ireme 11 Posted March 18, 2014 Posted March 18, 2014 (edited) Please, I would need help on how DLNA works because it is a bit confusing to me. I enabled the server "Enable DNLA play" but when I click on settings nothing appears.In Dashboard there are 3 connections for WDTVLive, TV Salon and the PC Mediacenter itself appears (The TV is a Samsung latest generation).I would need to install something else for DLNA work? I attach the server log: http://www.firedrive.com/file/CA1409937356BC1E Edited March 18, 2014 by ireme
swhitmore 781 Posted March 18, 2014 Posted March 18, 2014 You need another client to browse and select the dlna client you want to stream to. In the case of the web client, there is a remote icon next to the play icon on the details page.
ireme 11 Posted March 18, 2014 Author Posted March 18, 2014 (edited) Thanks for the help, but something is not working for me. When click from TV ,Go home or View settings nothing is show it. Maybe a compatibility issue? Edited March 18, 2014 by ireme
7illusions 1249 Posted March 18, 2014 Posted March 18, 2014 Those commands doesn't work on dlna devices. What you want to do is to look up a movie in the webclient that you want to watch. Instead of clicking on "Play" you click "Remote" and select your playback target.
ireme 11 Posted March 18, 2014 Author Posted March 18, 2014 (edited) 7Illusions, Or I am doing something wrong or DLNA does not work for me.I'm playing a movie on TV and in the WD TV Live and the "play" is missing. Edited March 18, 2014 by ireme
7illusions 1249 Posted March 18, 2014 Posted March 18, 2014 You're looking in the wrong place. Step-by-Step tutorial from the screenshot you posted. 1. Close remote window, that is only used to control a already started playback. 2. Click the Movies text in upper left corner. 3. Select the first movie that shows. 4. If no buttons are visible, scroll down a little bit until you see 3 buttons, "Play", "Remote" and "Edit" next to each other in the center of screen. 5. Click on the center button ("Remote") and select a session to play to. 1
ireme 11 Posted March 18, 2014 Author Posted March 18, 2014 Excellent tutorial 7Illusions, I tried to find similar steps tutorial for DLNA but had not found.Now it's working for me.Thanks for your support.
