Accents issue in video paths / Emby for Kodi
capitaineflam25
Hi,
i'm unable to browse a video library in Emby for Kodi.
According to the attached log extract, it seems that it is due to an invalid caracter : the accentued "é" in "vidéos".
I can change it to a non accentuated "e" but there is a lot of nested subfolders concerned with that.
In French language, accents are usuals.
Regards
kodi.log
Edited by capitaineflam25
Angelblue05
I'll look into it and let you know. Will have to change the way things are done, where the library name instead of it's id is used, causing issues like this.
  • Like 1
capitaineflam25
Thanks.
I can rename the Library without an accent until the issue is fixed. I thought the issue was concerning the file path.
Guest
