JarvisTek 3 Posted February 15, 2018 Posted February 15, 2018 As the Olympics are recording, I'm having a bear of a time trying to get "episodes" sorted properly since my recordings end up looking like "2018 Winter Olympics_20180213_20002330.ts" instead of something more along the lines of "2018 Winter Olympics S00E03.ts". One thing that NextPVR does for me is create a metadata file that has all the info I could possibly need for sorting recordings into seasons, episodes, etc. Is there any part of Auto Organize that works off of metadata currently? I could probably code something up, but I wanted to make sure I'm not duplicating effort. I imagine most people record TV to a folder and Emby just looks directly at that folder, but my setup consists of a Windows 10 VM running NextPVR and an Ubuntu VM that runs Emby. When something is recorded, it is recorded into a flat directory. Then Emby runs Auto Organize and moves it over to a structured directory on the Emby server (Series\Season\Episode).
Luke 42253 Posted February 15, 2018 Posted February 15, 2018 Hi, no, you'll probably just want to handle these manually. What kind of tuner do you have?
JarvisTek 3 Posted February 15, 2018 Author Posted February 15, 2018 Ceton InfiniTV 6 Eth So far NextPVR is the only thing I've found to work reliably with it (since it was designed for WMC). I've wanted to see if MythTV would work, but I haven't had the time.
JarvisTek 3 Posted February 25, 2018 Author Posted February 25, 2018 (edited) I can't find anything about it on the forums, but BRAVO good sir (in regards to the NextPVR plugin update last night)! I think it's sub3 or sven (or maybe they're the same), but whoever is behind it, my constant moving of media files appears to be over along with the added benefit of not having to re-identify already metadata'd recorded tv! Thank you so much! Edited February 25, 2018 by JarvisTek
