davedick 19 Posted February 17, 2018 Posted February 17, 2018 I have the library set do the use data delete media. When I select the show and go in to a season, I see the list of episodes, but when I select one, it just plays instead of showing the delete, play, resume options. However, if I select the episode, under "next up", it gives me the option to delete. It's there a swing, so I can see the delete option under a particular season? Sent from my HTC U11 using Tapatalk
Luke 42243 Posted February 18, 2018 Posted February 18, 2018 Currently that screen doesn't take you to a detail view because it would essentially just repeat everything you can already see in the list. It's set to just play to reduce the number of clicks needed to operate. We can always consider a setting for this in the future. thanks.
Guest asrequested Posted February 18, 2018 Posted February 18, 2018 But we still need the tools that we get in the web app.
