shocker 135 Posted February 19, 2018 Posted February 19, 2018 Hello, Is there a possibility to change the default view for a library to Thumb Card? Or can I change it from the dashboard some users? Thanks
Luke 42242 Posted February 19, 2018 Posted February 19, 2018 In the future it will remember after you select it so I think you'll be happy with that. But no there is no way to change the defaults at this time.
shocker 135 Posted February 19, 2018 Author Posted February 19, 2018 I have a Movie library without any metadata in it and the default view is: "posters". The problem is that the indexed picture from the video looks odd with posters view and I would like to change it by default to Thumb Poster in order to look nice, for all the users.
Luke 42242 Posted February 19, 2018 Posted February 19, 2018 Ok, yes it's possible for the future. You could also consider changing that library to home videos.
