shyne 0 Posted February 14, 2018 Posted February 14, 2018 Hello, I've noticed that I have to run restart emby every day because it crashed. After looking at the logs, I see that it is spamming mb3admin.com adresse, like trying to connect to it and posting data 10 times per seconds !!! This behaviour result in my server being freaking slow, and also in emby being very unstable as it crash on its own after a while ( a couple of hours after startup). I only use the web app as a client. System : Debain 9 64 bit Emby-server : 3.2.70.0 installed via the deb file you provide. I also disabled ipv6 on this server, but i checked using wireshark and it try to connect to the ipv4 of the mothership, so I don't think it is related. See the pastebin of the last logs : https://pastebin.com/raw/pmuJYYqi Thank you.
Luke 42245 Posted February 14, 2018 Posted February 14, 2018 Interesting, thanks for the report. We'll take a look at this. Would you mind performing a quick test. Please try uninstalling the Trailers plugin and then let me know if this still happens. That will help me narrow it down. Thanks !
