stratos67 0 Posted February 19, 2018 Posted February 19, 2018 Hello people! Just got the android app for my device. I have the option to load external subs from my library but unfortunately the Greek subs are not showing correctly. Like the encoding is not correct,,,it shows unreadable characters. Any suggastions?? Thanks!
ebr 16337 Posted February 19, 2018 Posted February 19, 2018 What version of the app are you running (shown on the settings page)? Wait... this is not the Android TV app is it?
stratos67 0 Posted February 19, 2018 Author Posted February 19, 2018 The version is 2.9.86 it is the Emby for Android app..
Luke 42244 Posted February 19, 2018 Posted February 19, 2018 What version of Android? Do they look correct in the web app?
stratos67 0 Posted February 19, 2018 Author Posted February 19, 2018 My smartphone and the mecool box, both have android 7. Havent tried the web app, i will
stratos67 0 Posted February 20, 2018 Author Posted February 20, 2018 it happens to any subtitle file with Greek characters, no matter what tv serie or movie is made for.
Luke 42244 Posted February 20, 2018 Posted February 20, 2018 And what is the name of the subtitle file? Thanks.
stratos67 0 Posted February 27, 2018 Author Posted February 27, 2018 For example, The.Blacklist.S02E05.720p.HDTV.X264-DIMENSION.srt if this is what you want.
Luke 42244 Posted February 27, 2018 Posted February 27, 2018 For example, The.Blacklist.S02E05.720p.HDTV.X264-DIMENSION.srt if this is what you want. Yes, try renaming it to: The.Blacklist.S02E05.720p.HDTV.X264-DIMENSION.gre.srt Then run a scan on that folder, and after that the subs should display correctly. Thanks.
stratos67 0 Posted February 27, 2018 Author Posted February 27, 2018 Thank you. Meanwhile, i think i found another solution that seems to work I opened the file with notepad and changed the encoding by "save as", from ANSI to UTF-8 And it works fine! But now, i have to change all tie subs of my library....i hope i can find a way to massively change all...and not one by one... Thanks again!!
