unisoft 355 Posted September 25, 2018 Posted September 25, 2018 Can you not have an option for 50hz if you default to 60hz in config for live TV? Simplest override but allows correct PAL 50hz (25 frames)? Nobody in PAL land likes 60hz refresh rates with 50hz content. Just a suggestion as incorrect refresh rate is terminal reason not to use if so.
