andyblac644 69 Posted February 17, 2018 Posted February 17, 2018 (edited) I have just been setting my ubiquity USG 4 Pro and with my Dual WAN, i have setup port forward and checked port is open on WAN1, but it seems Emby is detecting my WAN2 for external access, and the port is not open , and thus i can't share my server. i do i tell Emby to use my WAN1 external IP for external access? Thanks Edited February 17, 2018 by andyblac644
mastrmind11 722 Posted February 17, 2018 Posted February 17, 2018 what happens if you disconnect WAN2, leave WAN1 connected and reboot your Emby box?
Guest asrequested Posted February 17, 2018 Posted February 17, 2018 How are you configuring this? WAN2 as failover?
Solution andyblac644 69 Posted February 17, 2018 Author Solution Posted February 17, 2018 ok sussed it, in ADVANCE: External domain: i can just enter the external ip for WAN1 it works. thanks for trying to help anyway. 1
