Swynol 375 Posted March 18, 2014 Posted March 18, 2014 Hi, sorry the mods closed my previous thread about the poster wall issue. They closed it and linked to the thread http://mediabrowser.tv/community/index.php?/topic/4719-cant-switch-to-poster-wall-in-mbt-successfully/ however that is a different error. If you select the movies icon you can click on the sort by menu and save the view settings. (as per the link to the other thread) if you click on a collection in the folders menu, the sort by menu is greyed out, you can select view but if you go back to 'home' and back to the collections then the view doesnt stick. in future it might be worth not locking a thread until you hear back from the OP. 1
jespermart 5 Posted March 19, 2014 Posted March 19, 2014 Hi, sorry the mods closed my previous thread about the poster wall issue. They closed it and linked to the thread http://mediabrowser.tv/community/index.php?/topic/4719-cant-switch-to-poster-wall-in-mbt-successfully/ however that is a different error. If you select the movies icon you can click on the sort by menu and save the view settings. (as per the link to the other thread) if you click on a collection in the folders menu, the sort by menu is greyed out, you can select view but if you go back to 'home' and back to the collections then the view doesnt stick. in future it might be worth not locking a thread until you hear back from the OP. +1
jespermart 5 Posted March 19, 2014 Posted March 19, 2014 (edited) +1 I have the same error Edited March 19, 2014 by jespermart
spriggig 9 Posted March 20, 2014 Posted March 20, 2014 I read the previous thread and you're right it didn't solve this problem, I have the same issue--I'd like to be able to save views in ALL screens.
The Baron 64 Posted March 22, 2014 Posted March 22, 2014 The appearance of the 'Remember Settings' button would seem to be inconsistant. Currently MBT does not show the option in any section - Movies, TV or any of the folders I have set up. Previously, the button was available in the TV section only.
A8HTPC 38 Posted March 23, 2014 Posted March 23, 2014 I noticed the "sort" menu is disabled now where it used to be enabled. This was looking at DVD and bluray movies when click on DVD or BluRay under folder tab
