deaerator 2 Posted March 17, 2014 Posted March 17, 2014 I am just curious if there is any serious cons or pros to having mediabrowser server installed on a separate machine and have the it pointed at a nas box where the media is located.
ebr 16357 Posted March 17, 2014 Posted March 17, 2014 I'm not sure what you are specifying as "separate". Do you mean separate from your client app or separate from your actual media? In either case, that is a very common scenario and works just fine.
aspdend 177 Posted March 17, 2014 Posted March 17, 2014 My MB Server is located on my main PC, my htpc under the telly has MBC and MBT installed on it and my media is on a third machine - my UnRAID server. All are connected on my home network and all work fine...
WarrenH 16 Posted March 17, 2014 Posted March 17, 2014 Then you're having to have 3 machines on Sent from my HTC One using Tapatalk
