Hi guys. Hoping someone can help. A friend of mine purchased a small generic camera that came with only a cable. I have plugged it into windows but no new.hardware poops up. I also did a reset but nothing. Any help is appreciated.
Thanks
Dom
mastrmind11
is it usb powered or are you missing the power cord?  check that the usb cable is good.  google the make and model and see if it requires a specific windows driver.
It's is usb & I have it plugged into windows but nothing is happening. It's a cheap knock off that he bought at a flea market. Nothing else came with it. Is there a generic app that I can download?
Oh....what I found online is something that looks like it and the name is kmax q2 etl ip610 720p mini camera
mastrmind11
Well if that's the case, that's not a webcam that plugs into a computer.  The USB cable that came is likely the power cord which means there should be another piece that plugs into the wall (to which you plug the USB cable) like almost every smartphone in the modern world today.  Read the manual, and if it's missing one, throw the camera in the garbage because it will be useless w/o one.
Ok. I'll tell him. It was only 5 bucks so no loss.....to him.
Thanks.
