pmartel51175 0 Posted February 25, 2018 Posted February 25, 2018 I have a question, and pardon me if this has been discussed before, when in Cinema Mode and after intros/trailers play, there is an image of the movie that is about to play before the movie actually plays. Is there a way to disable this? Or is there an image that I can just make as 100% black? I would rather have it play just like the theater and have a black screen before the movie starts. Thanks.
ebr 16310 Posted February 25, 2018 Posted February 25, 2018 Hi. You are using the web app or Theater? I think it does show a backdrop of the movie while the video is loading. This is not related to Cinema Mode I don't believe. Should be the same even without that enabled.
pmartel51175 0 Posted February 25, 2018 Author Posted February 25, 2018 (edited) I am using both, and yes that is true that it does load the image even outside of cinema mode. I guess I am wondering if there is a way around it in cinema mode. Edited February 25, 2018 by pmartel51175
Guest asrequested Posted February 25, 2018 Posted February 25, 2018 It would nice to be able to disable it. It's inconsistent. Sometimes it comes up and goes away so fast, all I get is a flash.
