dejavux2 47 Posted February 19, 2018 Posted February 19, 2018 (edited) Hello, I'm on Emby for WMC Version 3.0.310.0 I don't know when this started, but the Auto-Scroll for Overview is no longer working. When I go to the config and go to Theme Options, the "Auto Scroll Overview" is checked. Any help would be greatly appreciated. Thank you! Edited February 19, 2018 by dejavux2
ebr 16332 Posted February 19, 2018 Posted February 19, 2018 Exactly where are you noticing this? I'm pretty sure it has only ever been supported in the detail screen.
dejavux2 47 Posted February 23, 2018 Author Posted February 23, 2018 (edited) Sorry for the late response. Actually, the detail screen is the only place it's not working. Emby > TV Shows.......... highlight a show, if the description is long, auto-scroll is working Emby > TV Shows > Enter into a TV Show........ highlight a season, if the description is long, auto-scroll is working Emby > TV Shows > Enter into a TV Show > Enter into a Season....... highlight an episode, if the description is long, auto-scroll is working Emby > TV Shows > Enter into a TV Show > Enter into a Season > Enter into an Episode..... if the description is long, auto-scroll IS NOT WORKING. So, it's the detail screen where the auto-scroll is not working. Emby for WMC Version 3.0.310.0 Theme: Chocolate Edited February 23, 2018 by dejavux2
One2Go 120 Posted February 23, 2018 Posted February 23, 2018 Also using Throg's themes work the same way only in the detail window it does not work, but once you navigate to the place where the detail description is, you can page up or down to read all the description. Would be nice to have it auto scroll.
throgmorton 96 Posted March 6, 2018 Posted March 6, 2018 Also using Throg's themes work the same way only in the detail window it does not work, but once you navigate to the place where the detail description is, you can page up or down to read all the description. Would be nice to have it auto scroll. That's by design I didn't think it needs to auto scroll when you have selected a title cause you can manipulate the scroll with the remote. This is unlike when you are scanning trough your collection which is why I use auto scroll only really for those views. Sent from my iPhone using Tapatalk
One2Go 120 Posted March 6, 2018 Posted March 6, 2018 That's by design I didn't think it needs to auto scroll when you have selected a title cause you can manipulate the scroll with the remote. This is unlike when you are scanning trough your collection which is why I use auto scroll only really for those views. Thanks for letting me know that it is by design. You do know how much I like your themes and try to make others aware of the features when possible thus my comment here. Regarding the auto scroll when you are in the detail window with a 10 foot remote the focus is on the play button to maneuver arrow up is easy to get to the description but to get back to the Play button not so easy because down arrow scrolls through the cast until the end when you are back to play. The only quick way is back out and enter again. When I am in a detail window I often read the description and it may change my mind to play it now or later. This is not a problem for 90% of the TV shows as they have very short descriptions unless they are foreign language. In any occasion thanks for posting and caring for your customers it is a big plus. Some that are on Emby Theater are waiting and might disagree
throgmorton 96 Posted March 8, 2018 Posted March 8, 2018 Thanks for letting me know that it is by design. You do know how much I like your themes and try to make others aware of the features when possible thus my comment here. Regarding the auto scroll when you are in the detail window with a 10 foot remote the focus is on the play button to maneuver arrow up is easy to get to the description but to get back to the Play button not so easy because down arrow scrolls through the cast until the end when you are back to play. The only quick way is back out and enter again. When I am in a detail window I often read the description and it may change my mind to play it now or later. This is not a problem for 90% of the TV shows as they have very short descriptions unless they are foreign language. In any occasion thanks for posting and caring for your customers it is a big plus. Some that are on Emby Theater are waiting and might disagree Depending on which detail view you are using you can usually press left or right when your on the cast or overview and it should bounce you back to the play button.
ebr 16332 Posted March 8, 2018 Posted March 8, 2018 I remember now - for Chocolate (the default theme) the overview dynamically adjusts its width based on the length of the overview in lieu of auto scrolling.
dejavux2 47 Posted March 11, 2018 Author Posted March 11, 2018 I remember now - for Chocolate (the default theme) the overview dynamically adjusts its width based on the length of the overview in lieu of auto scrolling. Ok, but it's not working correctly. The detail section is getting wider, but you cannot view all of the detail, as it is cut-off at the bottom. Thanks everyone.
ebr 16332 Posted March 11, 2018 Posted March 11, 2018 Ok, but it's not working correctly. The detail section is getting wider, but you cannot view all of the detail, as it is cut-off at the bottom. It is working there is just so much information that can fit - even if we do make it wider. It is only the rarest of cases where this is a problem though.
