Sorcerer 0 Posted February 16, 2018 Posted February 16, 2018 (edited) Okay trying to get Emby running on my Dedicated Server PC but it will not run. I have tried both the setup and non setup version just won't start. PC is running Windows 7 Ultimate x64 Latest version of dotnet Framework is installed Need more Info let me know -- edit -- Forgot to say Emby has not been installed on this PC since a fresh windows install Edited February 16, 2018 by Sorcerer
ebr 16310 Posted February 16, 2018 Posted February 16, 2018 Hi. Please see the link below and then fully describe what happens and provide a log. Thanks. How to Report a Problem
Sorcerer 0 Posted February 16, 2018 Author Posted February 16, 2018 (edited) There is no Log File Created. When I click on EmbyServer.exe nothing shows up, doesn't even show the file in windows task manager. I have the latest version of .net framework installed and the version of the C++ runtimes it downloaded when I first ran the setup. I have tried both the Setup and the Portable version neither will run on here. I have even tried running it as Admin Edited February 16, 2018 by Sorcerer
Solution Luke 42205 Posted February 16, 2018 Solution Posted February 16, 2018 Hi, make sure you have windows 7 sp1 installed plus windows updates fully up to date. Once you've done that it should run fine. Thanks. 1
Sorcerer 0 Posted February 16, 2018 Author Posted February 16, 2018 Updating Windows fixed the problem thanks
