rechner123 12 Posted February 21, 2018 Posted February 21, 2018 (edited) Hi On my tablet and smartphone i can not open a recorded show under recording groups. If i click on a show, i become black screen with upside down android logo on the left upper side. Emby Android 2.9.89 With the webbrowser it works. Edited February 21, 2018 by rechner123
ebr 16299 Posted February 21, 2018 Posted February 21, 2018 Hi. Are you running the beta version of the server?
Luke 42147 Posted February 21, 2018 Posted February 21, 2018 Are you using a live tv plugin, and if so, which one?
rechner123 12 Posted February 21, 2018 Author Posted February 21, 2018 Hi luke. Yes i am using dvbviewer rec service plugin.
Luke 42147 Posted February 21, 2018 Posted February 21, 2018 Ok following the upcoming stable, there will be a plugin update, and that should resolve this. Thanks. 1
serpi 82 Posted February 22, 2018 Posted February 22, 2018 I have exactly the same problem - empty groups in Android client but working in web client - and I'm using the Next PVR plugin for live TV. Will this also work with the upcoming update? Thanks & Ciao, Alfred
