jls7193 0 Posted February 23, 2018 Posted February 23, 2018 Hi, I’m new to the community so I’m sorry if already been asked and I just can’t find it. Once I install the app onto my Samsung tv or some updates devices like laptop it asks me to constantly put in IP address and port number but on my Xbox I was able to link my server up via ‘pin’ is this not available for other devices and it’s a lot easier to access. Thanks.
jls7193 0 Posted February 23, 2018 Author Posted February 23, 2018 Hi, what model Samsung do you have? I think it’s 2013 series. But my laptop is very latest model and having same problem with that but had to open browser to link but don’t get access in the app only on browser.
jls7193 0 Posted February 24, 2018 Author Posted February 24, 2018 I have tried skipping and constantly the page is resetting to this or a different page which just states up and port
FrostByte 5453 Posted February 24, 2018 Posted February 24, 2018 I think it’s 2013 series. Is your model an F series then (Fxxxx)?
Luke 42241 Posted February 24, 2018 Posted February 24, 2018 I have tried skipping and constantly the page is resetting to this or a different page which just states up and port What happens when you press skip on that screen?
jls7193 0 Posted February 24, 2018 Author Posted February 24, 2018 What happens when you press skip on that screen? You’re just redirected back to the same part it’s like there is a missing link or something missing on other software you could just press back and the pin was there but not on here just missing Is your model an F series then (Fxxxx)? E series I believe
Luke 42241 Posted February 24, 2018 Posted February 24, 2018 Ok well getting back on topic of the TV app, this is a community app built for older Samsung devices. It does not support the Emby Connect login feature that you're using on the Xbox. What this means is you'll have to enter the server address manually. It must have a setting to remember the login info, right @@FrostByte?
jls7193 0 Posted February 24, 2018 Author Posted February 24, 2018 Ok well getting back on topic of the TV app, this is a community app built for older Samsung devices. It does not support the Emby Connect login feature that you're using on the Xbox. What this means is you'll have to enter the server address manually. It must have a setting to remember the login info, right @@FrostByte? Ah fair enough that’s fine, I was just checking because I saw it on other devices etc and was wondering why this was.
FrostByte 5453 Posted February 24, 2018 Posted February 24, 2018 Ahh, E-series is 2012 then. That picture threw me off, must be from another app True, the old community app never had Connect added before the developers stopped working on it. Once you've added your IP/port and logged in the first time there is an option in the settings to remember User, etc. You should not have to enter that anymore.
