Finding id for item: Frozen2018-02-24 20:39:29.554 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Frozen&language=en2018-02-24 20:39:29.861 Info HttpClient: GET https://api.themoviedb.org/3/movie/109445?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:30.373 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2013&t=Frozen&type=movie2018-02-24 20:39:30.493 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt2294629&plot=short&tomatoes=true&r=json2018-02-24 20:39:30.889 Info App: MovieDbProvider: Finding id for item: Gnomeo and Juliet2018-02-24 20:39:30.889 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Gnomeo+and+Juliet&language=en2018-02-24 20:39:31.189 Info HttpClient: GET https://api.themoviedb.org/3/movie/45772?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:31.360 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2011&t=Gnomeo+and+Juliet&type=movie2018-02-24 20:39:31.940 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/45772?api_key=5c6b04c68e904cfed1e6cbc9a9e683d42018-02-24 20:39:32.299 Info App: MovieDbProvider: Finding id for item: Green lantern First Flight2018-02-24 20:39:32.299 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Green+lantern+First+Flight&language=en2018-02-24 20:39:32.612 Info HttpClient: GET https://api.themoviedb.org/3/movie/17445?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:32.992 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2009&t=Green+lantern+First+Flight&type=movie2018-02-24 20:39:52.993 Error HttpClient: Connection to https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2009&t=Green+lantern+First+Flight&type=movie timed out 2018-02-24 20:39:53.004 Error App: Error in The Open Movie Database *** Error Report *** Version: 3.3.0.0 Command line: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server Application directory: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\System MediaBrowser.Model.Net.HttpException: Connection to https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=2009&t=Green+lantern+First+Flight&type=movie timed out ---> System.Threading.Tasks.TaskCanceledException: A task was canceled. at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() at System.Net.Http.HttpClient.<FinishSendAsyncBuffered>d__58.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetSearchResultsInternal>d__12.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetMovieImdbId>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetMovieResult>d__19`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<ExecuteRemoteProviders>d__43.MoveNext() MediaBrowser.Model.Net.HttpException at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsync>d__17.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetSearchResultsInternal>d__12.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetMovieImdbId>d__20.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Omdb.OmdbItemProvider.<GetMovieResult>d__19`1.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.MetadataService`2.<ExecuteRemoteProviders>d__43.MoveNext() InnerException: System.Threading.Tasks.TaskCanceledException System.Threading.Tasks.TaskCanceledException: A task was canceled. at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() at System.Net.Http.HttpClient.<FinishSendAsyncBuffered>d__58.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult() at System.Net.Http.HttpClient.<FinishSendAsyncBuffered>d__58.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.<SendAsyncInternal>d__20.MoveNext() 2018-02-24 20:39:53.006 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/17445?api_key=5c6b04c68e904cfed1e6cbc9a9e683d42018-02-24 20:39:54.049 Info App: MovieDbProvider: Finding id for item: Heavy Metal2018-02-24 20:39:54.049 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Heavy+Metal&language=en2018-02-24 20:39:54.349 Info HttpClient: GET https://api.themoviedb.org/3/movie/11827?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:54.583 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&plot=full&r=json&y=1981&t=Heavy+Metal&type=movie2018-02-24 20:39:55.404 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt0082509&plot=short&tomatoes=true&r=json2018-02-24 20:39:55.977 Info HttpClient: GET https://api.themoviedb.org/3/movie/11827?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers2018-02-24 20:39:56.195 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/11827?api_key=5c6b04c68e904cfed1e6cbc9a9e683d42018-02-24 20:39:56.621 Info HttpClient: GET https://api.themoviedb.org/3/movie/tt1411704?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:57.283 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt1411704&plot=short&tomatoes=true&r=json2018-02-24 20:39:57.856 Info HttpClient: GET https://api.themoviedb.org/3/movie/tt0837562?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null2018-02-24 20:39:58.266 Info HttpClient: GET https://www.omdbapi.com?apikey=fe53f97e&i=tt0837562&plot=short&tomatoes=true&r=json2018-02-24 20:40:18.269 Error HttpClient: Connection to https://www.omdbapi.com?apikey=fe53f97e&i=tt0837562&plot=short&tomatoes=true&r=json timed out 2018-02-24 20:40:18.281 Error App: Error in The Open Movie Database *** Error Report *** Version: 3.3.0.0
Luke 42206 Posted February 25, 2018 Posted February 25, 2018 It's best to just attach the complete log so that i can look at it, thanks.
tdwilli1 0 Posted February 25, 2018 Posted February 25, 2018 Exact same thing happening to me. Can't see any of my media through MC or Theater. Scanned through TV and Music and then taking about .1% per 5 minutes.
Elenthil 4 Posted February 25, 2018 Posted February 25, 2018 Hi, i also have the problem that after update everything is gone.
Luke 42206 Posted February 25, 2018 Posted February 25, 2018 Hi, i also have the problem that after update everything is gone. Hi, can you try running a library scan? thanks.
Elenthil 4 Posted February 25, 2018 Posted February 25, 2018 i run a library scan, it discoverd items, when scan is finishd, all is deletet
Luke 42206 Posted February 25, 2018 Posted February 25, 2018 i run a library scan, it discoverd items, when scan is finishd, all is deletet Please attach the emby server log. you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
